Battery restraints
Hi All
Those of u who were at barnsley, I dont know if u realised that in both of Pugs fights, his battery fell out, Id pretty much like a device that not only keeps the battery restrained to the chassis, but is also easy to fit on, does anyone know what I can use and if they are on Technobots and if u know that, please tell me.
Regards
Liam Bryant
Battery restraints
Liam,
Depending on what the base is made of, and how easily it can be drilled, I would recommend drilling four holes in the base, threading two cable ties into these holes and tightening them around the battery.
Hope this helps,
Alex
Team Blitz
Battery restraints
Cable ties tend to break though especially if they go through the base and are visible on the underside.
We have been using the hose cilps used in cars. Cut them in half, bend them into shape and then bolt them in place. You need to put a bit of packing on top to stop it cutting into the battery.
Andy
Battery restraints
Just make a bracket from a few strips of aluminium bent around the battery and bolted to your base or frame.
Battery restraints
I have used perforated All Round Banding before which is often used for fixing armoured cables to cable tray. You can get it plain galv steel or PVC coated steel.
Battery restraints
OK, my kit that became Pug did come with perforated metal strips, u know if I can buy them off technobots or if theyre not on Technobots anymore?
Battery restraints
Battery restraints
Arent cable ties likely to snap?
Battery restraints
YES :sad: most of the time but theres noing and no where to put them
in B3 no panels either LOL
go for think ones
Battery restraints
Liam,
I forgot about them, see http://www.technobots.co.uk/acatalog/Online_Catalogue_Perforated_Steel_Sheet_102.htmlhttp://www.technobots.co.uk/acatalog...teel_Sheet_102 .html
Battery restraints
On The Saint I use straps similar to the type you use to stop a suitcase from opening, or tying down something on a roof rack, they have a quick release lock can be cut to the correct length with a sharp blade and the clasp tightens the more force that€™s applied to it up to about 1/2 tonne
Battery restraints
i got some cable ties that are about 20mm thick, found them under the seat in my van when i brought it. never seen them as big as these before, found about 50 of them
