That's the chap.
Does anyone happen to know the dimensions of the BotBitz 85A controller? I can't seem to find them on the website.
That's the chap.
Length: 65.5mm
Width: 34mm
Height: 17.5mm
here:
http://www.botbitz.com/manuals/TZ85A_Manual.pdf
Make it look the same but just power it off an actuator or pneumatics be much easier
Anyone recommend some good wheels? I found some castor wheels, but the thread diameter is larger than the diameter of the drill motor shaft...
All the electronics have arrived, as well as the springs! Now all I need is the steel for the baseplate, and I can begin.
Attachment 4191
Have a look at Robo challenge http://www.robochallenge.co.uk/Event...echanical.html
What are those motors?
Yes, the wheels with the nut inserts fit standard drill motors
