The tournament formerly known as FFW
Right guys, the FFW is changing to the ZFW. I should probably point out that my name will very shortly be changing, and that Zarte is my first name and short for Esforzarte... It makes more sense if you know the backstory :P
Although this is essentially a new tournament, the seedings will carry across from FFW.
The format in itself will be different as well.
This is a 72 robot tournament, however whereas in the past I've always felt the seeds don't get proper advantages, in this series they will (all 24 of them)
There will be 12 heats of 6.
The 4 non-seeded robots will go in 2 battles for the right to face a seed. The robot I deem more impressive will get the easier seed (so performing well as a non-seed does have its advantages too)
Normal stats will be required for 6 robots from 12 people with the weight limits as follows:
Wheeled//Shufflers - 100kg
Tracked - 110
Walkers - 160kg
Any other motivation - Ask if appropriate.
Please include 1 realie in your team. I can't work out seedings before all entries are in, however if you don't enter a likely seed, you will NOT be offered to replace it's rank with another machine.
The arena used will be the UKRW7 arena.
If any more info is needed, feel free to ask, but otherwise chaps, get entering :)
Re: The tournament formerly known as FFW
alright, 6 bots, I'm gonna start typing...
Sheer Heart Attack 2
Axe to Fall
Liar 2
Back to Rock III
Under Pressure
Bio-Hazard (realie)
I can copy the stats in here if you'd like to?
Nitro-Gene 5.0
Supersonic
Knyfe
Volcano
Blast
Storm 2 (realie)
Stats here: http://strickenone.proboards.com/index. ... =tivapours
Looking forward to this Matty, welcome back :proud:
Team Mechanical Menagerie
1: Compression
2: Equinox
3: Vertigo
4: V for Vendetta
5: Armageddon
6: Tough as Nails (realie)
1:
http://img.photobucket.com/albums/v2...ompression.jpg
COMPRESSION
BODY SHAPE: Low box with angled rear and sloped sides
WEIGHT: 100kg
DIMENSIONS (L X W X H): 85cm (90cm with wedge and claws) x 95cm (130cm with claws) x 25cm
COLOUR: Polished to perfection, the claws are gold with red tips
LOCOMOTION: 4 x 270mm go-kart style wheels with aluminium hubs and vulcanised tyres
GROUND CLEARANCE: 10mm, protected at the front and sides, 10mm at rear
SKIRTS: A 5mm hardox hinged wedge at the front (between the claws) that flops over when the robot is inverted.
DRIVE MOTORS: 2 x A28-400 magmotors run @ 24v
DRIVE BATTERIES: 4 x NiCad battlepacks running @ 24v in parallel
SPEED: Can reach 25mph to batter opponents around, but is kept to 15mph when driving around
TURNING CIRCLE: 0 metres
BODY ARMOUR: 3.2mm hardox monocoque for the most part, with 5mm hardox extra protection in key areas such as battery mounts
CHASSIS: 3.2mm hardox monocoque
WEAPON 1: The front horizontal Kan Opener-style crushing jaws are closed completely via a vivoil pump powered by a LEM-130 motor @ 36v, the hydraulics are at 3000psi giving 4.5 tonnes of crushing force between the tip, this is interchangeable for a pneumatic setup powered from a 3kg bottle and 2 x 100mm rams at 725 psi each. The claws themselves remain the same in both setups and are tungsten tipped with serrated edges
WEAPON 2: The hinged wedge between the claws beaches opponents with the Mute-style barbs it has so that the opponent can be pushed around while the claws keep hold, this is perfect for pitting robots because the wedge will flop over the edge of the pit so when the claws let go the opponent will fall straight in.
SRIMECH: Can run inverted
STRENGTHS: Powerful weaponry, can end battles in seconds due to grab and pit using the weapon synergy, fast, good armour
NOTES: Just a slight re-freshening, getting rid of the silly triangle shape, spikes and bosches. Known for a while as Compression 1.1, but I'm not keen on that name.
THEME SONG: Beast And The Harlot by Avenged Sevenfold
2:
EQUINOX
BODY SHAPE: Box with 30* wedge at the front and angled rear ala Tornado like >. Sides are 45* to deflect spinners.
WEIGHT: 100kg
DIMENSIONS (L X W X H): 95cm x 70cm x 9cm
COLOUR: Dark blue with yellow skirts and forks
LOCOMOTION: 4 x internal wheels, each is 80mm in diameter and has vulkalon tyres for grip. They are mounted on a slant ala Tazbot for extra control. Instead of one in each corner they are mounted at the rear and middle of the machine, with two ball castors in the two front corners. This gives very good manouevrability, allowing Equinox to really glide around the arena like Panic Attack.
GROUND CLEARANCE: 0 at the wedge, effectively 0 at sides and rear due to skirts, but 10mm behind them.
SKIRTS: 5mm grade 2 titanium skirts at the sides and rear, joined by 4mm hardox hinges to stop them breaking.
DRIVE MOTORS: 4 x A28-400 magmotors run @ 24v
DRIVE BATTERIES: 4 x NiCad battlepacks at 24v in parallel
SPEED: 15mph, designed to be very fluidly controlled
BODY ARMOUR: 6mm grade 5 titanium/vanadium 10% alloy monocoque. The removable panel is the top panel, but this is mounted on rubber bolts, rendering axes and hammers useless.
WEAPON 1: Running down the front wedge and flat along the floor are two 60cm long lifting forks, each powered by its own linear actuator, capable of rising to full height in 2 seconds, fast enough to be effective, but slow enough for controlled lifting.
WEAPON 2: Running along the top of the robot are two sets of Mute-style tungsten carbide barbs to trap opponents. Also hinged at the rear of the robot is a 95cm long clamping arm with a serrated tungsten tooth at the end of it, this is powered by an S28-400 magmotor @ 24v and is usually raised to vertical and then used to clamp opponents in place, can be used in unison with the lifting forks and barbs to good effect.
SRIMECH: The clamping arm can right the robot in 1 second, because it has a large hardox fin towards the rear half that allows it to self-right over the rear skirt.
STRENGTHS: Excellent manouevrability, controllability and pushing power, weapon synergy, tough armour
THEME SONG: Meet Me on the Equinox by Death Cab for Cutie
3:
http://i1106.photobucket.com/albums/...m/Vertigo1.jpg
http://i1106.photobucket.com/albums/...m/Vertigo2.jpg
VERTIGO
BODY SHAPE: Box with 60* wedge at front and angled rear ala Tornado. The sides are sloped at 45*
WEIGHT: 100kg
DIMENSIONS (L X W X H): 80cm x 75cm x 20cm
COLOUR: See CAD
LOCOMOTION: 4 x internal wheels, made of aluminium with unrethane tyres. Each is exposed from the top and bottom and is 22cm in diameter
GROUND CLEARANCE: 0 at the wedge, 8mm at sides and 10mm at rear
DRIVE MOTORS: 2 x A28-400 magmotors @ 24v
DRIVE BATTERIES: 4 x NiCad battlepacks @ 24v in parallel
SPEED: 18mph
BODY ARMOUR: 4mm hardox monocoque, flipper/top panel is
6mm.
CHASSIS: 4mm hardox monocoque. The removable panel is the top one.
WEAPON 1: The whole top panel is a full pressure flipper, powered by a 100mm ram @ 725psi from a 3kg co2 bottle, providing plenty of flips and a lot of power, similar power in fact to the modern Kronic the Wedgehog.
SRIMECH: The robot is invertible, but the flipper can be used to right it if needs be.
STRENGTHS: Powerful weaponry, tough armour
THEME SONG: Bodies by Drowning Pool
NOTES: Another robot designed primarily with ARC in mind, Vertigo was built to take advantage of the weapon/armour rule there, which would allow Vertigo to have a high powered flipper and very tough armour while not sacrificing much in terms of drive power. It surpassed all expectations, reaching the semi-finals and only losing to eventual champion Tank there. Again, thanks to Area51Escapee for this CAD :D
4:
V for Vendetta
WEIGHT: 100kg
DIMENSIONS (L X W X H): 80cm x 75cm x 30cm
COLOUR: Black with lightning stripes on the side and name written in white on the sides, rear and wedge
LOCOMOTION: 4 x internal wheels, each is 145mm in diameter and has vulkalon tyres for grip. They are mounted on a slant ala Tazbot for extra control. Instead of one in each corner they are mounted at the rear and middle of the machine, with two ball castors in the two front corners. This gives very good manouevrability, allowing Vengeance to really glide around the arena like Panic Attack.
SKIRTS: 5mm grade 2 titanium skirts at the sides and rear, joined by 4mm hardox hinges to stop them breaking and torsion sprung to stop them rising due to the imperfect arena floor.
DRIVE MOTORS: 2 x LEMCO-130 lynch motors running @ 48v
DRIVE BATTERIES: 4 x NiCad battlepacks at 12v in series to make 48v
SPEED: The motors are geared towards acceleration so it reaches its top speed of 25mph very quickly, but if neccessary it can keep speeds low for more control.
BODY ARMOUR: 6mm grade 5 titanium/vanadium 10% alloy all over
CHASSIS: There is a 5mm steel bar chassis, but this is mounted on the outside of the robot like an exo-skeleton. This prevents spinners from doing any damage at all and only unusually long axeheads will be able to reach the armour.
WEAPON 1: The front wedge and robot's speed combined make what is basically a flipper, so on high speed runs across the arena it can turn over opponents and depending on the angle of an attack may be able to propel an opponent over the fence.
WEAPON 2: The main weapon is hinged at the top of the front wedge, and is a 78cm long axe, with a serrated tungsten carbide spike on the top. This is powered by a 120mm x 100mm bore stroke ram at 725psi from a 3kg gas bottle. This provides a nice meaty hit from the 8kg axe and can fire about 15-20 times per bout.
SRIMECH: The axe can right the robot very quickly, and even if the axe is fired when the robot is flipped it can pull in and right the robot still
STRENGTHS: Powerful weaponry, decent drive, good armour for spinners
THEME SONG: Vendetta by Slipknot
5:
http://i415.photobucket.com/albums/p...Armageddon.jpg
ARMAGEDDON
BODY SHAPE: Basic box with front hinged wedges and rear battering ram
WEIGHT: 100kg
DIMENSIONS (L X W X H): 90cm x 80cm x 25cm
COLOUR: See CAD
LOCOMOTION: 4 x internal but invertible custom-built HDPE wheels 270mm in diameter with vulcanised tyres.
GROUND CLEARANCE: 10mm, this is protected on the front by the hinged wedges and on the sides by the skirts
DRIVE MOTORS: 2 x LEM-130 lynch motors @ 36v
DRIVE BATTERIES: 4 x 30cell 36v 3Ah Sanyo NiCad packs
SPEED: 18mph
BODY ARMOUR: 5mm hardox monocoque
CHASSIS: 5mm hardox monocoque
SKIRTS: 5mm grade 2 titanium, hinged wedges are 7mm of the same stuff
WEAPON 1: The set of 5 hinged wedges at the front of the robot are very effective at getting under other robots to help in pushing them around.
WEAPON 2: The battering ram at the rear of the robot is shock mounted and is made of 1cm think grade 2 titanium, so it will flex under pressure from spinners rather than being ripped off, like Behemoth's scoop
SRIMECH: Invertible, works just as well as upside down.
STRENGTHS: Strong and powerful
THEME SONG: I Don't Want to Miss a Thing by Aerosmith
NOTES: Originally crafted to take part in ARC: Aftermath, Armageddon was born out of a desire to have a simple wedge robot with no active weapons - yeah it's boring, but it's also damn effective. This was proved in its ARC debut, as it stormed through the main season with a 7-2 battle ratio before losing out in the quarter-finals. It returned to ARC the following season, but despite a successful main season run it failed to reach the quarter-finals and so made the transition to FRA combat, where it will hopefully prove equally successful. Kudos goes to Area51Escapee for the CAD :)
Looking forward to this :)
Fabulous guys, ta muchly.
Think I can find yours Martijn :)
You should hopefully be able to find my stats too Zarte ;P hope this all goes well.
Team Picus entries
Gabriel V
Eye of Ran*
Nidhogg*
No Consequences
Flirty Skirty (series 2)
Haardvark (series 2)
*use latest incarnation of these at the time signups close; EoR III is being worked on, Nidhogg's latest version might be done but there are obstacles (my endemic laziness) to both
Here I go. :)
Corona (some kind of seed, was The Epidemic a LOOOOONG time ago)
Wedginator X
Tira VI
Super Gore Eahta
Intriguality
Nemesis (Series 2)
link to all stats, barring the realie, can be found here.
Looks to be fun, Mr.... Z? :proud:
Ooooo, finally, a use for my gifty bot! 8D
Mobile Failure 2.5, V'ger, Bloody Frigid, Lime-y, SOTAR and.... Krayzzee Tokyo on top of Chaos 2. (Failing that, I'll be back with a actual real one later. XD)
All the ones that AREN'T real can be found over here!
Team ?¿?
1. Gehenna 2
2. Psychosis
3. Wedga Ennea
4. Axeon 4.0
5. Fissure
6. Gravity (Series 7)
Stats here: http://strickenone.proboards.com/index.cgi?board=ajhw
Good luck with this, Mr. Siempre. :)
Zarte, if it's not too much trouble, I'd like to replace Corona with its redesign:
http://teamzlayerz.proboards.com/index. ... =13&page=1
Mr McG has reserved a spot, and Kody that's fine as a very fine fine thing.
At last, entries! :P
TEAM BRAVEHEART
1. Wedge Devolution
2. Spin Dash Unleashed (replacing Metal Sonic Spin Dash)
3. Mornington Crescent (replacing Whirligig 4.0)
4. E Clawdius Unum (replacing Clawdius Decimus Murderous)
5. Traffic Warden (NEW)
6. Mega Hurts LT (RW7)
1. 1. Wedge Devolution
SHAPE- low wedge with sloped rear
COLOUR- sleek and shiny silver
WEIGHT- about 100kg
DIMENSIONS- 90cm X 75cm X 30cm
SPEED- 16mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
ARMOUR- 4mm Hardox
WHEELS- inside robot, 4-wheel drive
POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
NOTES- flashing red light on top of robot, flies Scotland flag
STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers )
PIC- http://img166.imageshack.us/img166/7555 ... ionza6.png
SHAPE- skirted box, with rounded sides and back.
COLOUR- dark blue bodywork, with red-and-white striped skirting.
WEIGHT- about 100kg
DIMENSIONS- 100cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
ARMOUR- 4mm Hardox
MOVEMENT- inner, 6WD
POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
NOTES- flies Scotland flag.
STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
PIC- http://img137.imageshack.us/img137/5359 ... sh6ta1.png
SHAPE- flat cylinder
COLOUR- white, with the London Underground sign for Mornington Crescent on the top and bottom
WEIGHT- approx 100kg
DIMENSIONS- 100cm X 20cm
SPEED- 12mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 8mm
ARMOUR- 3.5mm Hardox
MOVEMENT- 4 x inner wheels
POWER- 2 x S28-400 Magmotors, running at 24v
WEAPONS- Mornington Crescent is armed with not one, but TWO outer spinning rings, one on top of the other. The top ring spins anticlockwise, while the bottom ring spins clockwise. Each ring has four teeth and weighs about 10kg. The rings are powered by an LEM-130 running at 36v each and can reach speeds of 1500rpm. The two rings spinning in alternate directions should also help the robot be easier to drive - theoretically, anyway.
SRIMECH- invertible
NOTES- flies Scotland flag, thanks to Joey and Andy for helping with stats
STRENGTHS- two spinners for the price of one, nippy, manoueverable, tough, more controlled than regular ring spinners
WEAKNESSES- wheels open to axes and crushers, unpredictable bouncing?
PIC- http://img25.imageshack.us/img25/5661/m ... escent.bmp
4. E Clawdius Unum
SHAPE- skirted wedge with small box section and rounded back
COLOUR- deep green with red shield emblazoned on the wedge, depicting a gold lion with a crown
WEIGHT- about 100kg
DIMENSIONS- 95cm X 70cm X 40cm
SPEED- 14mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
ARMOUR- 4mm Hardox
POWER- 2 X S28-400 MagMotors
WEAPONS- The main weapon, as ever, is the hydraulic diamond-tipped crushing claw. It is powered by a Vivoil pump with an 80mm x 40mm ram, with a 2kg tank for storing the hydraulics. The claw runs at 3000psi and, aided by the diamond tip, should be able to leave plenty of holes in another robot.
The front wedge also features a Firestorm-style blade and two flat 'spears' to aid in getting under the opposition. The wedge itself is now home to several Mute-style barbs to help ensnare other robots.
SRIMECH- A rear-hinged pneumatic arm on either side, powered by a pair of linear actuators. The rounded rear also prevents the robot getting beached.
NOTES- flies the Scotland flag, thanks to AJ, et tu, Brute? written on the underbelly
STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fairly quick srimech
WEAKNESSES- so-so manoeuvrability
PIC- http://img137.imageshack.us/img137/1801 ... numor1.png
5. Traffic Warden
SHAPE- square bracket with rounded rear
COLOUR- black with a yellow stripe
WEIGHT- 100kg, I hope
DIMENSIONS- 95cm X 150cm X 25cm
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 10mm
ARMOUR- 4mm Grade 5 titanium
MOVEMENT- four inner wheels
POWER- 2 x Etek-RT motors, running at 48v and producing 38hp.
WEAPONS- A pair of horizontal hydraulic clamps within the middle of the machine. Each clamp is powered by an 80mm x 40mm ram operating at 3000psi, delivering up to 10 tonnes of crushing power. When an opponent slips into the middle, the clamps activate and hold them in place. Traffic Warden can then drag them around and shove them into the nearest arena hazard. Think of it as Huggy Bear on steroids.
SRIMECH- invertible, rounded rear should prevent it getting beached
NOTES- flies Scotland flag, super special awesome thanks to Daniel Stickler, Martijn and AJ for helping with the design
STRENGTHS- good traction, tough shell, fairly manoueverable, nippy, powerful grip
WEAKNESSES- untested weapon, exposed ground clearance
PIC- http://img381.imageshack.us/img381/1130 ... nalto6.png
Could i reserve a spot please?
Sorry guys, internet's been down. No problems Mr. Walsh.
Come on guys, there must be more of you!
Lian I need your entries.
I also need 2 more people. Please?
OK, as there seems to be no interest, and as Lian hasn't entered his machines, I'm going to change the format with 9 people entering 8 each, If the 9 of you who have entered could enter 2 more robots with at least one being a realie, it'd be much appreciated.
Thanks guys.
Re-posting :)
Heliosphere
Wedginator X
Seung Mina VI
Tira VI
Super Gore Eahta
Intriguality
Wharthog (Series 1 - http://www.youtube.com/watch?v=BYkIf2t_Jt8 )
Nemesis (Series 2)
There you go. :P
I should clarify, 1 of the extra 2 should be a realie :P So a minimum of 2 realies in total :P
Team Picus other entries, picked using a random number generator and the entry list of series 2
Pain
Cassius
http://i1006.photobucket.com/albums/.../exotherm2.jpg
http://i1006.photobucket.com/albums/..._2009/exy2.jpg
http://i1006.photobucket.com/albums/..._2009/exy3.jpg
Exotherm
BODY SHAPE: A bit like Nightmare, see picture
WEIGHT: 100kg
DIMENSIONS (L X W X H): 100cm x 71cm x 57cm (with disc)
COLOUR: Yellow and black, silver disc
LOCOMOTION: 2 x sturdy 7mm hardox wheels with vulcanised tyres, 400mm in diameter
GROUND CLEARANCE: 0 at the front hinged wedges and rear shocl-absorbing wedge, doesn't really have a ground clearance elsewhere due to the shape
SKIRTS: 2 x hinged wedges at the front
DRIVE MOTORS: 2 x A28-400 magmotors running at 24v
DRIVE BATTERIES: 4 x NiCad battlepacks running at 24v in parallel
SPEED: 20mph
BODY ARMOUR: There isn't really much armour, so where there is armour it's 6mm 10% titanium/vanadium alloy. The front wedges are made of 6mm hardox.
CHASSIS: Steel Ladder
WEAPONRY: A 500mm diameter vertical flywheel with curved blades that are part of the disc itself so they can't be ripped off. It can reach a top speed of 2500rpm in 2.5 seconds courtesy of 2 x A28-400 magmotors @ 24v, the disc itself is made of titanium, is 1cm thick and weighs 31kg. It spins upwards to flip as well as rip.
SRIMECH: Invertible, and the disc can rotate 10 degrees up and down so when flipped it can quickly and easily adjust so that the wheels touch the floor.
STRENGTHS: Hard to attack, damaging weaponry, good armour
NOTES: I was given this robot by Spatula over on ARC, as he no longer wishes to compete. It was originally a lightweight, but has now been scaled up by myself to compete both on the FRA and in the heavyweight division at ARC, where it managed a battle ratio of 4/5.
THEME SONG: Best of You by Foo Fighters
And for my other realie I'll take Behemoth if that's okay :)
If that's the case, my overall list of entries shall be
Nitro-Gene 5.0
Supersonic
Knyfe
Volcano
Blast
Harraz
Storm 2 (realie)
Tough As Nails (realie)
Hope this is all good :talker:
Here's my revised line-up:
Team ???
1. Gehenna 2
2. Psychosis
3. Wedga Ennea
4. Axeon 4.0
5. Fissure
6. Exertion II
7. Gravity (Series 7)
8. Steg-O-Saw-Us (Series 3)
5 people have put 8 in
3 have put 6 in
we need 1 to put 8 in and the other 3 to put their other 2 and we can have lift-off :)
I already picked TAN sorry Paul :>
It's true, he had :P Sorry Paul, well noticed Lewis.
In that case, make it Tornado. If that's been picked, make it Merlin (I assume you know that one) :talker:
alongside my 6 bots already entered, I shall give you Flick of the Wrist (whose stats can be found on ZED) and Overkill!
Zarte, I'd like to make more redesigns to my team, so if it's not too much trouble...
Seung Mina VII (replacing her VI version; is done)
Tira VII (same; is done)
Shadow Zone Forever More (will be done soon :) )
Thanks!
Add in Killotine: EVO (same as always) and Venus Fly Trap II for me, ta. :)
Venus Fly Trap II
SHAPE- box with wedges on all sides
COLOUR- green with ugly great mouth on top
WEIGHT- about 100kg, I hope.
DIMENSIONS- 95cm X 95cm X 20cm
SPEED- 12mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 10mm, though the wedges and spatulas should provide some extra protection
ARMOUR- 3.75mm Hardox
POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
WEAPONS- On either side of Venus Fly Trap II is what appear a rear-hinged flipper with a large spatula, covered in barbs. These are the 'jaws' and are powered by an 80mm x 120mm pneumatic ram each, running at 250psi. The idea is that an opponent is scooped up on top of the robot or gets stuck on one of the spatulas, the 'jaws' fire simultaneously and ensnare it like a real venus fly trap.
SRIMECH- A rear-hinged arm on top. Powered by a separate S28-400 MagMotor geared 250:1 for quick and easy self-righting.
NOTES- flies Scotland flag, thanks to Joey for aiding in the design
STRENGTHS- Unique weaponry, powerful, well-protected, nimble
PIC- http://img394.imageshack.us/img394/7102 ... trapii.png
Two realies now, Steve. ;)
Bleh. Brain no thinky so good.
Swap out Killotine with the latest Terrorhurtz then, please, Mr Z.
That's cool :)
Tracy's last 2 needed and 1 more entry pleeeeeease.
Oh darn it, my internet is playing up all the time, hopefully its not too late
Sauron
Weight: 80-100kg, depending on the setup used.
Shape: The robot without any setup on it is shaped like Tornado, back when they didn't have the interchangeable weapons.
Colour: Black, with a picture of The One Ring on top.
Dimensions: 85cm x 75cm x 25cm
Drive: 4x S28-400 Magmotors, powered by 3x 25.9v 5000mAh LiPo battery packs.
Locomotion: 4 Goodyear go-kart wheels.
Armour: 4mm titanium
Speed: 15mph
Ground Clearance: 0mm at sides and back due to skirts. 5mm without skirts. The front ground clearance varies with the setups, but unless otherwise noted is 5mm.
Turning Circle: 0m
Weapon: 7 different interchangeable setups.
1: A 20kg hardox scoop, designed to kill spinners. 0mm ground clearance at the front.
2: A 10kg hardox scoop like the one above, but with a Pneumatic axe powered by 2 2kg Co2 tanks using a 3kg Terrorhurtz-style axehead and a 100mm stroke 180mm ram at 200psi. It can strike with around 600kg of force, and can be recessed into the body of the robot, keeping it invertible. 0mm ground clearance at the front.
3: A set of Panic Attack-style lifting forks, powered by a 50:1 reduced 25.9v S28-400 Magmotor. It can lift 250kg. 0mm ground clearance under the forks.
4: A Behemoth-style lifting scoop, using a 75mm bore 100mm stroke ram and a 2kg Co2 tank. It can flip 400kg and lift 500kg. 0mm ground clearance at the front.
5: A 4-bar Biohazard-style lifter, using a geared-down S28-400 Magmotor. It can lift 300kg. 0mm ground clearance at the front.
6: A 20kg hardox spinning bar on top of the robot, powered by a 25.9v S28-400 Magmotor at 4000rpm. It puts out 156kj. Another skirt is added to the front of the robot. 0mm ground clearance at the front.
7: LIke setup 6, but without the bar. 0mm ground clearance all around due to skirts.
Srimech: Invertible in all setups except for setup 6. Setups 2, 4, and 5 can all self-right the robot.
Strengths: 7 WEAPON SETUPS!!!
Weaknesses: There has to be at least 1 problem with each setup.
Bio: The first Team Blood Mages robot with interchangeable weaponry. Will it work? We'll see...
Win/Loss Ratio: N/A
Empty Inside
Weight: 100kg
Shape: Storm 2, a box with wedges on the front and sides, with a rounded back
Colour: Camo, with shades of red
Dimensions: Height 25cm Width: 65cm Length: 105cm
Drive: 2x 24v S28-400 Magmotors, powered by 5x 3000mAh NiCad Battlepacks.
Locomotion: 2 Storm 2 style wheels, like Merlin, are positioned at the front
Armour: 6mm titanium
Speed: 12mph
Ground Clearance: 0mm, under the flipper and 0mm elsewhere except the back thanks to Titanium skirting, 5mm with out skirts though
Weapon:An Achilles style rear-hinged flipper,which is attached from the back and goes all the way down the front to the bottom of the wedge. powered by a 750pi 2.5kg C02 tank, with 2 70mm bore 300mm stroke rams which power the flipper. Can flip up to 300kg and can lift up to 400kg, much like Achilles itself, it is a full body flipper, which means that the front wedge and the top, fire towards the back of the robot, the sides do not flip up though
Scrimech: The flipper of course
Strength: Powerful weapon
Weakness: Dunno
BIO: Another new design for 2011
Win/loss ratio: N/A
rated I for: This bot is in the hands of an Idiot
http://s276.photobucket.com/albums/kk11 ... icDoom.jpg
Metallic Doom
Weight: 150kg
Shape: A low box ala Drillzilla.
Colour: The left half is red, while the right half is black.
Dimensions: 107cm x 95cm x 17cm
Drive: 2 36.3v LEM-130 motors powered by 11x A123 Battlepacks
Locomotion: 2 Drillzilla-style shuffling feet, giving Metallic Doom good traction and pushing ability.
Armour: 3.25mm hardox
Speed: 20mph
Ground Clearance: 0mm at the front, 5mm elsewhere.
Turning Circle: 0m
Weapon: A pair of horizontal crushing jaws, each which looks like the one used by Suicidal Tendencies, powered by a Vivoil Pump and LEM-130. Each jaw has a 2:1 ratio giving it 9 tonnes at the ram and 4.5 tonnes at the tip.
Srimech: Invertible.
Strengths: Nothing wrong overall.
Weaknesses: Average everything.
Bio: The 6th Team Blood Mages(a subsidiary of Death Robotics) creation is rather average overall...
Win/Loss Ratio: N/A
EDIT: Thanks to mr Kody for the excellente CAD
The Servant's Assistant
Weight: 100kg
Shape: Box with a wedge on the front ala Mortis
Colour: Behemoth style yellow and black stripes
Dimensions: 0.36m x 0.76m x 0.91m
Drive: 4x 24v S28-400 Magmotors, powered by 5x 3000mAh NiCad Battlepacks
Locomotion: 6 internally mounted solid rubber wheels.
Armour: 6mm thick Titanium all over. 3mm Polycarbonate baseplate
Speed: Limited to 18 mph. Can reach 40mph.
Turning Circle: Zilch
Ground Clearance: 0mm at the front. 8mm elsewhere
Weapons: A full-pressure rear-hinged Co2 flipper which starts off from the back of the robot and finishes at the bottom of the front wedge powered by a fire extinguisher using a 70mm bore 100mm stroke ram. It can flip 500kg.
Srimech: The flipper of course. Hubs on the sides to stop it being stranded
Strenghs: Fast despite speed cap. Good flipper
Weakness: Not sure
Bio: The Servant takes on a new shape and armour. Will do proud. Or will it flop. Only time will tell
Win/Loss Ratio: N/A
Rest to Follow, if im still allowed into this. Sorry guys
Me and Joey are helping Tracy with a new vapourbot for this. :) As for another realie, that's her problem. :P
Lian that's fine. Please try and do it fairly soon though as I'm itching to start :P
Will do mate, im at my nans this weekend (Infact im at her house now) so it should be done in the next day or 2
Shadow Zone Forevermore is now up on my forum, let's see how bad it does :P
Heres my other 4
Nurse Pain
Weight: 150kg
Shape: Son of Whyachi (Battlebots 3.0)
Colour: The chassis is green, the weapon is black, and the bracing rods are blue.
Dimensions: 110cm x 80cm x 30cm
Drive: 2 C40-300 Magmotors at 36.3 volts, geared 4.5:1, powered by 11 M1 A123 Li-Ion cells.
Locomotion: 2 Drillzilla-style shuffling feet.
Armour: 10mm hardox for the tribar, and 3mm titanium for the main body.
Speed: 12mph
Ground Clearance: 1mm all around due to the hammers almost touching the ground. 5mm under the body of the robot.
Turning Circle: Zero.
Weapons: The weapon is a deadly 21kg Son of Whyachi-style tribar powered by 2 36.3v LEM-130 motors at 4000rpm. Each end of the tribar has a 3kg Hardox hammerhead attached to it. It can put out 277.5kj. It also has bracing rods that are part of the tribar, and therefore give the tribar the full 21kg of weight.
Srimech: None
Strength: Absolutely deadly. Can kill almost anything.
Weakness: No srimech, but that won't matter.
Bio: Nurse Pain has no shockproofing. Basicaly its a bot for laughs and comedic perpouses
Win/Loss Ratio: N/A
Druid 2.0
Weight: 100kg
Shape: Reptirron the 2nd (S6)
Colour: Black on the right-hand side. Gold on the left.
Dimensions: 82cm x 90cm x 60cm
Drive: 4x 24v S28-400 Magmotors, powered by 4x 3000mAh NiCad Battlepacks
Locomotion: 4 internally mounted Biohazrd-style wheels.
Armour: 3mm Hardox
Speed: 12mph
Ground Clearance: 0mm at front. 9mm elsewhere.
Turning Circle: 0m
Weapon: The weapon is a rear-hinged flipper, powered by 2 2kg Co2 tanks at 750psi via a 100mm bore 150mm stroke ram. It can lift 800kg, and can flip 500kg.
Srimech: The flipper can self-right it.
Strengths: Tough, decent flipper.
Weaknesses: Previous incarnation had a habit of going out of control.
Bio: A slower, but tougher incarnation of Druid.
Win/Loss Ratio: N/A
For the realies, i'll have Slicer (Dutch Robot wars champ) and Tsunami
