The Magnificent Banana
My Father and I are planning to build a robot: The Magnificent Banana:
Shape: See pic ( Pic on profile, sorry about quality, theyre awful)
Colour: Yellow with a black stripe
Speed: 20MPH
Weight: 100KG
Armour: ?
Drive: 2 LEM130s @ 36V
Power: ?
Locomotion: 2 Wheels near the rear of the robot
Ground clearance: 0MM at front, Varies at sides, 1MM at back
Turning circle: 0
Dimensions: ?
Weaponry: A large flipper powered by 2 120X180 Pneumatic rams @ 1000PSI
Srimech: The flipper
Opinions, help, a DVD of the RR 2006 UK championships
I think the highest operating pressure you can get for co2 is 725psi pr 750psi
Boyles Law, :mrgreen:
Der Boyz
Fine 750 PSI, but what about nitrogen
Nitrogen is removed from the rules, only CO2, or compressed air on low pressure.
Also, a 120*180 ram is at least 12 kg, if a commercial available ram is used. And delivers on its own 1.5 times more power than a 100mm bore ram.
With 2 of these gasguzzlers, youre emptying a 2 kg CO2 bottle in 2 actions. And then the question of valves. Each one will need a 1 bsp or equivalent inlet valve (meaning 4 burkerts =2.5 kg at least).
Then the LEM130s. Youll need a boatload of batteries to provide the power, and then deal with it.
A nice vaporbot, unless you got acces to aboutish £50 000.
New Pic on profile
weapon is powered by a 5KG Co2 tank
Armour 3MM Hardox
Ive just checked the Fra rules and the max operating pressure allowed for pneumatics is 1000PSI
Correct, but in reality you cant compress C02 past 750 psi as this is when it becomes a liquid. You can compress a liquid a small amount but there is no advantage to do this as it wont get you any more power.
The pressure of co2 in the main tank / cylinder is temperature dependant.
You may get 1000 psi on a hot day....and then only in the main tank ...extracting gas ... as in firing a ram ... has a cooling / freezing effect and will cause the pressure to drop dramatically.
are you using a 5kg as the main tank ?
Im quite sure no one uses more than 1 2kg for
a main tank except an old iron awe ? gilbert ?
and nearly everyone uses 1 2kg for a buffer
and they are powering quite large rams to.
I think you can lose a lot of weight here.
Craig, does beast have a much larger ram bore/stroke, and how many flips do you get per 5kg bottle or how much on average left over after a fight ?
Beast isnt mine, I jus know it uses a 5kg Bottle John Lear or LJ will be able to answer u beast I mean best
Beast uses a 100mm bore ram, with an adjusted stroke of 200mm.
Full ali construction.
And there is a reason I know.
is that because your closer to the LHC than us and the energy field its creating is giving you pshyic powers beyond reckoning?
Either that, or he built the ram. I know the LHC explanation is more plausible. :)
Can we agree then, Mario may have made the ram but he also has become a master pshyic with telekinisis (or however u spell it, and dont say i -t )
After thousands of years of laying in wait the swizz are finally creating an army of super humans with the energy of the LHC
Millions of swizz ready to fight armed with annoying cuckoo clocks
beast uses a mario ram but the stroke has been modified to 150mm or 175mm as we have a spacer in it to make it not go over vertical
we had to cut it down abit so the length was the correct length for our flipper arm
we dont know how many flips we get - with iron awe we had 1 good flip as that was all we needed lol but i dont think we have never come out of a fight with an empty bottle - my dad says we would prob get 30 good flips before something breaks lol
and the next event ill get someone to count
we dont really need a 5kg bottle but u no what my dads like he likes to show off abit and use all jonnos gas lol but you never know when you may need more flips!
o ye after this years replacement of the ram beast is back ready to rule ;)
(Message edited by john on September 10, 2008)
what LJ really means is that hes never done a fight where he was able to count them either...
a) he got stuck upside down trying to selfright
b) he had a gas leak from the first flip
c) he had a wire come loose
d) he got flipped out the arena, or down the pit
one day maybe, there always an excuse !!
haha
its my dad not pressing the button thats y i cant count them
iv told u lots of times now jonno - beast is back :P just wait til i get ripper oota
