Where can I get astroflight motors in the UK?
I guess not easely.
Maybe that one or other of the more expensive RC shops has one or 2 burried under a ton of unsold expensive stuff, but that's about it.
How many - I have some lying around the garage somewhere
I'm just intrested in the price, if they are cheaper than speed 900's then I'm intreasted.
Also are they better then speed 900's?
-Ed do you live in the Ipswich area as we live near to Ipswich?
That's a little like asking I'd like a car . . . .
... is a Ferrari more than a Ford Fiesta.
A speed 900 and an Astroflight are very different beasts (although technically both PMDC motors) - Astroflights are probably circa £100 ish.
ohhh, bit expensive. I would really like some though!
If I can get the money I'll have them :)
Hey Ed could You also Pm a specs of them Please
If your using them for drive you will need a vantec to control them as they are thisty on power ( which arn't cheap), you can find the specs by putting astroflight cobalt motors into google..
The biggest difference between a speed 900 and an astroflight is weight .
The 900 is 310 gram heavier.
would the astroflights work on a victor 883?
also would they work on 24v?
the cobalt 40 is recommended 18-20 cells so will work fine on 24v. on the astroflight website it sys maximum continuous current is 35 amps for the cobalt 40 so victor 883s should work. they're going for $170 from the astroflight website although they occasionally come up on us ebay for cheaper.
http://www.astroflight.com/index.php?ma ... ucts_id=87
PITA and Pillow torque both use astroflights on victors and never had problems, although I'd me more inclined to get a pair of 900's :P
