robot market place large rc duel relay help
my negative port on my relay is playing up, sometimes it works but only when i push the wires down. the positive works fine which i dont understand. the wire is connected properly to the spade connection but its still dodgy and since i have little experience with them can anyone help me since im nearly clueless?
Re: robot market place large rc duel relay help
Robot market place large rc duel relay RCE225?
Pic of wiring ... as your description leaves a bit to be desired.
i cant really get pics since its not stored were i am. but its a prob with the relay which im not sure of
can anyone give me pointers with the limited info i am able to provide?
thats the thing, there aint anything visually wrong with it but it wont reverse the current
2 Attachment(s)
I don't understand your statement.
A drawing of the wiring would help.[attachment=1:3op79r3k]relay1.jpg[/attachment:3op79r3k][attachment=0:3op79r3k]relay2.jpg[/attachment:3op79r3k]
pick one or draw your own.
1 Attachment(s)
[attachment=0:335ixij7]relays.JPG[/attachment:335ixij7]
my set up is the first one and thats has all been wired up and is working but for some reason the negative has stopped working and i cant see why it could have
which is ...
http://www.fightingrobots.co.uk/foru...php?id=912&t=1
..there's two negatives.
So your post makes little sense to me.
The spade connectors going to the motor alternate between positive and negative depending on which relay is switched on.
1 Attachment(s)
[attachment=0:3i65o8rw]relays4P.JPG[/attachment:3i65o8rw]
Did it work before?
Is the relay clicking?
Is the LED responding?
Yes it has worked before and the relay is clicking, the light is also responding but I'm not getting any response from the actuator
have you put a meter on the output of the relay to see if there's power there, have you checked the actuator directly onto a battery?
