My New robot needs some advice
Hello im building my second robot :) but need some advice. :?: Im going for a Rammbot with wheels sticking out both sides.
1) Im looking for a desent trasmiter 2.4GHz but don't know were to look. :?:
2)Team Toque sugested I use Nylon 6 as my armour and Frame, so is it a good idea. :!:
3)Im thinking of using 12volt Drill motors, but don't know Wether to buy cheap motors (Like Tesco Value) or buy more expesive motors ,but go over my very low buget £100-£150 ish :( (I might beable to get a bit more but don't know).
4)were to get 100mm solid rubber wheels and how to fix them to the gear boxes from the drills.
5)Allredy have speed controlers From ArmourDillo (I might not use ArmourDillo any more)
6)where to get a removalble link but also have a charging plug built in (so I can charge batterys in side the new robot)
7) Wether to Use My 12volt SLA from ArmourDillo And Car charge, or use batterys and Chargers from drill moters. :?:
I may have more Questions when I think of them.
Re: My New robot needs some advice
Basic 4-channel radio set (enough for a rambot with room to add weapons later should you wish): http://www.giantcod.co.uk/gianitcod-24g ... 03779.html
Yep, although I would only use Nylon 6 for the frame and opt for something like HDPE for the armour. I use Nylon 6 and it is a very good material. Strong enough for bulkheads but fairly easy to work with using a drill and saw.
Nylon 6: http://www.directplasticsonline.co.uk/Nylon6Sheet/
HDPE: http://www.directplasticsonline.co.uk/HDPESheet/
Just go for the Tesco value (or cheap Homebase/B&Q models) as there isn't much difference between them and drills in the £25-£30 category (the more expensive drills will generally have better motors though)
Robochallenge blue wheels with nut inserts (third item down) will screw straight onto the output shaft of your drill motors:
http://web.me.com/robochallenge/Robo_Ch ... nical.html
Bottom item:
http://web.me.com/robochallenge/Robo_Ch ... rical.html
Although any loop of wire on a connector would do, so long as it removes all power from the robot.
For in-line charging, wire up your robot like this: http://i31.photobucket.com/albums/c367/ ... arging.gif
Either option would be fine. The capacity of your battery (the 'Ah' figure) will determine how long your robot will last. The drill batteries will probably be less than your SLA battery so may not last as long, but they are a cheap option as they are part of the drills you purchase for the motors.
Thanks for the advice it will help loads. If i see you at an event I will thank you again
Edit: Just realised that I was ninja'd
also i need a copy of the FRA rules because evry time I look at the rules i get the old 2008 virsion, so ArmourDillo was illigal in till someone let me buro some spair parts to make ArmourDillo safe to drive. :oops:
That was me :) happy to have been of service.
I'll see if I can find the newest ruleset
its on the FRA mainpage www.fightingrobots.co.uk
Thanks, but I still get the 2008 version when I click on build rules. but thanks anyway
The build rules are pretty much up to date apart from some updates regarding Lipo's and tethers so remind me what was deemed illegal on your robot?
The trasmiter it's 27MHz and the rules we get when I click on 'rules' then click on 'FRA Build Rules' I get the 2008 version. I get this www.fightingrobots.co.uk/documents/Buil ... 008_v2.pdf rather than the modern version. the 2008 version said that I could use 27MHz.
GB can you please note Item 4 from the minutes of the 22nd meeting held on 23rd Jan 2010:
40MHz is no longer permitted for use in Heavyweights as of 1st January 2010 and will be phased out in 2011 for featherweights.
The build rules should have been re-written to reflect this however rules 4.1.3 and 4.1.4 still have 27MHz as a permitted frequency :uhoh:
Was there a final membership decision on the 40mhz phasing out? There was/is a sizable portion of roboteers opposed to it when it first came up as I recall...
OK thanks for your help and thank you (Team Toque) for helping me at robots live, Nowich. :rofl: :rofl: :rofl:
