No probs. And Lewis (since he can't post on FRA at the mo') has also reserved a spot. So...1 spot left!
*looks around suspiciously, reserves spot*
Well, I guess that's all spots taken then, yes?
I will hold reserved spots until further notice. People who have currently reserved spots, but without any entries are:
Andrew Jackson
Tracy Farber
Martijn Benschop
Steven McGregor
Lewis Matthews
Jordan Brown
Jack Orr
Josh Noel
Badnik96
GF93
Mark Elam
In other words, there's a LOT of people who need to get their bots in! Come on, peeps!
I can confirm that I will enter Under Pressure and Sheer Heart Attack, be it in their current forms or new incarnations.
Working on 2 new bots, but in a pinch when a deadline draws near I can call on Plan B and enter 4 of my excisting bots.
I don't expect to get 'round designing a whole otherweight fleet and will probably enter realies in most otherweight spots.
That's fine Marti. :)
I will be checking for BIIBI bots soon.
Other three bots ARE on the way. Don't worry.
Not worrying. :)
Perhaps you should. :twisted:
*is worried about what sort of antweight Nick might come up with :uhoh:*
A few addenda to my entries:
> Broken Wings' stats are up in Alex's Oddbots thread, and may be found by means of this link. Although it 'walks', it's not a proper walker and more of a shuffler; however it weighs 100kg and is made of fibreglass so this should probably not be an issue.
> For people who are unaware of what Jigsaw is, I have derived some stats for it:
http://i267.photobucket.com/albums/i...y/IMGP0857.jpg
Name: Jigsaw V mk. III
Weight: ~150g (it depends whose scales are being used, which battery pack is in it, and possibly on the phases of the moon)
Dimensions: 145mm x 100mm x 40mm
Drive: 2 x 50:1 Pololu 'HP' gearmotors run at 7.4v from a 2 cell 135mah lithium polymer battery pack, driving two 32mm wheels with quite grippy rubber tyres.
Speed: Very fast, but top speed of about 1m/s hardly ever used as I tend to drive it in a far more controlled manner
Ground clearance: 0 at the front due to both the wedge, and then a strip of acetate (not pictured) which runs along the ground at the front of the wedge for maximum lowness - up to 10mm elsewhere
Chassis: Folded 1mm polycarbonate
Armour: 0.9mm grade 2 titanium, with the top windows being protected and strengthened with 0.3mm carbon fibre sheet
Weapon: Forward hinged flipper driven from a Hitec HS82MG servo, run at full battery voltage, which can lift up to 500g
Srimech: The flipper (for the purposes of fanfic, this works every time - in real life I need to fiddle with the transmitter settings more...)
Notes: Antweight World Series 33 champion (somehow!) and has placed quite highly in every AWS since. No sides...
Heavyweights:
Shego
All Bar One
Munch
Frustum
Antweight: Black box vaguely statted in the link
The rest shall follow.
