Hey guys, I am attempting to build my own FW, I have a general idea of what Motors and Weapon I would like to use, but that's all, what other parts do I need?
What weapon and design are you planning on?
You're gonna need
- drive speed controller (s)
- radio gear
- chassis
- drive motors
- control for weapon (depends on what you're planning on building)
- wheels
- wiring
- a lot of patience
I'm hoping to build a bar spinner reminiscent of Last Rites or Tombstone.
If it's your first machine I would think carefully about whether or not a spinner is a wise idea. It's great to say that you wanna build a spinning weapon but there is a hell of a lot to take into account when first designing it to mechanically work, then making it realiable and finally and most importantly making it safe to operate.
I'm pretty confident I can make a spinner, I have made a sumo bot before but it was from a kit
(I'd like to do a spinner because there are too many rammers around and flippers are also quite common plus I know absolutely nothing about pneumatics)
You also need to know where everything needs to go so then the robot is balanced. Also, KEEP THE WEIGHT DOWN.
Trust me on this, I learnt the hard way (eyes go to where Gary and Andy are sitting). Don't run without walking. Just because you built a sumobot, doesn't mean you can go to a bar spinner straight away. You could start out with one Jonno's ratz, or something similar.
A very good kit, and will definitely help you.
You need to figure out the gear ratio, the armour, the chassis, the drive, the wheels and how the disc is going to be made.
hey, its good to see you want to build a spinner, but realistically its far harder to do than build a rambot or a robot with a lifter for example, when i first started i made a 2 wheel drive robot with an electric lifter and due to my in-experience the weapon broke before i even got chance to use it lol
after building a few robots i made a spinner my self- still havnt had chance to use it yet and its been built since september. and i had to get alot of help off people about how to go about building a robot with a spinning weapon because i didnt have a clue.
its alright you saying theres too many boxes about but they are a good place to start off for beginners as you can get to grips with how to get a nice drivable and reliable robot and dont have to worry about any weapons straight away
Ok, will try one of Jonno's rats
or something else i could suggest is comming to an event and having a look at a few feathers to get you in the right frame of mind about how to go about making one your self
make a nice box out of platic or ali more pratice for crumple zone then :evil: :twisted: :twisted: :twisted: :twisted: :twisted: :rofl:
Hey guys, I almost have enough money for a Battlerat.
Which tools do I need?
speak to Jonno when you order. He will be able to let you know what you need.
it is only simple tools you need i.e screwdriver set spanners i believe as all the frame etc is already cut to shape
You need a large set of screwdrivers, a soldering iron+solder, alan keys (metric).
Not much else really.
