Can any one name a servo board that won't brake over time when used with a 6.0 volt battery and is not as big as the board in a s3003 servo
http://www.giantcod.co.uk/sg5010-towerp ... p-205.html
have used these in ants on 6v with much success and they're still going even work on 7.2v :)
they are a bit weird though. why not s3003?
yeh but only £4 :)
s3003s £3 delivered :proud:
still waiting for a link on that
Well in my ant most of the space is taken up with the axe and scoop so theres really not enough space for 3-servo boards of that size
you could buy the planet 5 rx/speed controller of archie and use a s3003 for the axe, alternatively you could looking into using a scorpion mini for the axe if you're still pushed for space
how is there not space mate? the servo boards are about a cm by a cm, not including leads. they will fit fine :)
not this one its 4cm by 2cm
oh, iknow those boards, get some hitecs then, they are not like that
