Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: First Robot
  1. #11
  2. #12
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Shu!, The Honey Badger / FW: Azriel / MW: Jibril, Kaizen
    Location
    Somewhere on the Wirral
    Posts
    954
    So is this transmitter/receiver better?
    I don't use that particular variant so I can't comment but so long as the receiver failsafes to a safe/off position, it then comes down to what you want out of a transmitter.
    The battery and ESC linked to are those used in Shu! but they are on the weak side of what would be "normal" for a Beetleweight I think. Then again, the ESC is something I had laying around rather than "being ideal" and the battery choice was because I am a bit iffy about using LiPo batteries but slowly coming to use them.
    Ultimately, the parts you choose depends on what you want out of your robot. I'd again advise reading the build threads to see what folks are using so you know what works and what doesn't.
    I would just add that I understand that each ESC feeds power to the receiver. So if you have two, you are best to remove the middle red wire from the feed from one of those ESC to RX links.
    I found that I didn't need to do this in Shu! but did need to do this in The Honey Badger so depends on the implementation I would have thought.
    FW: Azriel
    MW: Jibril, Kaizen
  3. #13
    The servos I'm thinking to use are rated for 4.8V - 6V, but the battery I have looked at getting is 9.9V - does this mean being over volted, the servos will not work/burn out?
  4. #14
    Deathly Hallows's Avatar
    Roboteer
    Status
    Offline
    Name
    Simon Hallows
    Robots
    Beetleweight Evil K'Weevil Featherweight Alligrator concept
    Location
    Scotland
    Posts
    187
    Blog Entries
    12
    I bought a flysky i6 transmitter and receiver pair for around £30 on eBay. I got it because it was cheap, but so far I found it very capable. Multiple models supported, lots of channels and cheap receivers from Turnigy and Flysky you can get for £7-10 a pop.
  5. #15
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Pullover V2 (AW), Leopold (BW) & 1/3 of a Feather (Pushover)
    Location
    Gtr Manchester
    Posts
    130
    I too have a flysky fsi6, and it work ell with my other toys, I can recommend it as a starter, it even allows you t set your ow failsafe states of required.
    But then I'm the guy who built a machine that was totally incompatible with his tx...
