The Killer Toad Tournament - The Final Assault
Location: After-tournament party for Fight against House Robots
Everybody is busy celebrating Paul€™s victory, apart from 2 people, 1 of which is sleeping on the floor having a bit too much to drink, and 1 mysterious person wearing a darken cloak, who nobody has noticed as slowly worked their way into the back-stage pits area, where they take a hammer out of the cloak and smash open the lock to the locked door to the secure out-of-bounds production office, being exiting 5 minutes later carrying a large black box containing some very important details and stuff. The mysterious person exits as mysterious as they entered.
Meanwhile at the party, nobody has noticed as Kody tips a bottle of champagne over Paul€™s head as everybody cheers and downs some more pints of various alcoholic drinks.
*The next day*
Clearing up, one of the cleaners notices that the door to the production office has been damaged, and calls the production manager who after a quick scan notices that some very important documents are missing, more importantly that his lovely expensive large black box is missing, but there is a note on the table saying: €œIf you want to see your documents again, don€™t call the police, but call this number 07€¦€ of which the production manager does.
15 minutes later he exits the office looking a nervous wreck, and reads out the demands made by the kidnapper for the safe return of the very important documents, that 1 robot of the highest order will fight it out against 1 of the kidnappers own robots which is off the highest order in a location and date to be determined, however the kidnapper has also made it clear that the robot selected must have been selected after going though a series of tests and battles against other robots. The conditions for these tests and battles will be posted to the arena within the next couple days.
2 days later a large parcel is returned, showing pictures of the documents and some details, of which the production manager passes onto the writer who writes them out into a format which people would know
The next week a notice is printed out and sent to all active Roboteers which sums up the situation.
What is needed
17 people to enter 3 vapourbots each. 51 robots might seem to be an odd number but it is what the kidnapper wanted
Weight limits and the like
Wheeled machines are allowed 100kg, tracked machines are allowed 100kg, shufflers are allowed 100kg and walkers are allowed 100kg to play with.
Passive weapons are allowed, and clusterbots are allowed up-to 4 pieces, in which the 50% rule applies
Format
48 machines will fight it out in a round of knockout to leave 10 machines (48 down to 24 down to 12), 3 machines which are seeded from the original series will be given byes until the 3rd round, and 3 lucky machines will be given
The 3rd round will be made up of 3 groups, each containing 5 robots each, where the 3rd round will be made up of each robot fighting each other robot in the group
The 4th round will be the 3-way play-off ties, where the runner-up of each group will fight each other to determine which will get the 4th spot in the semi-finals
The 5th round will be the winners of the 3 groups, plus the winner of round 4 fighting it out in a best of 3 knockouts, of which more details will be announced later. The winner of round 4 won€™t face the winner of the group they were in (Say the winner of round 4 came from group 2, the winner of group 2 and €œgroup 4€ won€™t fight it out against each other)
The 5th round will be the winners of the semi-finals fighting it out, at a neutral location.
The 6th round will be the fight against the winner and thus demanded as a robot of the highest order against the kidnapper€™s own robot, again in a neutral location.
Seeds
1 - Frankie (For May Tracks Have You for double champion of KT)
2 - Martijn (For Flick of the Wrist for runner-up of KT3)
3 - Paul (For Nitro-Gene, champion of FAHR)
Those 3 can enter the same robots, or can elect a member of their team
Other stuff worth mentioning
The arena for the rounds 1 to round 4 will be a bog-standard Robot Wars style arena, with no hazards, apart from the pit which is open all the time. Plus the walls are slightly higher and stronger.
(And before anybody asks, I do not know at this moment in time which robot the kidnapper will bring to the final fight, nor the details of what was in the documents of which the Production manager wants so much back.
So in recap, 17 people to enter 3 vapourbots each, with a link to where their stats are located. Stats can be in any format, as long as the basics are there I dont really care how detailed you wish to go, but if Im unsure I will ask questions.
Any questions?
Ill enter:
Robo-Mosquito
Robo-Tiger
Robo-Hedgehog
Stats on ZED or in How Could I Improve Pt 2
The May Tracks Has You
Shape: Like Comengetorix. It has a wedge extender to give it 0 mm at the front.
Speed: 20 MPH.
Dimensions(lwh A): 85CM X 45 CM X 24 CM
Armour: 4.5 MM hardox.
GC: 0 mm at the front, 6 mm everywhere else, covered by skirts made of 3 mm Ti.
Weapon 1: Rear hinged flipper, powered by two pneumatic rams at 500 psi.
Weapon 2: Upward facing spikes on the wedge. A robot can go over them, but if it tries to reverse, say goodbye to your tyres. By wedging a robot then reversing suddenly, TMTHY can impale the tyres, then fire the flipper to do loads of damage. Even a robot with stuffed tyres will be limping after that.
Drive: Inner tracks, powered by Lem-130€™s at 24 volts.
Srimech: The flipper.
Strengths: Weapon synergy. Once The May Tracks Has You, there is no escape.
Weaknesses: Axe/flipper combos could take the tracks out.
The 6isc
Shape: Too complicated, apparently. See picture in the vapourbot images thread.
Size: 60X110X60 CM (LWH)
Weight: ~100 KGs
Speed: 10 MPH.
Ground clearance: Under the wheel protectors, it€™s 5 mm.
Weapon: 26 KG spinning disc, powered by one LEM 130 Lynch motor and going at 2500 RPM. The disc is shaped with its own teeth rather than needing teeth surgically attached to it, so dentistry is quite impossible. The energy output is 36 KJ€™s which, while modest by vapour €˜bot standards should still be enough to make a mess of things.
Wheels: 6 wheels, but four wheel drive. This has three wheels on either side arranged in a triangular fashion, so it only runs on four at a time. The wheels are 1 CM solid Ti with soft compound rubber wrapped around them to provide shock resistance, and a layer of Vulcalon wrapped around that to provide traction.
Chassis: The main chassis consists of one solitary 1 CM thick 4 mm box section hardox bar. Slotted over that is a secondary axle, inside which are the batteries. There are also two other triangular chassis€™ supporting the wheels. These are made from 4 MM 1 CM box section Ti bars with weight reducing holes.
Armour: The true axle and chassis is a 4 MM hardox bar. The battery axle is 2 mm aluminium. The semi circular wheel protectors and side spikes are 5 mm Hardox. The disc itself is 14 MM of Hardox 500, and the outer axle is 4 mm grade 5 Ti.
Srimech: Totally invertible. Controls won€™t even have to be reversed after flipping, meaning it can just go straight back on the attack.
Drive: 2 S28-400 Magmotors at 24 volts.
Strengths: The newest version of The 6isc does away with as many weaknesses in The Disc 5 as I could find.
Weaknesses: Weak armour in places. Can€™t use axe attacks.
Masamune
Shape: Barrel shaped, with a 20 CM long wedge at the front, with a sword blade extender. More on this a little later.
Speed: 15 MPH
Size: 80x50x25 CMs (LWH)
GC: 3 CMs at the sides and rear, 0 at the front.
Armour: 6 mm Hardox all over except for a 5 mm Ali baseplate. With the exception of the wedge, the barrel is made out of one sheet of hardox so there are no plates that can just be torn off.
Weapon: Retractable sword lifter. The sword blade can be extended 15 CMs out from the wedge to allow it to get under any spinner safely, or it can be retracted to extend only a couple of CMs from the wedge to allow it to lift with more control. The actual moving part s the wedge, which is powered by two linear actuators and should be able to lift around 200 KGs. It can also be lowered slightly, causing the sword to dig into the floor slightly resulting in it being able to get under even 0 GC wedges and skirts. The actual sword blade is made from 5 mm grade 5 Ti.
Drive: 4 internal wheels with vulkanised tyres, powered by two S28-400 Magmotors at 24 volts.
Batteries: 4 packs of 24 volt NiCads.
Shrimech: The rollover barrel shape. If it gets stranded against a wall, it can use the sword to push itself away.
My 3 entries are going to test my opponents to their very limits, in terms of how they fly and die, push and shove, and how they like being torn to absolute bits :proud:
Nitro-Gene 4.0 (seeded 3rd) [http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=17 7http://strickenone.proboards99.com/i...n=display&thre ad=177]
Knyfe [http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=18 6http://strickenone.proboards99.com/i...n=display&thre ad=186]
Inferno [http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=39 4http://strickenone.proboards99.com/i...n=display&thre ad=394]
I still say The May Tracks Has You could be even better if it had something on the top of the machine to trap robots from driving up and over :wink:
My stats are on ZED Dave :)
I will enter:
1- Apocalypse
2- Gulp 2.0
3- Duncan
Also Ben should know that Robo-Hedgehog is overweight
(Message edited by Swim2win on August 10, 2008)
Slammer
Black Panther
Achilles
http://www.alexjholt.tkwww.alexjholt.tk
Fine I will change Robo-Hedgehog for Robo-Goat
Seung Mina IV
Intriguer
Curse of Dread
Do you want the stats here or shall I just post a link to them?
Count me in.
Fatality
Weight: 100 kg
Body Shape: Cone.
Colour: Flourescent Blue Body with Turquoise and Green Teeth.
Dimensions: 96 X 96 X 42 cm.
Drive: 2 X S28-400€™s @ 24v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Tyres: 2 X Vulkanized Tyres.
Ground Clearence: 7mm all around. It has to be.
Armour: 6mm Hardox FBS shell, 6mm Polypropylene Base.
Turning Circle: Zero! Need I say more?
Weapon: A very nasty 36kg, 1500RPM FBS shell with 2 X 2kg Hardox Teeth and small Tungsten Carbide-tipped teeth all around, powered by an LEM-130 @ 36v. This can reach top speed in 2 seconds, and brings out about 80kJ. The teeth are curved, jagged, and barbed. Has a buttload of shock proofing inside to stop it from self-destruction. Holes drilled into it to reduce weight.
Srimech: An extremely blunt spike that comes out at the top, powered by 1 X 2kg CO2 Tank.
Strengths: Deadly Weapon, Fast Srimech.
Weaknesses: Weak Base Armour, able to shoot only 15 times with the srimech.
Mad Dash
Weight: 100kg.
Body Shape: Box with a front scoop.
Color: Chartreuse Body, Pure Black Scoop.
Dimensions: 100 X 90 X 36
Drive: 2 X LEM-130€™s @ 36v powered by 4 X NiCad Batteries.
Top Speed: 20 mph.
Tyres: 4 X Vulkanized Tyres.
Armour: 5mm Hardox for the scoop and 5mm Grade 5 Titanium for the rest.
Ground Clearence: Completely 0mm on the front and 6mm anywhere else. (including sides)
Turning Circle: Zero, what does it look like?
Weapon 1: Static Scoop to deflect other spinners.
Weapon 2: In the middle of the scoop, there is a Tornado-esque drum thingy powered by S28-150, spinning at 3220RPM.
Srimech: Invertible, Side spikes prevent it from getting beached on its side.
Strengths: Can run both ways up, EXTREME Pushing Power, Deadly Drum, Can get under anything, Shock-Proofed.
Weaknesses: So-So Turning.
Walk Don€™t Run 3€˜n a half
Weight: 110kg.
Body Shape: Disc.
Colour: Emerald Green Weapon, Snow White for top and bottom.
Dimensions: 95 X 95 X 27.
Drive: 2 X LEM-130€™s @ 36v powered by 3 X NiCad Batteries.
Top Speed: 13 mph.
Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
Armour: 6mm Hardox for the ring spinner, and 4mm Grade 5 Titanium for top and bottom.
Ground Clearence: 5mm all around.
Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its INSANE pushing power to ram other robots to death. Its also heavily shock-proofed as well.
Srimech: Invertible.
Strengfths: Deadly Weapon.
Weaknesses: Hates Flippers.
(Message edited by samuel3764 on August 11, 2008)
Samuel, as much as I myself dislike Dave Ss keep max. weight at 100kg rule :P, I will have to ask you to compensate Walk Dont Runs weight to make it 100kg, or else enter another bot.
Paralyzation 2
Weight: 100kg.
Body Shape: Low Box ala Tetanus Booster.
Colour: Gold.
Dimensions: 100 X 78 X 20.
Top Speed: 15 mph.
Wheels: 4 inner, Tightly Foam-Packed Wheels with Asmaprene Urethane on them.
Armour: 3.4mm Hardox 500.
Ground Clearence: 3.5mm all around.
Weapon: 19 kg Drum powered by a LEM-130 Lynch, spinning at 5000 RPM. There are 8 teeth, which are all curved upwards and jagged to rip and flip opponents.
Srimech: Invertible. Side spikes prevent it from getting beached.
Strengths: Deadly Weapon, and a Great Pusher.
Weaknesses: Exposed Tyres although very strong.
I still say that the spikes on May Tracks act like that. Since its a non-smooth surface, wheels cant get any proper traction to move more than a centimetre or so and very slowly. I only need them on the wedge for a second or two after all.
reserve first, ask questions later, seeing how bloody fast place are filling up :proud:
El Reservo Spaceo, pleaseo.
9 down, 8 to get (I think)
Wedge, Killy and Spin Dash for me, please, Dave. :)
STATS:
1. Wedge Devolution
SHAPE- low wedge with sloped rear
COLOUR- sleek and shiny silver
WEIGHT- about 100kg
DIMENSIONS- 90cm X 75cm X 30cm
SPEED- 16mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
ARMOUR- 4mm Hardox
WHEELS- inside robot, 4-wheel drive
POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
NOTES- flashing red light on top of robot, flies Scotland flag
STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
http://img166.imageshack.us/img166/7555/wedgedevolutionza6.pnghttp://img166.imageshack.us/img166/7...olutionza6.png
2. Killotine: EVO
SHAPE- compact box-wedge ala Storm 2, rounded back
COLOUR- red
WEIGHT- about 100kg
DIMENSIONS- 100cm X 70cm X 35cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front with spatula, 10mm at sides and back. Skirts at sides and back produce 0mm.
ARMOUR- 3.25mm Hardox
WHEELS- inside robot, 4WD
WEAPONS- The main weapon is the large pneumatic axe, composed of 3.5mm hardox. It is very similar to that of Killerhurtz and operates with a rack-and-pinion system like Terrorhurtz. Running on 160psi, the axe runs off an 80mm X 20mm ram and stores its gas in a 2kg main bottle and 1kg buffertank. If anything goes wrong with the axe, Killotine can use its great pushing power to simply ram its opponents to death.
SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. Also, just like the original Killotine, the machine has a rounded back and a red semi-sphere on either side of robot to stop it getting beached.
NOTES- flies the Scotland flag, thanks to Tom, Aaron & AJ for helping with the design
STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
WEAKNESSES- so-so turning, limited gas supply
http://img511.imageshack.us/img511/8806/killotineevocw0.pnghttp://img511.imageshack.us/img511/8...tineevocw0.png
3. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
SHAPE- skirted box, with rounded sides and back.
COLOUR- dark blue bodywork, with red-and-white striped skirting.
WEIGHT- about 100kg
DIMENSIONS- 100cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
ARMOUR- 4mm Hardox
MOVEMENT- inner, 6WD
POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
NOTES- flies Scotland flag.
STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
PIC- http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
Flick of the Wrist (or perhaps even Flick of the Wrist 2 :wink:)
Back to Rock III
Liar 2
http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
Gonna teach those kidnappers!
Cat With Wheels,
Crimson Thunder,
Sithis,
Stats in the same place as the two people above me.
Ben R
MC Franky G
Paul C
Liam
Alex H
Samuel
Mart
Dan (awaiting entries)
Stevie
AJ
Danny B
I make that 11 entries so far, so 6 more to get
Be patient Paul:lame:
Its really rich of you to say that when EOTR is going the way it is
Hey Paul
5 more entries to get, if not, I could also give out byes in round 1.
hi
can i reserve a place, i have 1 vapour done but my others are being upgraded
jack
Can you swap Nitro-Gene 4.0 for the latest model please?
http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=17 7&page=1http://strickenone.proboards99.com/i...n=display&thre ad=177&page=1
Of course, I dont mind any edits as long as they are done before the line-up is posted.
Few notes:
Height 200mm, Wheel diameter 180mm
The wheel diameter is now 210mm.
So the height is now 210mm?
(Height being measured from the ground to the topmost point of the robot which isnt the aerial)
Also:
quote:
The flipper has enough power to self-right Nitro-Gene 5.0 in a super stylish 540* somersault!
Thats nice to know, but what about 6.0 :lame:
You are so flippin petty :lame:
And I measure the height of the body so the ground clearance can be made clear.
Paul, why have you made a new version of Nitro-Gene? I thought you had just sorted Nitro-Gene 5.0 out in the How Could I Improve thread? What worries me more is that people were questioning the weight of it before. You seem to have responded by giving it thicker armour, bigger and heavier motors and slightly larger dimensions. Maybe I missed something along the way...
Larger dimensions = more air inside. Air is very light:proud:
...Ill get my coat:sad:
please look at the sheer paradox of this page, three completely different robots (Nitro-Gene 4.0, 5.0 and 6.0 respectively), one CLEARLY heavier than the other going after what the stats tell us, but all three have at least one thing in common
quote:
WEIGHT: 100kg
This is, by ALL means, physically impossible, you must agree with me on that Paul? Not more than ONE of these robots can physically be 100 kg, and a 100 kg robot is what this tournament requires :)
So the real question is, who is the real 100 kg heavyweight among these 3 robots? Pick your choice wisely Paul, as anything heavier will make your robot illegal, yet anything lighter might lessen your odds to win this tournament...
(Message edited by MajinB on August 19, 2008)
Paul, Simple question really, what are you thinking? It took me the best part of an hour to get Nitro-Gene 5 in weight and sorted and then you bring this on.
PS: You know Mini Kievs, on the menu, are they under starters or under main courses?
Would I have a backlash if I used a house robot in the first couple rounds?
