Results 11 to 20 of 21
Thread: DX6i mixing modes
  1. #11
    Hmm, I don't think I ever turned on Elevon mixing, but I think I have your solution. I believe it's because it's designed for mixing the elevons on an aircraft, so it tones the power down a bit.
  2. #12
  3. #13
    No problem, always happy to help!
  4. #14
    Nothing.
    Go to the endpoint settings and put aileron and elevator both on +125% and -125%
  5. #15
  6. #16
    switch out your esc's
  7. #17
  8. #18
  9. #19
    Pretty sure you need to do aile - elev and elev - aile, since you're basically mixing the action of one channel into another. Then work out your % values as needed to make the motors go the right way.
  10. #20
