Team Storm Write Up
But but but but but, the movment of the lift must have created some sort of weight un balanece, or kj of energy, or something that that that made steel avenger go out the arena. you you you still moved your weapon.
Mr Stu
-I know he was right before he even posted :sad:, still worth the work up tho :)
Team Storm Write Up
can i just point out that ed has been blurting all year long that storm 2 is itself a weapon with so much kj of force and all that so you did actually use a weapon to oota steel avenger.
oota without the use of a weapon....taken away
Team Storm Write Up
OOTA without the use of a weapon happens in every battle, when the robots drive/are taken out of the arena. :proud:
Team Storm Write Up
oh dear hear come the kids....
Team Storm Write Up
Run along spinner boy :)
Mr Stu
Team Storm Write Up
Team Storm Write Up
If Storm 2 rams into the side wall at full power, with another robot ramming it out of the arena. Will the forces involved damage the arena wall?
Dave, who was trying to be funny, but it didnt work in the last post.
Team Storm Write Up
ive seen Storm II in a fight with Das Gepack in the roaming robots arena in Holland. during a couple of slams by Storm II i saw the entire arena move 3 inches. Both Das Gepack and Storm II did this. If theyd put Tornado in aswell they could have moved the entire arena where they wanted to go. :)
But i saw no real damage on the wall though.
Team Storm Write Up
Leo, Storm IIs performance in Holland was nothing on what it was producing in Series 7 - things were a little more fine tuned by then !
I doubt the Roaming Robots arena in its current form would take Storm II without coming apart - but Jonno knows that and Im sure hell fix it.
We have indeed been asked by Mentorn to go easy on the arena with Storm II twice now, once asked to stay away from weak points, and once asked not to slam people into side walls so much.....
Ed
http://www.stormrobot.comhttp://www.stormrobot.com
Team Storm Write Up
shame WITW was concelled, cause that was going to be the last job of the event.
See how / if storm 2 can break the arena, what better way to improve things by having it broken.
Jonno
