Your mechanical monsters could be used for utility, so much hard work you don't want to do, some chores, etc. Can that be done?
I could use Spinza to cut the grass! Hell, it has the blade off my lawnmower so it better!
I have use DB5 as a Axle stand for my car, a door stop (on the big door at Burgess Hill) and it is currently being used as a cradle for Asgard!
I could replace Drumroll's drum with one of those rotary lawnmower blades, although utterly pointless as we don't have any grass to cut :?
None of mine can be used it anything else as much as I would like them too :)
Big Nipper is good for popping tyres of wheel rims :)
Don't forget kan opener for the same job :)
Arcus is just about the right size to carry a can of Diet Coke on its top, which I have used it for ^^ it's actually better in that function than it is as a combat robot...
Arcus=awesomeness
Kookaburra used to be good at scaring my cats, also metanoia is a good bench!
Don't ask why, but ive been putting heavy objects in Spike the Avengers chassis and trying to bench press it.
It ended badly :rofl:
Ice skating? http://www.youtube.com/watch?v=5VUOp2C09Hs
I could always use The Steel Avenger's feather duster to do the cleaning :)
Sargent bash's flame thrower for de-icing?
Besides fighting each other? Well then you could flip ya sofa if you really felt like it. Or pull your car. Or destroy it. Remove undesired family members. :o
Practical uses? Well I guess the pulling power of a robot like Shunt or any Heavy really, could be useful.
tis is a movie of toby with some of the pneumatics from toxic in the garden,
i thought his toy missile needed a bit more power so i used co2, had to turn it down as on
fp they went into orbit ! no really they went right up and dissapeared within a few seconds !
lost 3 of them before i got the pressure right.
http://www.youtube.com/watch?v=Fk5vZN8Cinc
well not office work
http://www.youtube.com/watch?v=69OgXjPantc
