can u use the servo micro switch esc ? like on martsards video
Yes, I used it but you need a failsafe.
is that in the radio gear?
depends what your using
how could u do it else were?
plug in fail safe.
and the removable link can it be under a hinged flap or must it be on show?
It can be under a hinged flap, but you must be able to access it without the use of tools. So if you can just lift the hinged flap up with your fingers, it's fine; if you have to use a screwdriver to undo a bolt or screw to lift it up, it's a no-no.
instead of a hinge maybe use a stiff bolt that attaches the cover this can be rotated out the way to show the link
or get a magnet so it stays down but u can lift it up :)
or use strong velcro
