I need to buy a good battery and I have my eyes set on the one used in ant awe 6, I am looking for that battery and a charger for it.
probavly a lipo then
Hi,
I built Ant Awe 6 and it uses a 180mAh, 2 cell Lipo. I got mine from http://www.micronradiocontrol.co.uk but they don't seem to have the exact one which I use any more but this is the nearest one to it which they sell. http://micronradiocontrol.co.uk/lipo_efl.html (the second one)
As for the charger I use the Blue Arrow 2S/3S LiPo Charger (150mA - 550mA) which can be found here http://micronradiocontrol.co.uk/charger.html
Hope this helps
some chargers require a power supply (12v around 4 ah) to charge
Thanks for that I have now found with that info a similar lipo
2 question
Last time I use a duracell 9v battery and I had to build a power supply for it
will I have to with 7.4v
Will this charger do for it
http://www.art-tech.com/english/Article ... icleID=163
http://www.rcgraveyard.co.uk/losi-micro ... s-94-p.asp
Slight issue is that charger has a MINIUM setting to charge at 0.3A (300mA), which is too high for your 180mA lipos. No battery should ever be charged at over their capacity rating.
I would personally recommend a Pro Peak Quattro Plus. I've been using the original for 4 years now, never have a problem. The plus has the advantage because it has a built in mains plug, mine has a seperate 12v power supply.
BTW, when you said you had to build a power supply for a 9V battery, I'm not sure I follow.
Thanks I mean 9 volts was a too high voltage for my servo. Is 7.4 volts going to break them seeing as most servos have a voltage rating of 4.4-6 volts
yep, you need a regulator
It depends what servo you're using. HPXF's are tolerant of 7.4v, so are ome of the larger servos. HS82-MG can handle it when its used for a weapon, no good for a drive, but as a rule, servos prefer 6v.
The problem for me is I don't have enough money for a fancy charger I just ask that anyone could give me suggestions as to the cheapest charger for that battery please. Would this do http://micronradiocontrol.co.uk/charger.html the blue arrow charger on this page and does it connect to a wall socket. Help would be great.
pro peak quattro plus. done.
I happen to have a JP charger and power supply (bit overkill for it, but meh) that I am willing to let you have for free, just to help get you started. Its been used but its all fine.
I am envious of your generosity but I have my mind set on buying the pro peak plus charger. However I am confused because I am not sure wether it will charge this http://www.rcgraveyard.co.uk/losi-micro ... s-94-p.asp and and if it has a wall plug.
The Pro-peak plus will do those batteries fine, but you may not be able to balance the cells, but TBH I've been using LIPOS for a while with that charger and no balancing, never had a problem.
I am glad to hear that but is the connector suitable
just use a jst and you will be fine, i advis the hyperion 180mah lipos, basicly the same but without balancing leads.
Yes, its got a red JST connector that matches with the ones on almost all lipos (including yours)
Where can I buy that charger it's not in stock anywhere
just wait :lol: i got mine from brentford model centre because they had free postage
ok thanks will this have a wall connection i am concerned that it is not the same http://www.elitemodelsonline.co.uk/Prod ... o-Charger-
Thats an original Pro-peak quattro, the plus version has the mains plug, that one runs from a 12v supply. I use old PC power supplies for mine, output between 11 and 15v works.
