Can someone post me a link for a 4.6v receiver battery? Thanks
http://cgi.ebay.co.uk/RX-Pack-4-8v-NEW- ... 335f36a0b6
http://www.overlander.co.uk/batteries-c ... ml?cat=121
Try 4.8v receiver batteryQuote:
http://tinyurl.com/66b4f6o
Originally Posted by woody
Wierd link !! 8)
any local model shop will sell them. What speedos do you have, most fw ones have BECs.
Alan is correct .Quote:
Originally Posted by blazerbotics
Matt you said that this was your intended setup.
http://www.fightingrobots.co.uk/foru...ile.php?id=700
If so you do NOT require a receiver battery.
Cheers Woody
i followed your model woddy down to the letter and it just did not work.
i think the orange and red wires do something but i cant find what
When joined they turn on the BEC that is inside the electronize controller.
and that does not have to be connected to anything? it can just be loose?
i wired it all up in parallel and connected the esc's to the reciever and there was just no power going to the esc's or anything
Solder the orange and red wires together ...join them.
This switches ON the BEC
Loose ...not joined ...the BEC is OFF
If you attached a switch to the 2 wires you could turn the BEC on/off
they are joined but only by a twist connecting for now till i have got it all right and working
