Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 71
Thread: "scratching the surface"
  1. #51
    Really the load of reverse forward switching is place mainly on the ESC's as a power spike is produced so im using these ESC's that should handle the loads. Also as Brushless motors are not too expensive It shouldn't be much of a problem having to replace them. Of course there is a possibility that it completely fails and then I have alternate options.
  2. #52
  3. #53
  4. #54
    Hi Jon,
    Like the CAD design,
    Just a quick question
    Do you know if that brushless motor reverses or not?
    Thanks
  5. #55
  6. #56
    Max's Avatar
    Member
    I believe all brushless motors reverse, it is only sme brushless speed controllers that don't reverse.
  7. #57
    Unless the brushless motor has a very rare way of windings on the stator, it can reverse. Just switch 2 of the wires. But, it's can't reverse when it's already running. It will just keep on running in the same direction.
    So, the bright spark that tries reversing a brushless motor with an extra H-bridge on 2 wires won't enjoy an instant reversing motor.
  8. #58
    so a translating spinner/melty brain cant reverse?
    couldn't it get stuck in the arena walls and floor without being able to reverse very well?
  9. #59
    Max's Avatar
    Member
    It doesn't matter if it is a melty brain robot as the motors always spin in one direction and just break at certain points in each spin to make it translate across the floor. It only needs a reverse if you want it to spin in the other direction
  10. #60
