Results 1 to 10 of 10
Thread: Brushless problem
    Are you sure there aren't any loose connections in your set up? with that amount of wiring and solder joints it could just be a duff connection.
    Your joints look like you have just taped them together... you must solder them to have a good enough connection. There isn't enough surface area to get the amount of power the motor needs through surface contact.
    Also check your batteries to see if they are charged, what their maximum output current is (Capacity x C Rating), and the minimum required voltage for your motor.
    It could be a loose connection then again it couldn't but it's best to cover all the bases. Does anything smell like it's burnt out/shorted? are all of your leads plugged in the right way? sounds silly but at the featherweight champs this year i had an rc lead plugged in backwards so it's best to check.
    *edit* Just noticed Alex's post and he's got a point, i presumed the wires were soldered but it does look like they're just taped in which case the connection might be broken.
    Max's Avatar
    Member
    What exactly is it doing? Is it rotating at all? Does it make a buzzing/noise when it turns on, are there any lights on the esc that light up?
    Are you sure the battery is fully charged, maybe the esc has a low voltage drop off? Are you sure the battery connectors are working properly?
