Page 18 of 18 FirstFirst ... 8161718
Results 171 to 176 of 176
  1. #171
    Roboteer
    Status
    Offline
    Name
    Robert Shalders
    Robots
    Flatfish (FW), Naginata (BW)
    Posts
    13
    I've had the standard RS mains soldering iron for XT60s and XT90s and it works for both, also invest in a small metal clamp with corkscrew handle to hold the connector in place while soldering, makes it much easier. For anything smaller most cheap irons should be ok.
  2. #172
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Got a strong and neatish solder on the EC5 now but managed to get solder down the connector so would not slot into the plastic housing
    So now i have ordered a soldering station and solder sucker from RS, spent a lot of money on all the parts so committed now so might aswell give myself the best chance when soldering.
  3. #173
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    980
    It'll come with practice as to how to solder these things.
  4. #174
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Yeah, I have plenty EC5's now so going to get practising soldering more, connectors so much trickier than just wires lol
  5. #175
    RogueTwoRobots's Avatar
    Roboteer
    Status
    Offline
    Name
    Jamie McHarg
    Robots
    Location
    Aberdeen, Scotland
    Posts
    3,961
    Get a block of wood and drill a hole in it same diameter as the connectors (5mm I think). Push the connector down into it until just the last little section that you're soldering the wire onto is sticking out the wood. This way, when the solder runs, it won't run down the connector. Any excess around the soldered end can just be filed down (again easier when it's in the block of wood). Also use a little less solder so less overflows when you put the wire in. So long as the wire and the connector are tinned beforehand, you'll still get a good solid connection.
    Jamie McHarg
    RogueTwo Robots
  6. #176
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    83
    Wheels done and ready to go
    EDIT: Anyone know why my images are showing so small untill click on them? Using the build in "insert image" button
