Re: cutting out after a flip
What speedo does it have? We used to have a similar problem in Merlin, it would cause the Vantec to cut out or crash, it ended up being a diode that had blew on the valves. Do you have diodes across the coils on the valves? If not then its worth fitting, if you have them already check that they havent blew up! Other than that i dunno!
I agree with Alan, we had the same problem with the victors in Stagefright.Trouble is that just about everything went wrong and is still going wrong with it even now. :mrgreen:
Calum try putting a seperate RX battery in. Savage did it a few times when i started the disk up, It was drawing so much powering the 2 speed 900s and the drive and the RX was resetting.
Might be completely different prob but worth a try eh ?
hey,
using 2 electronize controllers and its running off a seperate rx battery already.
as for the diodes across the coils in the valves im not sure, how would i check? for now anyway i could try out a spare valve that i could swap for the one in the robot to see if the problem gets cured.
if everything works with the spare valve fitted (fingers crossed) it would look like its a diode problem after all
swapped the valve over, tried it all again drove it about, fired the flipper and - dead:S
without the gas on if i fire the flipper so the solenoid clicks the robot still works but its when the flipper physically fires then its all dead
might be the shock of the pneumatics firing?
problem seems to be sorted:P your all going to laugh at me lol
theres a block of connectors at the back of the robot and for some reason a wire could happily either stay in place or remove its self, and every time the robot flips the wire comes out of the connector block- disconnecting all the power from the batteries.
with all the times i had to take the link out and put it back in again- which was what i thought i had to do to get the robot working again, the wire must have freely moved just enough back to the connector block to give the robot power again untill another flip moved the wire away again.
i think that was most likley the problem as its completly working now and its not cut out since i've properly secured the wire
what a muppet
thanks for the help anyway
I second that - what a muppet! :lol:
Just kidding of course, we've all been there. Good to hear its all working ok again
HAHAHA! Had you stripped it down completely before you realised? normally it's in bits on the table before you realise.
Andy
no i didnt take whole robot apart but i took the pnumatics to bits to change the valve over and i had to remove parts of the robot so i could get to what i needed to sort out, took about an hour lol, with most the robot in bits i fired the flipper in the safety of my bedroom:P and saw with my eyes the bloody wire just pop out lol so now i've got to change it all back now.
And tom if you read this then those wheels have arrived:) will have to wait a few days to be able to see them as im working away, im currently sat in nasty hotel room with a snoring work mate so im just on the internet on my phone. Im missing my own bed already-mines definatly less lumpy
that will probobly happen too me in the near future
but that was kind of funny :mrgreen:
