Re: Team Shock's new robots
That's a very nice looking setup Will, simple and neat. Makes me want to build a flipper now :proud:
Good luck with the build
Not a lot has happened with Whirlwind recently, we got the last part the other day so it is all ready to build. I have designed the frame and it should have been started on today but the weather had other ideas and stopped us from welding it. If the weather allows we might have it going for maidstone but it will be tight.
In other news I have started work on a new antweight. I decided to go for a spinner and so far it's coming along quite nicely
Weight: Should be under 150g with some weight saving
Length: 9cm
Width: 11cm
Height: 3cm
Weapon: 40gram Spinning Drum running off a brushless outrunner motor
Drive: 2x 30:1 Solarbotics motors
ESC: Peter's option A board
Rx: AR500e
Battery: 250mAh 2 cell LiPo
Armour: HDPE of various thicknesses
Pics- http://s881.photobucket.com/albums/ac13 ... 3_1239.jpg
Video- http://www.youtube.com/watch?v=qYWrN-svJX4
i do beleive you have the same laptop as me :P , looking very very nice btw .
Bloody hell, it's cute and scary at the same time!
It's looking great.
We have finally finished Whirlwind (just in time for Barnsley)
We managed to test the flipper last week but that caused a couple of problems (the main one being that it bent the 3mm thick steel arm) Since then we have added extra braces and it no longer bends and should hopefully work (or self destruct)
Here are the stats of the finished robot
Weight: Around 13.6kg
Length: 45cm
Width: 50cm
Height: 20cm
Weapon: Full Pressure Flipper with a 60mm Bore, 80mm Stroke 'Kenny Special' ram
Drive: 2x drills with 100mm Blue wheels
Armour: 3mm HDPE & 3mm Steel
Speedo: Sabretooth 10A
Batteries: 14.4 Ni-Mh for drive, 24v for valve
Radio: Spektrum DX5e with BR6000
Pictures can be found here
http://s881.photobucket.com/albums/ac13 ... G_0324.jpg
That looks good :) is it using the chassis of Aftershock or just built similarly?
Thanks Joey.
It is a completely separate robot to aftershock, we just made it in a similar way.
looks cool, has a stealthy look about it
I'd get those exposed wheels protected somehow, but it looks nice.
hi will, if you swap the elbow fittings for sweaped fittings you would increase the flow from the buffer tank just a small tip and for not much money
After a couple of fights with Whirlwind it became clear that there were one or two small issues with the power of the flipper which has resulted in breaking 3 flipper arms which went like this
Arm 1: Bent after 3 fights at Barnsley
Arm 2: Bent during testing before Whitwick
Arm 3: Snapped in half during its first flip at Whitwick :lol:
So we spent today making yet another flipper arm and this one looks like it might finally work :proud:
Here is a quick video of us testing it:
http://www.youtube.com/watch?v=BzyboiXXfqU
Also in other news, Aftershock has had a few upgrades including a brand new flipper arm and we also have 2 new antweights Inertia & Tesla
Pics of both can be found here
Tesla (electric axe) http://media.photobucket.com/image/tesl ... 77.jpg?o=9
Inertia (Vertical spinner) http://s881.photobucket.com/albums/ac13 ... G_0298.jpg
your garden is a bit muddy :rofl:
antweights look great and the CAD images in the back look slick any armour on the spinner???
Well about time I did another update.
Whirlwind has finally started to work as intended, the new flipper arm survived 3 fights at Nottingham without any sign of bending. The flipper seemed to have plenty of power which was clear when self righting (4 somersaults in the air is pretty impressive but can be a bit annoying when the battery comes out)
Also I have finally got round to sorting out a new team website which has been desperately needed (I haven't updated the last one since 2008!) so here it is
http://www.teamshock.kk5.org
there are a couple of bits which are just updating but the whole thing should be done tonight.
