What do people reckon is better for a 4 wheel drive 'bot?
Must admit I like the invert switch in the scorpion!
scorpion xl wouldn't work as it's only 12.5 amps each channel. go for electronize 30 amps. sabertooth 2x25 or scorpion xxl
Will the electronize 15a with a bec be able to power a single drill motor? For a feather.
should work with a 12v drill motor, many robots use this combo with sucess
For drive I liked the XL running 2 drill motors on the front half of my bot but the electronize will do the job too, and did do on the back half of my feather. That was on 19.2v so 12v should be no problem.
Will the 15a electronize work with a 18.4v lipo?
Don't see why not.
me neither
The Electronize's are seriously tough. They can easily handle a 12v motor.
Tough they are, I set one on fire during a battle and it carried on working fine afterwards.
yep, much tougher than sabretooths. the one in bulldozer (henrys 4wd rambot) blew up on saturday and large amounts of purple smoke came out :crazy: it's now running on 2, 30 amp electronizes :)
thanks for the in put guys.
