crazy bots series 1 (the remake)
hiya guys this is my 2nd attempt at series 1 (huge thanks to manjib for advice) if some one could kindly please lock the old for me cos i dont know how to
the rules
1: weight limit
wheels: 100kg
tracks:105kg
shifter:115kg
true walkers:160 kg
2: before getting on to what bots ive chosen there will be 96 bots 48 of mine and 48 of yours ( thanks again manjib)
3: the arena
cpz's are now the ppz's
walls lowered by 5cm
4: battle rules
6 robots each heat, with 3 bots per 1st round 2 bots go through
semi- finals have loser melees
5: side tournament
there will be a feather weight tournament as well, which will be during the final heat and the 1st and 2nd semi-finals which will consist of 18 bots which will be drawn into an anialator (lol cant spell :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: ) in each the 2 bots from each heat that are the victors go on to the final battle to be crowned feather weight champion
6: bot entries every one who enters can choose 3 vapour bots and 1 real bot (or 4 vapours i you like)
now that the rules are establised (yet again thanks manjib) i will now commence with the bots ive chosen (ive changed my 48 since last time once again thanks manjib where would i be without you :proud: :rofl: ) my 1st 24 will be uk bots but the 2nd 24 will be battlebots
the uk bots (no seeding till next wars if that ever happens)
1:razer
2:ripper evo
3:chaos 2
4:behemoth
5:thor
6:mortis
7:hypno-disc
8:pussycat
9:storm 2
10:firestorm
11:panic attack
12:mute
13: pressure (the one that auditioned for series 7 with blue and yellow sploges of paint and a larger hammmer)
14: typhoon 2
15:iron awe 6
16:envy
17:dantomkia
18:cedric slammer
19:terrorhurtz
20:wheely big cheese
21:hydra
22:king buxton powerworks (aka king b)
23:ig 88
24:merlin
us bots
25:biohazard
26:nightmare
27: overkill
28:vlad the impaler
29:mechavore
30:mechadon
31:mauler 51-50
32:megabyte
33:punjar
34:matador
35:voltronic
36:frostbite
37: m.o.e (marvel of engineering
38:frenzy
39:dreadbot
40:tazbot
41:jabberwock
42panzer wrath
43:complete control
44:s.o.b (that darn dustpan)
45:hazard
46:t-minus
47:subject to change without reason (to us itll be called stcwr or subject)
48:ziggo
one last thing in each heat there will be 2 uk bots 2 battlebots and 2 vapours
hope i got it right this time
Re: crazy bots series 1 (the remake)
3 vapours, huh...
Starfire the 4th
Shape: Box with curvy upper edges
Colour: Magenta, orange, blue, bit of green, yada yada...
Weight: 99kg
Drive: S28-150 MagMotors run @ 36v
Power: SLAs
Motivation: 2 inner
Speed: 10mph
Armour: 10mm Lexan with an aluminium boron carbide chassis
Ground Clearance: 5mm
Turning Circle: That of a pizza machine.
Dimensions in CM (LxWxH): 105 x 95 x 35
Weaponry: A 20kg vertical spinning disc (powered by a LEM200 motor) that is on an arm that can lift the disc 180 degrees, from below to up top, linear actuated.
Gimmicks: A lightweight pneumatics system powers 8 rams that punch out from underneath Starfire to send her into the air and on top of another robot.
Srimech: Arm
Strengths: Destructive, versatile, has the power of gloorg on her side!
Weaknesses: Mustard
Raven the 4th
Shape: Mauler 5150
Colour: Dark blues, dark purples, blacks
Weight: 99kg
Drive: 2 Sinclair C5s run @ 24v, very reliable motors
Power: Motorbike batteries. But small ones so they can fit
Motivation: 4 omniwheels, so she can move wherever she wants to in a hurry
Speed: 11mph
Armour: 20mm tiriliumcarbonate alloy shell, with 6mm plasma nitrite on the top and bottom
Ground Clearance: 10mm
Turning Circle: you spin me right round baby right round like a record baby right round round round
Dimensions in CM (DxH): 100 x 20
Weaponry: 50kg spinning ring; has 20 hardox teeth to rip and tear. Powered by two petrol chainsaw engines, it can give out approx. 800kJ per hit! Is shockproofed with 10cm of PU foam to absorb blows.
Srimech: Invertible
Strengths: One-hit KO potential, empathy
Weaknesses: Being Satan's portal
Terra the 2nd
Shape: Biohazard(ous Waste of Time, which is a real bot)
Colour: Yellowjacket
Weight: 105kg
Drive: 4 LEM130s @ 36v
Power: 6 NiCad Battlepacks
Motivation: Eurypterus-style tracks
Speed: 15mph
Armour: 25mm plywood bolted on with hardened rubber bolts. Never underestimate the power of wood.
Ground Clearance: Check Biohazards's.
Turning Circle: :elcriC gninruT
Dimensions in CM: Check Biohazard's.
Weaponry: A very large lifting arm working similar to Biohazard's, powered by an M-Mac actuator. It can lift approx. 10000oz.
Srimech: Arm(ed and dangerous).
Strengths: Based off a winning design, good weapon, metabolism
Weaknesses: Mediocre control
Anarchy (realie) :D
96 bots... 48 of my choice and 48 of yours, you can have 3 vapours and 1 real or 4 vapours
CrOoKeD evo
O.I.D
pick-axe-of-doom
anddddddddd.........GRAVITY!
I might as well enter, and since I cold be considered desperate...
Cyrilium 5
Minesweep3r
Nega2vity
Bandwagon 2
Stats are here.
nice entrants guyz keep em coming, remember there are still 18 spaces in the feather weight championships
for the featherweights il have flow and beauty 2
FWs?
Heretic and Micro Gore please. :)
You know where to find the stats for Heretic. Micro Gore's are not too far from it.
keep em coming lads we still need more guys but i can wait
I'll have Starfighter and Beauty IV :proud: ...
can you give me some specs on starfighter cos i dont know anything about it corsair
keep the entrants coming
only 37 spots remain in the main tournament
and 12 in the feather weights
also after the series there will be extra events such as the anahalator (damn it cant spell) and a tag team terror tournie
(in which people who have entered will be drawn up with a random partner that could be your mate :P )
i have a feeling that this series is gonna be great
1
Robot Name: The R.O.C (Revenge of Collateral)
Shape: Box with wedges on all sides, the front wedge has a Firestorm-style blade for zero ground clearance
Weight: 100kg
Length: 90cm
Width: 95cm
Height: 15cm
Motivation: 4 x internal vulcanised wheels, mounted like those of Tazbot for extra manouevrability
Drive: 2 x PERM 080s @ 24v
Batteries: 2 x NiCad battlepacks
Armour: 6-8mm grade 2 titanium for the most part, with 4mm hardox in key areas and 10mm HDPE on the base, with 4mm grade 2 titanium additional protection in key areas
Weaponry: This robot has an interesting weapon synergy onvolving;
1) A rear hinged lifting arm, hinged at the centre of the robot's length and width. It is powered by an S28-400 at 24v for quick lifting, and it can raise to 2 levels- 75 degrees when lifting and 270 degrees when it needs to self-right/reset the flipper. The arm raises in about half a second
2) An upside down U-shaped front hinged flipper. The lifting arm is hinged in between the hinges of this weapon. It is powered by a 2 x 1.1kg co2 bottles and 2 x 85mm non-attached rams at 750psi, meaning it gets about 10 flips. Normally the rams wouldn't work when non-attached because of the way it is hinged, but the lifter will already be raised when the flipper is raised and so can quickly move back the rest of the way to reset the flipper
The way the weapon synergy works is this- the lifter lifts the opponent to 75 degrees, then uses the flipper to throw them about 7 feet up and across because of the placing of flipper and lifter. Then the lifter resets the flipper.
Speed: 15mph
Turning Circle: 0
Ground Clearance: 0 at the front, 7mm at sides and rear
Srimech: The flipper can right the robot, but the lifter will be used to conserve gas.
2
Robot Name: The Subjugator
Shape: Box with skirts all the way around
Weight: 150kg/200kg (see armour)
Length: 90cm
Width: 90cm
Height: 35cm
Motivation/Drive: 4 x hardox legs with vulkalon rubber feet, they are each actuated by two 10 bar 32mm pneumatic rams from a 5kg tank, they are not visible as they are internal
Armour: 4mm hardox (8mm with 200kg rule)
Weaponry: An 80cm long hardox arm on a 360 degree turret spun by a Bosch 750 watt motor at 36v. On the end of the arm is a large vertical claw, it has two prongs on the top and one on the bottom that goes between the top two when the claw closes (like Mr. Psycho). The prongs are all tungsten tipped and the claw is drilled with several speed holes, the claw is actuated by hydraulics at 3000psi from a vivoil pump powered by a LEM-130 lynch motor at 36v, they can be cranked up to 5000psi if the tournament allows it and can crunch through 4mm hardox when at 3000psi, look out if it€™s at 5000! The arm can move over 180 degrees via a LEM-130 at 36v to flip opponents and slam them onto the ground
Speed: 12mph, pretty fast for a walker
Turning Circle: In the centre of the robot€™s base armour there is a 20cm x 20cm circular section that extends to below the robot via another 10 bar ram, but this one is 400mm and takes the gas from its own 1.1kg bottle, once on the ground the circular piece of armour rotates in the direction which I want the robot to go via a Briggs & Stratton E-Tek at 48v.
Ground Clearance: 20mm all round, protected by 7mm titanium torsion sprung skirts, held together at the corners by 5mm hardox hinges
Srimech: The arm can right it in any direction
Colour: Black, with red and gold claw and the name written in white
Strengths: Heavy, unpushable, good weapon
Weaknesses: Comparatively slow turning
Notes: This is what happened the day I thought €œWalkers used linear actuators... What about fast pneumatic rams?€ With a lot of help from Leo Van Miert The Subjugator finally came into being, originally using a Whyachi-style tri-bar before that was replaced by the vertical claw when Leo brought to my attention how unstable it would be with the spinner weapon.
3
Robot Name: Helix
Shape: Tornado (including the angled rear) with angled sides, skirts and a front wedge
Weight: 100kg
Length: 80cm
Width: 80cm
Height: 9cm
Motivation: 4 x vulcanised wheels
Drive: 2 x S28-400s at 24v, 9HP, powered by 2 x NiCad battlepacks
Armour: 3.25mm hardox top, sides, front and rear, 5mm titanium skirts and 5mm aluminium base
Weaponry:
1)The front wedge is made of 3.25mm hardox and has a wedge extender for zero ground clearance at the front
2)A front 65cm long hardox axe, the head is shaped like Excalibur€™s from RW3 and it€™s on a rack and pinion system ala Terrorhurtz. It is powered by a 140mm stroke, 80mm bore cylinder at 1000psi from 1 x 2kg nitrogen bottles, the point is tungsten tipped and the underside serrated to really dig into opponents, it is on a rack and pinion system and there is enough gas to provide about 15 hits per fight which should be more than enough considering the power in each hit, there is about 2 tonnes of force in each hit when at full pressure and is enough to destroy aluminium, punch holes in titanium and even dent hardox
3)There are two tungsten tipped hardox spikes on either end of the angled rear
4)The front wedge lifts up via a linear actuator, this is used to flip opponents and attack their base armour with the axe or to lift and then ram or clamp when using this in unison with the axe. It has two spikes that run flush to the floor to help get under other robots
5) Not exactly a weapon, but it has a vacuum device to suck the robot to the floor. This is used to counter-act the effects of the axe and help it fight rammers and flippers. It can be turned on and off throughout the match, but unless I say so assume it will be turned on.
Top Speed: 17mph
Ground Clearance: Effectively 0 all round due to wedge at front and skirts at sides and rear, but 20mm behind them, they are all joined together with tungsten hinges to make them extremely hard to break
Turning Circle: 0
Srimech: The axe is long enough to right it over the wedge
Colour: Black with some green and red
Strengths: Powerful axe and decent pushing power
Weaknesses: High GC behind the skirts
Notes: Plenty of shock-proofing
4
Robot Name: Brutalis 2.1
Shape: Dantomkia, but with the front spikes hinged
Weight: 100kg
Length: 65cm
Width: 70cm
Height: 15cm
Motivation: 2 x HDPE internal wheels, 125mm in diameter and sloped like Tazbot for more manouevrability. They are in the front of the robot so the front turns rather than the back
Drive: 2 x LEM-130 lynch motors run @ 48v from 6 x 3600mAh NiCad battlepacks
Armour: 3.75mm hardox monocoque
Weaponry: The main weapon is the front hinged flipper, powered by a 120mm x 100mm bore stroke ram @ 145psi from a 1.5kg co2 bottle, giving 15-20 flips per round due to the low pressure. It is capable of pushing robots OOTA of it gets the chance, but is better at turning robots over and than throwing them. Also there is a strip of Mute-style barbs running up the flipper to get robots stuck on it. And finally on either front spike there is a tungsten spike pointing sideways, so when the robot spins it can act as a thwackbot.
Speed: 17mph average
Turning Circle: 0
Ground Clearance: 0 at front and effectively the same at sides and rear due to 7mm skirts torsion-sprung and made of grade 2 titanium, but behind the skirts is 6mm at the sides and 15mm at the rear.
Srimech: The flipper can right the robot quickly, easily and repeatedly if need be
Colour: Black bodywork, with red skirts and a gold flipper.
Strengths: Very durable, well-armoured, good pushing power
Weaknesses: Flipper isn€™t very powerful, no real damaging weaponry
Notes: This new version of Brutalis ditches the full pressure flipper and heaps of gas from the old one for thicker armour and slightly more powerful drive. The strategy is to push and bully robots around the arena with the pushing power and the flipper, rolling and tossing them around and into the pit or even out of the arena. If it can€™t manage either of those then it will be aiming for dominance in order to swing a judge€™s decision, and due to the tough armour it won€™t be too down in the damage department despite lacking any real damaging weaponry.
ok we have 33 spots left for the heavyweights
and only 12 for the featherweights
ok since not many people are signing up i extend how many bots you can have to 8 bots
Alright, my final entry list:
Revenge of the Prayer Shawl
1-hit Wonder
Darkwing 2
Bomb-Omb
Turbo
ARC Smacker
Megaroll
Dr. Acula
All stats are here.
ok then add these 4 to my team...
Robot Name: Apocalypse II
Weight: Roughly 100kg
Shape: Box wedge with sloped sides, ala Storm II. The front wedge is angled at 30* to get under opponents, and the sides are sloped at 42* to deflect spinners. The rear is rounded for easier self-righting.
Length: 80cm
Width: 60cm
Height: 15cm
Motivation: 2 x internal HDPE wheels, each are 125mm in diameter and they have vulcanised tyres for extra grip, plus they are mounted like Tazbot€™s for more manouevrability. They are in the front of the robot like Merlin so the front turns rather than the back.
Drive: 2 x S28-400 magmotors run @ 24v from 2 x 3600mAh NiCad battlepacks; this should provide about 9 horsepower.
Armour: 3.2mm hardox monocoque for the most part, strengthened in certain key areas with extra 5mm titanium/vanadium alloy sheeting.
Weaponry: The robot is a decent pusher, but on top there are three sets of Mute-style barbs, one on each side and one running down the flipper arm. These are tungsten tipped to allow it to trap robots on top, and once their stuck on top they can€™t get free.
The second weapon is what I use to get rid of the robot stuck on the barbs. It is a Bio-Hazard style 4-bar flipping arm, but unlike Bio-Hazard it is run off full pressure pneumatics, meaning it will easily throw robots out of the arena. It is 30cm wide and runs down the centre of the robot, made of 4mm hardox and powered by a 120mm x 100mm bore stroke ram @ 750psi from a 1.5kg gas bottle, giving it about 10 flips per round, which should be enough. On the front of the flipper arm there is a strip of 8mm grade 2 titanium, which should aid in getting under the other robots
Speed: 15mph
Ground Clearance: 0 at front, 8mm at sides and rear, but this is protected by 5mm titanium torsion-sprung skirts made of grade 2 titanium.
Turning Circle: Using the skid steer system ala Razer gives Apocalypse II a 0 turning circle
Srimech: The 4-bar flipper can right it in less than a second, but to conserve gas there is an electric srimech hinged at the rear of the robot. This is the two strips of barbs on either side of the machine lifting up to vertical via a Bosch 750w motor run @ 28.8v from a NiCad battlepack. This rights the robot in 1 second, and can also be used offensively to tip opponents stuck on the barbs into the pit
Colour: This new Apocalypse keeps the colour scheme of the old one, with dark blue bodywork and a red weapon.
Notes: This new Apocalypse trades the powerful drive motors of the old one for more armour, as well as bringing in a new 4-bar system and a new srimech idea, albeit with less gas for the flipper. This shouldn€™t effect it too much though as the lifter can still be used to dump opponents in the pit or stack them against a wall. The previous robot enjoyed some success, and hopefully this new, more original version will build on that.
Last time the emphasis was more on the flipper, but this time around the focus is more on the barbs, which were under-used last time and so this time around the design is focused around the barbs instead of around the flipper.
Robot Name: Final Resting Place
Shape: Cylinder
Weight: 100kg
Length: 85cm
Width: 85cm
Height: 15cm
Motivation: 8 x Big Nipper style small wheels, 4 on top and 4 on the bottom, they are made of HDPE and have vulcanised tyres
Drive: 4 x S28-150s @ 24v, 6HP
Batteries: 4 x NiCad Battlepacks
Armour: 1mm titanium for the side (though that is untouchable) and 5mm hardox on top and base
Weaponry: A spinning spike ring similar to that of Del-Dog's (RW UK vs. Germany special), it runs the full circumference of the robot and spins up to 3000rpm in 3 seconds courtesy of a LEM-130 @ 48v. It weighs 25kg and can reach 1500rpm in 1.5 seconds, from where it can produce 72.5Kj, so at 3000rpm it can deliver 145Kj. To protect from its own and other hits it has internal shockproofing, the ring itself is made of 10mm titanium. The blades are curved spikes made of tungsten and weighing 2.5kg each, they are part of the ring so cannot be ripped off. This weapon is capable of serious damage
Speed: 20mph
Turning Circle: 0
Ground Clearance: 8mm
Srimech: Invertible
Colour: Red, with name in green on top and base and a gold ring with sapphire blades
Robot Name: Volde
Weight: 100kg
Length: 90cm
Width: 90cm
Height: 25cm
Motivation: 2 x internal 80mm diameter wheels with vulcanised tyres
Drive: 2 x S28-400 magmotors @ 24v powered by 2 x NiCad battlepacks @ 24v
Armour: 3.2mm hardox, the base armour is 4mm aluminium
Weaponry: All three weapons work in unison to clamp opponents:
1) Overhead axe, powered by an S28-400 @ 24v, it is 90cm long and made of titanium
2) Splinter-style side arms, each powered by an S28-400 @ 24v Each is identical to the axe. There are hinged, and so when the lifting plate lifts and the axe goes up they do too
3) A Complete Control style lifting plate, powered by an S28-400 @ 24v, it is made of titanium and runs flat to the ground to get under skirts and 0 ground clearance
None of the weapons are designed to damage the opponent, just hold them in place
Speed: 15mph
Turning Circle: 0
Ground Clearance: 0 at front, 7mm elsewhere
Srimech: The axe can right the robot quickly and easily
Colour: Dark blue bodywork with red and gold weapons, the name written in green on the sides and in purple on the rear
Robot Name: LockJaw v3
Shape: Imagine an axlebot with Triangles at either side where the wheels would normally be, then on the right of the left triangle and on the left of the right triangle imagine a vertical claw. Then add a scoop in between the claws and put a third claw in the middle of the scoop, built into the scoop so it is invisible until it opens wider or closes.
Weight: 100kg
Length: 55cm
Width: 90cm
Height: 20cm (with claws shut) / 55cm (with claws fully open)
Motivation: The triangles at either end of the robot are wheel pods, as in each one is a 6mm hardox wheel with a vulcanised tyre. The wheels are both 220mm in diameter and mostly protected, but exposed from the three sides of the triangle. This allows it to run anyway up, but without having to put the drive in reverse.
Armour: As it€™s an axlebot there isn€™t much armour, but the wheel pods are made of 6mm hardox, and the 1cm scoop is made of grade 2 titanium.
Weaponry: The two outer claws are fast, but not powerful. They are each powered by an over-volted Litton motor @ 36v for fast grabbing. They merely hold the opponent in place while the middle claw comes into play, powered by hydraulics from a vivoil pump actuated by an S28-400 magmotor @ 24v running at 3000psi (5000psi if the tournament permits it). This claw can crunch through thin hardox and itself is made of tungsten carbide with serrated edges like the other two. The claws can open wider if the opponent is too high for them to grab. When they do this they dig their bottom prong into the ground ala Big Nipper, meaning they can get under 0 ground clearance, but nothing will get under them. This will not only be used against tall robots, but flippers or other wedges.
Speed: 15mph
Turning Circle: 0
Ground Clearance: 0 at front, less than zero if the claws open fully. It€™s an axlebot though so doesn€™t really have much of a ground clearance.
Srimech: The robots runs exactly the same when flipped upside down, I don€™t even have to put the drive in reverse due to the triangular wheel pods giving it three drive positions.
Colour: Unpainted
Notes: The original LockJaw was Stinger with a claw between the wheels, and failed miserably in its only fight. LockJaw Epidemic introduced two separate claws, but they were electric and not powerful enough. Version 3 provides the best of both worlds.
CrOoKeD EvO
O.I.D
bigger brother
iron awe 6
storm 2
razer
turbulance
dantomkia
Replacing Megaroll with Megaroll II. Stats in the usual place...
Team Mechanical Menagerie
a) Compression 1.1
b) Apples & Pears
c) V for Vendetta
d) Exotherm
e) Skull
f) Loki
g) Shadow Assassin
h) Thunderstorm
All stats here:
http://strickenone.proboards.com/ind...board=mmheavys
13 spots left in the main competition.... im hoping that some one else is gonna join the carnage, when all spots are full ill make a special trailer on youtube
Very well, I'll throw in some more realies...
Surgeon General (Battlebots Season 5)
Hexadecimator (RoboGames 2006)
Ripper Evo (Roaming Robots; most recent)
Thor (Roaming Robots; most recent)
ull have to have just ripper as ive chosen ripper evo and thor as well
You never called Jack Orr out for using Iron Awe 5. :P But whatever.
Give me...S.M.I.D.S.Y (series 7) and Diotoir (Extreme 2) instead of Ripper Evo and Thor, then.
hes using iron awe 6 not 5
...yeah, 6. But you have Iron Awe 6 listed, and he chose it. :P
Edit: Now that I think about it, he chose other realies that are also on your list like Storm 2. :P
ok ill have 5 he can have 6
i dont mean to be rude but, your entering yourself in your compitition? people are gonna say thats kinda biast.
and its martijn not manjib :mrgreen: :rofl:
im not entering myself... these bots were random choice i know what u mean by me entering myself but what i meant was robots ive chosen to be put in compotition
hope u understand my point
ok theres an important change
there wont be 6 per heat there will be 8 per heat cos ive just gone over it calculating on my fingers turns out there would be too many semi-finalists
12 spots left in the main competiton any 1 else wanna enter to be crowned crazy bots champ
right ive decided that a random draw for final 12 bots will be chosen
this is how the hat came out
st hammer
obsidian
chompalot
maelstrom
kan opener
big nipper
killer B
mjollnir
iron eagle
blendo
gold digger
pressure drop
draws will be up soon
ok heres heat a draws
rest to follow
heat a
mechavore vs anarchy(kody kunz) vs o.i.d (jack orr) vs biohazard
minesweeper (corsair lightning) vs nightmare vs merlin vs apocolypse 2 (swimm3r)
tactics plans or a local lonney bin? :mrgreen:
tactix.....
right, il rev O.I.Ds disk up to full and wait for the right moment, anachy looks like the best bet to attack, the polycarb should be no problem, aim for the side and rip out the polycarb/legs, thats him disabled, then see what happens after that, mechvore should be no problem, just hit it a couple of times and it should die, biohazard looks nice too, the titainium will give off some nice sparks :) hit it a couple of times and the side pannles will fail, then just keep hitting it and it should cease to be a threat any longer :)
if for any reason i see a chance to pit someone, take it :) but keep well away from it otherwise :)
jack
Minesweep3r: Now here's the thing: Only yesterday I competed against Jim Smentowski(The guy who made Nightmare) in an antweight competition and beat him. I have great respect for him, so I'll team up with Nightmare(Titanium disc, 2 teeth, powered by an E-Tek at 48v) and let him destroy Merlin. Flip him onot his wheels if he gets flipped over, and attack Apocalypse II if need be.
Mash OID with the axe, try and flip it over. Because he's attacking me, what other choice do I have? :P
mark, you have an antweight? is this a real robot or a vapour, cos the micro nightmare is awsome :P
Yes, it's a real robot. Surprisingly, it's nothing more then a Battlebots toy with all HDPE armour. It weighs 15.4 oz, and defeated Shazbot in a grudge match at Gulf Coast Robot Sports 3. And let's not forget that Shazbot won its first 3 tournaments...
