Jonny's bonza bargain shed clearance sale!
hi, having a bit of a clearout and have lots for sale:
1st items: 4 x 12v 10 amp SLA's all had about 2 cycles and are in very good condition
2nd items: 2x fracmo wheelchair motors+gearboxes including wheels. these motors give 10mph speed with supplied wheels. unfortunately i've lost 1 of the m20 nuts that holds 1 of thee wheels on so you'll have to find a replacement-ebay?
3rd item: 0-10 bar input 0-10 bar output regulator with 1/4 ports + 1/8th gauge ports. i'll chuck in a pair of gauges aswel
4th items: 2x 2kg grey co2 bottles with screw valve. unused still with safety caps!
5th item: antweight brushless setup (esc and motor)
6th items: 2x 50:1 high power gearmotors + servo boards
that's it for now! pictures available on request :) :crazy:
Re: Jonny's bonza bargain shed clearance sale!
how much for the gearmotors?
dunno, make me an offer. do you want the servo boards aswell?
yes please are the mounts for sale as well, say £25, £27 with mounts and screws.
ok, i'll have to have a dig about as at the moment i can only find 1 mount
What's the brushless setup like?
it's a 20 amp (i think) blue unbranded esc and this motor: http://www.giantcod.co.uk/1806n-2100kv- ... 405248.htm
Please excuse the lack of knowledge Jonny, Would those batteries powering those wheelchair motors be enough to power a heavyweight?
i believe so, also i forgot to mention the wheelchair motors are 24v.
harry, i've found the other motor mount now. do you want the stuff tomorrow?
yes please. joey the brushless esc is and 18 amp giant cod one worth about £10 (i gave it to jonny way back)
Nice one, its wheelchair motors we're using at the minute but they are both ornaments with the only use being holding the wheels on to the robot. How much would you reckon for the motors and batteries?
how about £85? and i'll bung in a charger for the sla's aswell if you want (although i'm not sure if the charger works)
Sounds good to me, the charger would be helpful too cheers.
Hi Jonny, I'm interested in the two 2kg CO2 bttles, how much do you want for the pair?
Mike.
pete has enquired about them so i'll let him have first refusal but i would be looking for £70 for the pair posted.
Hi again, OK, If Pete doesn't want them (or just one) consider them (it!) sold.
Thanks, Mike.
hi, pete changed his mind so they're available again. send me a pm if you're still interested :)
Everything arrived today Jonny, cheers :-D
NEW ITEMS!!!:
4x bosch 400's, 3 of these are perfect working order and and spin both ways at the same speed, is missing 2 magnets and some magnet holders.-£60 the lot
8x 160mm dia 25mm width . 20mm bore with bearing -£3.50 each
if you're interested in the following items make me an offer
e-flite 650mah lipo balance charger for 2/3 cell lipos + 1.5a 12v supply. bought a pro peak quattro so i don't need this one anymore-
brand new pack of pointed weller soldering iron tips. i don't currently have a soldering iron and will probably get an antex
0-10 bar input, 0-7 bar output technobots pressure regulator with 1/4 ports, 2 1/8 guage ports. i'll chuck in a 0-20 bar guage aswell
bag of push fits/thread adapters etc
I can bring any of these items to burgess hill or guildford, pictures to come! :)
actually have 11 of the 160mm dia wheels :) will sell the lot for £30
18, 4 ah nicad cells- £1 each or all for £15.
