Re: batterys and pnumatics
Lead acid are good if you have more money NiMh are better you can also use LiPo's.You'll want a 14v and around 3000mah battery, technobots sell lead acid and car dealers sell them to.If you want NiMh the robo market place do design-a-pack or go to overlander batteries as they are good.
i think i will use the batterys i have now for my 45mph :!: :!: rc car :proud:....
intill i have some more money :lame:
there only 8.4v but 4500mah which is good
i think i am going to get a co2 tank from...
http://www.amazon.co.uk/approved-20oz-C ... 149&sr=1-5
and most of the other stuff apart from a valve (reg, a valve to let psi out, and stuff like that from...
http://www.technobotsonline.com/
and a 5/2 valve from ebay
but where can i get a double acting cylinder :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!: :!:
THEO
jonno can get the co2 tanks most people use then you know its correct etc
i dont know alot about flippers etc but you can get the rams from ebay
Ok but if it is more I am going to go with amazon (or I will nick a fire exthingy :lol:
what is his username :!: ( porbs seen him before but bad with names)
whats jonno username?
and whats the best type of welder tig, mig or what??? (lots of weird names)
theo
His username is roamingrobots.
Might be best to email though - email can be found on http://roamingrobots.co.uk/?pages=contact
thanks :roll:
and what is the best thing to weld aluminum tig, mig or what (weird names)
Theo
hate to say it but if you don't know the difference between tig and mig then I wouldn't start trying to weld aluminium. Get a simple arc welder for around 50 quid and start on steel. Much easier to pick up the basics of welding.
i know what mig is and tig (mig is gas)
and my dad is buying the welder :D
and i was just woundering what is the best type of welder to buy
theo
Ironically enough with that comment you have shown that you don't know the difference. Both Tig and Mig processes use gas. Each differs with how the filler material is added to the weld. :crazy:
With regards to the best welder Tig is the prefered method
http://www.mig-welding.co.uk/aluminium-welding.htm
That page shows quite nicely the difference in quality of welds with both techniques. Problem with Tig is that the machines can be more expensive than mig.
ok :oops:
where is a good place to get a mig welder :?: :?: :?: :?: :?: :?: :?: :?: :?: :?:
theo
is this battery good!!!
http://store.modelpower.co.uk/3s-2200ma ... 1330-p.asp
and where can u get a cheap mig welder
Theo
I'd highly recommend staying away from lipo batteries until you are more familiar with bots. Nimh far more suitable.
Check out ebay for a welder
because they go caboom.....
yes i no i have 3 for my car
do u know where to get some good cheap NiMH batterys
Ebay is a pain for finding things.
I searched for cigarette lighters and got 15,000 matches.
I'll get my coat
so do u know where to get some good cheap NiMH batterys :twisted:
I buy my Nimh packs from Vapextech through their eBay store here:
http://stores.ebay.co.uk/Vapextech-Batt ... d-Chargers
is this battery(s) good
http://cgi.ebay.co.uk/12v-NiMH-3700mAh- ... 563e83073a
http://cgi.ebay.co.uk/12v-NiMH-3300mAh- ... 3353c52b76
for a 14.4v motor
theo
yup, either one of those battery packs will happily power a featherweight rammer for a good 10 minutes at least, pop an electric weapon on and the time will drop but it won't be a problem to last a 3 minute fight :)
hi thx
i will prob buy 2 (what 1 will depend on money :cry: )
Theo
back to welders, you can get gassless mig welders which means you dont need gas
Poking about on the mig welding forum I was advised that gasless was a bit messy and that I should go for gas which ended up being a bit more then i really wanted to pay, although im not sure they got the message that it was likely to be attacked by all varieties of weapons so didnt really matter too much about neatness.
Im planning on going to night classes to learn to weld soon though so hopefully I will have more of an idea after Ive done that
thx for the idea for a gasless one but there not as easy and messy as a gas mig welder and hopefully i will have 1 tomorrow :D ( my dad is buying it :proud: )
Theo
