got some teathing problems, anyone any help?
hi all
with my electrics today, im having a few issues
first, on channels 2 and 3 of my giantcod rc gear, with both motos plugged im, only one will resopond to the RC commands, the other just stays running yet if they go into channels 1 and 4, they run fine, but that involves them running of separate sticks
i need the left stick for my actuator and need both motors to drive on the right stick, anyone got any ways how i can achieve this and counter the issues im having?
Re: got some teathing problems, anyone any help?
What ESC's is it you're using again?
electonize 15a with 25a fuses :)
I can't find it on a quick search, but does the manual tell you which channel does what? Is it the same as Spektrum for example?
i didnt get one with it :)
channels 2 and 3 worked for drive for me in my last bot and i used the exact same set up but they just wont work in this one
ch1 and 2 is drive, 3 is the throttle
right, sorted that, but my actuator is acting up
the relay is on, its showing that its active, yet the actuator does nothing. i texted it on a 12v drill battery and that also did nothing, but im not sure if the battery is dead
Maybe it doesn't have its phone on it? :lol:
hello IT, have you tried turning it off and on again
I'll be annoyed if he doesn't :lol:
Has anyone got an idea of how I can test it with spade connectors on it?
touch the spade connectors to terminals of a battery
