Hi All,
We recently got to the stage of having a rolling chassis, so fired it up to find the robot incredibly sluggish, so much so that powering both motors simultaneously brought the robot to a stop!
We have 2 12v drill motors, 2 15amp electronize ESC (2nd hand) and 2 Ni-cad battery packs 8.4v each (7 cells) when charged holding about 9.5v wired in series.
The ESC arn't quite right, the BEC's are out putting the full 18v, and despite taking them apart I can't see why. While running the robot I measured the voltages are certain stages. From the batteries its at the full 18v, but the motors are only getting 5v, tops!
The ESC are turned all the way up on the speed control and the wiring is sound.
The cells are those from the drills we got the motors, so they-re are not the best, but this seems like an extreme voltage drop. Anyone got any ideas as to what is going on?
I'm going to try it in the next few days with some Ni-mh hobby packs we have to see if that makes a difference and eliminate whether it is the ESC that are playing up or the batteries.
On a final note anyone got a good source where you can by ni-mh cells from? I can't find any.
Thanks!
