Robo Challenge - Online Store now Open!
Hello Roboteers
We are delighted to announce our new online store is now open! Theres loads of items from robot parts and components to t-shirts & posters. More and more items will be gradually added soon including a robot graveyard for used and old items.
make sure you check out www.robochallenge.co.uk for details!
Re: Robo Challenge - Online Store now Open!
vertical motor mount now available from our store at www.robochallenge.co.uk
any idea when the pneumatics section will be sorted??
yea when is the pneumatic bit up and running
(before xmas would be helpful)
Theo
We hope to have some pneumatic parts available fairly soon. It will include a starter kit for building a pneumatic robot as well as our low pressure buffer tanks.
just don't do what i did :P, i wanted 6 wheels so i selected that i wanted 6 pairs of wheels lol fail
On the bright side you had spares?
no i managed to change it once grant told me what i ordered lol
Horizontal motor mounts are now back in stock! Our zinc plated steel motor mounts are perfect for securely mounting drill motors in featherweights. We use them in all of our kits and Captain Scarlett (06 UK Champion). Available now from our online store at www.robochallenge.co.uk
New parts now in store!
New - Sam Smith designed Deans connector mounts
New - EC3 connectors with and with out silicone wire
Back in stock - Horizontal Zinc plated motor mounts
when will the pneumatic kits be up for sale?
do you know how many amps deans connectors can handle? had a look on the deans connector website but can't find it :?
around the 50amp cont mark
will there be 125mm wheels with nut insert soon?
We may start producing some of the 125mm wheels with the nut inserts soon. In the past there hasnt been much demand for them though.
It's easy enough to make them yourself. Buy two of the 125mm wheels, get a couple of nuts suitable (ebay or a plumbers merchants will have them), drill the bore out to just short of the outer diameter of the nut, heat the nut up using a big soldering iron/gas torch/blue flame light/gas kitchen hob and then carefully press it in. Don't breath in the ensuing fumes and make sure the place you're doing it is well ventalated.
Been doing this myself to make some captive nuts on the new panels for boner, works a treat.
any news on the pheumatic kits?
Etronix 2.4ghz 4 channel radios with built in mixing now in stock!
Custom made left handed cap head bolts now in stock! Perfect replacement for lost or rounded off drill motor chuck bolts. Cap head allows you to use a 4mm Allen key which will allow more torque before rounding off.
Got a direct link to those James? Been looking for some (and struggling) recently as I've got very few left but I've been through all the sections of your store and can't see them.
Update on the peunumatics yet?
