i would like to try and get one please does any body have a spare you know the 150kg ones
thanx
thanx
http://cgi.ebay.co.uk/scissor-lift-tabl ... 230df7a74c
Be quick learo before they go ......
or this one john ......
http://cgi.ebay.co.uk/Motorcycle-Americ ... 3f04335b27
dont like thw rusty one but just trying to find out what the red moter bike one weighs
thanx pete
Well if you don't like the rust on the you could get one from here http://www.slingsby.com/c-1180-mobile-l ... ngsby.aspxQuote:
Originally Posted by beast
Machine Mart do them http://www.machinemart.co.uk/shop/produ ... -equipment
bit dear them :(
or this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Make one? A couple of electric car scissor jacks bolted to a wheeled base and lifting surface? Okay it would need battery power, but no shortage of that at events :)
:idea: how about just making a trolley the same height as the arena, so just push on and off ?
cheap as chips !
It's getting it in the car after is a problem
The yellow one I made for Cherub comes apart in four pieces and fits in the gaps between the other bits in the car/van
is there any cheap way to travel with a robot
Trains?
in my case thats good thinking :)
walk :rofl:
O COME ON :roll:
if its a hw sit on your robot and drive it
:roll:
any way im still after one
any one getting rid of theres ?
my ebay i can only see new ones :(
Johny had a actuator for sale
build one from that
I don't see the problem with a new one.
This one is only £161, brandnew.
thats quite good but whats the del
i carnt read dutch ahhhh
I'm not shabby in English, but this sounds more like pidgin or chinglish. Care to translate?Quote:
I know, but ever heard of Babelfish?Quote:
I carnt read dutch ahhhh
I get this
Technical data of the HBM 150 kilogrammes Verrijdbarework/Heftafel:
Maximum capacity: 150 kilogrammes.
Dimensions of the hefplatform: 700x450x35 mm.
Minimum altitude: 255 mm.
Maximum altitude: 740 mm.
Diameter of the wheels: 100 mm. Own weight: Approximately 44 kilogrammes.
Provided with 2 zwenkwielen including brake.
Packing dimensions: 82x48x26,5 cm.
Very robust implementation!!
with my own refinement.
Technical data of the HBM 150 kilogram work/lift table:
Maximum capacity: 150 kilogram.
Dimensions of the hydraulic lifting table: 700x450x35 mm.
Lowest position 255mm.
Max height: 740 mm.
Wheel diameter: 100 mm.
Own weight: Approximately 44 kilogram.
Provided with 2 brake swivel wheels.
Very solid build.
On another note, we have the 300 kg version, and we changed the el cheapo Chink wheels to 125mm Priory castor wheels. Still very happy about it.
John
Same as Clives, folds up as well so for £161 I would buy it.
Trev
i said whats the DEL (delivery ?)
Delivery.
Probably a lot. After all, it's 44 kg that has to be shipped from The Netherlands.
On the other hand, it's a trip to the candystore if you ever come over.
www.buitelaar.nl
Open it with Google Translate to make life easier.
Keep checking ebay, i just got one for £30 and was only a few miles away
just bidding on one been looking every day
walsall £25.oo on ebay john
gone up to £45 will bid last min lol
Did you win it then ?
8pm ish tonight why do u have one ?
no, but £45 is a great price for one !
owww its up to £71 :P
nope not won £124 it went for
