Results 1 to 4 of 4
Thread: FP buffer tank thickness
    What is the recommended wall thickness of a full pressure CO2 buffer tank in aluminium?
    Approx outer diameter of 60mm if that helps.
    Thanks
    The wall of a 12oz paintball tank is on avarage 4mm.
    Thanks, thought it would be thicker than that.
    The smaller the diameter, the thinner the wall can be.
    A 2 kg fire-extinguisher can be up to 10mm. The bottom and neck are way thicker tough.
