Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 154
  1. #141
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    72
    Ah, I had missed it was a XT-90. You would need one of these - https://hobbyking.com/en_us/xt90-mal...-2pcs-bag.html - to make the connection.
    Sorted, cheers
    This robot building is expensive!
  2. #142
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    957
    Hahhaa, that it is. I once totaled up how much my second version of The Honey Badger cost me. Close to about £400 but then again, I was things like a pricey transmitter at the time and such.
  3. #143
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    72
    Yeah lol, I managed to get a second hand DX6i for not too much, but between the ESC and everything else plus tools its cost a fair bit and this is just the prototype, got to get the HDPE next
  4. #144
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    957
    The thing is, as a one off, it is expensive, yes but you do end up reusing tools and components from one machine to the next as you go along. My Middleweight needs a new body but the parts from the current version can easily be transplanted so that will only cost me about £300 or 400 to get the parts and for me to machine them to make it work.
  5. #145
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte, Meteorite & Exabyte (FW)
    Location
    Birmingham
    Posts
    98
    Expenses wise, the worst part is always starting up. Once you're up & running it's not so bad & as Lucy said the vast majority of it can be reused & more expensive things like transmitters usually don't get damaged in combat. I've had a pretty rough run over the last couple of events (1 lipo fire, 1 other lipo die & multiple big hits from spinners) but once I've added it up it was less than half what I spent on the hotels for the events.
    James
    Team Phyte
  6. #146
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    72
    Yeah most of it is reusable thankfully! Just gotta price up the HDPE once got the design finalised.
    LiPo and chargers ordered and dispatched from hobby king, so think I have everything I need now
  7. #147
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    72
    Im sure i remembering reading it on here before but looked in many threads and cant find it.
    How do I work out what fuse size I need for this; https://hobbyking.com/en_us/turnigy-...ack-xt-90.html
  8. #148
    McMullet's Avatar
    Roboteer
    Status
    Offline
    Name
    Sam
    Robots
    Ensign Wedgeley Crusher (FW)
    Location
    Nottingham
    Posts
    103
    The max current from your battery is the capacity in Ah multiplied by the C rate (in this case you have a burst and continuous C rate, so use the lower of the two, i.e., the continuous rating). That's 4.0 Ah x 60 C = 240 A. The fuse must be less that that.
    However, with two drill motors and a linac you'll never get close to 240 A. So to protect your motors and ESCs you are probably better off with something around the 100 A mark, or even less. We have an 80 A fuse for a similar setup to yours.
  9. #149
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    957
    You work out the burst amperage of the battery and get a fuse below that amperage as per the rules:
    7.8.3 Fusing
    A fuse rated below the maximum burst discharge of the battery MUST be fitted. The maximum burst discharge current is calculated by multiplying the C rating by the capacity. E.g. 25C 2200mAh = 55 Amp
    So in that particular batteries case, it is 4 amps * 120C = 480amps (240amps constant). That, to me, sounds crazy and you'll likely never draw that much. I'd figure on it being a quarter of that, so 120amps but from experience, a 60 or 80amp fuse will be sufficient. I've yet to blow a 80A fuse in either my Featherweights or my Middleweights.
  10. #150
    McMullet's Avatar
    Roboteer
    Status
    Offline
    Name
    Sam
    Robots
    Location
    Nottingham
    Posts
    103
    Looks like we're largely in agreement here Lucy!
