Page 23 of 37 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 368
  1. #221
    McMullet
    Guest
    Good to hear you're making progress Lucy! Look forward to seeing the pics and videos.
  2. #222
    Ocracoke's Avatar
    Team Kaizen
    Jibril
    Installed the Ragebridge into the robot and soldered up a new wiring loom for it. I've clearly forgotten how to solder but it is kind of done, needs branching off for the weapon. The bodywork also needs adaptation to add in a channel to run the wiring through to the other side of the robot.
    Took a brief video of the robot driving around. Bit of an oddity as left was forwards, right was backwards, forwards was turn right and so on on the controller.
    Next stage is to get the armour plates CADed up and then work on the weapon.
    BW: Shu!, The Honey Badger
  3. #223
    McMullet
    Guest
    Yeeees! Looks very nippy and well-controlled.
  4. #224
    Ocracoke's Avatar
    Team Kaizen
    Aww thanks! I definitely need to sort out the radio controls but it works well enough for the moment. Next stop, the big axe. Speaking of axes...
    Azriel
    Finally the video is done! This has been an absolute headache. I couldn't find music that suited it, I couldn't correct a audio problem that meant it crackled, the whole thing has been through two renditions but here it is, for better or for worse. As noted in the video, it does still need a locking pin, tether and painting with a metal axe but works well enough for now.
  5. #225
    Oohhh fantastic. nice power from the axe. Whats the total weight of the FW now?
  6. #226
    McMullet
    Guest
    Looks great! Nice work on the video too, I enjoyed the timelapse. Have you tried self-righting?
  7. #227
    Ocracoke's Avatar
    Team Kaizen
    Aww, thanks guys!
    11.1kg as is so plenty of weight to put something really tasty on there.
    Yeah but it isn't playing ball. When I try to, the gears slip (you can hear it in the video at the end) so I think there is some work to do in getting it more secure but it shouldn't be a problem. If it comes down to it, I can always add in another stage to the gearbox. Switching to LiPo will also help if it needs it .
  8. #228
    Ocracoke's Avatar
    Team Kaizen
    Been busy today painting the body of Azriel and the side arms of Jibril, the weather was just too nice to pass up. The latter isn't ready to show until all the metal parts are done but Azriel is practically finished.
    Looks alright I think. The axe I've deliberately not painted as that is only a temporary affair until I can find someone able to cut a all metal one for me. I think I've fixed the slipping gear problem for now but I suspect it'll need redoing properly, the gear mesh but aren't meshed enough. I had the opposite problem on Jibril 1.x and wanted to avoid a repeat. Oh well... :P
    Next stage is to get the metal panels made up for the Middleweight and start work on the new Scythe-Axe.
  9. #229
    McMullet
    Guest
    Good work! Are the wheels from an RC car?
  10. #230
    Ocracoke's Avatar
    Team Kaizen
    Yeah, they are from a 1/10 or a 1/8 scale RC car with a 0 offset and the hub is bolted directly to the flat face of the wheel. They've proven surprisingly durable though I could do with new ones :P Nice and grippy though.
