disassembled four of them now. 3 of them i cant turn by hand but 1 i can? does this mean theres something wrong with this individual motor/gearbox unit?
bought another drill, exact same problem? i took it apart same way as the others (remove everything, ball bearings etc) and i can easily just hold it and it wont spin. any advice?
worked it out! ordered a set of grub screws!
OR A O-RING
As in this 'hack'?... http://www.wa4dsy.net/robot/drill-motor-hackQuote:
Originally Posted by Thunder arrow
yep thats all i did :proud:
and they all work fine
out of interest where did you get the o rings from?
Well I got them from b and q
but homebase proberly do them too
theo
B and Q?
...I just spent 30 minutes looking for o rings on the internet. I cannot believe I forgot that place :lol:
Lol I do that all the time :rofl:
Can someone please talk me through the grub screw method? I understand the threading , etc but I'm confused as to how deep the screws are going and if they are meant to touch the notches on the ring or the ring itself? I tried the o ring and it snapped one of the bolt holes on the motor mounting!
The grub screws sit in the notches.
As in between the raised points on the ring gear? So it basically stops the whole ring gear rotating yeah?
correct 2 per motor is best don't go to far otherwise you will lock up the gearbox
Would you say putting the screws either adjacent or opposite is best?
Another SBS... http://www.robowars.org/wikka/DrillHacking101
Would this method not leave an amount of play in the gearbox?
must admit i always have drilled and tapped a 5mm and used grub screw but this should work quite good (may try it next time)
I just take off the chuck but leave the clutch in place. Works fine.
Just grub screwed my motors. Seems to have worked a treat! Threw loads of grease in there as well for good measure!
