Tron
I couldn't see a thread for Tron any more so I decided to start another.
Tron will be going to the UK champs, I am thinking of fitting an anti spinner barrier device on the front, any ideas? Or inside information on the opposition like how high is the cutting teeth on 360 or Little Spinner!
Re: Tron
Not sure about the tooth heights, but I was going for the same thing with Quattro, probably made from welded box section to keep the spinners away from the main body of the machine.
Re: Tron
My idea is to use either HDPE or conveyor belt as the barrier but I am not sure of the tooth height of the oppositions discs especially 360 :uhoh: :uhoh:
I may have to cut something up on the day :mrgreen:
Re: Tron
Just to make things easier, vertical spinners will have a varying tooth height. Hopefully with my new one, the lowest it can get will be around 5mm off the ground :proud:
Although I don't know all the entries, the only verticals I can think of that will be competing are Drumroll 2 and....ahem....'Boner' (old Drumroll) so there's likely to be only a 1-in-20 (roughly) chance of encountering a vertical.
Re: Tron
Thanks Jamie, I will try to think of something just in case :uhoh: :uhoh: :uhoh:
Re: Tron
I made an angle iron (tornado) cage for 4 4 Toon for the champs last year and fought 360 with no damage :proud: It works well.
Re: Tron
New paint new scoop on the front,
UK champ dead cert :mrgreen: :mrgreen: :mrgreen: :mrgreen:
http://i569.photobucket.com/albums/s...g?t=1284757335
Re: Tron
Re: Tron
Regular Octagons? So overused. Make it an irregular Enneadecagon.
Re: Tron
19 sides all different lengths................................ It just might work :mrgreen:
Re: Tron
Re: Tron
New secret weapon for Tron next year :mrgreen: :mrgreen:
BE WARNED!!!!!!!!!!!!
Re: Tron
Got your mojo back have we ????
Re: Tron
Started fitting up Tron with the new idea. It is basically an electro-magnet with about 40KG attraction (400N) as Tron is A good pusher the idea is to make it a puller too. the magnet is attached to some rubber belt similar to that wrapped round Saint, the idea is it will adjust to the different angles of the armour of the opposition. I don't think anyone's tried this before so I thought I would give it a go.
http://i569.photobucket.com/albums/s...g?t=1331199729
Re: Tron
I thought it was a spinning bar weapon for a second! I think I actually made a :shock: face. A magnet would be cool, however, and as far as I'm aware unique as a weapon. This is legal as a weapon, though, isn't it? I get the impression it could cause major internal damage, especially with such a massive pull?
Or maybe that's the point. :lol:
Re: Tron
Dan was playing around with a similar idea and seemed quite keen until I pointed out that it would be ineffective against Ali, Ti (wood) or any of the plastics (Polycarb, Nylon, HDPE) which are pretty popular in robots.
I'm assuming it would work against Hardox and obviously any steel used and I don't see Nickel or Cobalt catching on as robot armour.....
Re: Tron
got a data sheet or any more information on that magnet Craig?
Re: Tron
Looks Cool Craig,
If it ends up not being very good you can always call it tron legacy :mrgreen:
Re: Tron
Dave the link is below
http://www.tme.eu/en/details/em-hs5030- ... 030-12vdc/
some answers
The north and south poles are on the same side (the front) so the magnetic field is very small the armour of the opponent robot would serve as the keeper,
I doubt if much if any of the magnetic flux would penetrate too far into the robot, so it will not cause any problem.
I know about the wooden or plastic robots but even these have some parts that could be steel on the outside and I'm feeling lucky!
If we don't try new things we could end up with a field of wedge flippers :uhoh: :uhoh:
Re: Tron
Thanks craig!
Jonny- i doubt it would cause much of an issue... in 360 ive got the rx double sided taped down on top of its magnet running right next to a big brushless motor... and ive never had interfearance issues:)
Re: Tron
Re: Tron
Ah, the one benefit of having a wooden robot :P
