Eye Of The Robot - Series 5 Re-Opened
After Liams mysterious departure (without reason), Ive been advised by Kody that we need to do the sign-ups again. Here we are:
EYE OF THE ROBOT - SERIES 5
I first started fan-fiction writing in 2007, with E.O.T.R Series 1:
This was an achievement for me, with Series 1 having 72 robots, 71 losing, but one great robot winning called Killotine: EVO, belonging to Steven McGregor. Killotine intended to keep the crown, but he couldn€™t keep onto it, but another Steven McGregor robot was there to grab onto the title, and it got there by using its mighty ring of doom and using his 9 teeth to wreck carnage, as Whirligig 4.0 bashed its way to greatness! However, Whirligig nor Steven could keep the crown on his head, and instead It went to a rushing flip master belonging to Alex Holt called Kali! Kali wasn€™t able to defend the title, and the cup was taken by a powerful axe from Canada called Intrigue. Intrigue may bewilder us all again, but can he win again?
The line-up is going to be like this
HEATS
R1 - 2 x 3 ROBOT MELLES, TWO GO THROUGH
R2 - 2 x 1 ON 1, TWO ROBOTS GOES THROUGH
R3 - 1 x 1 ON 1, ONE ROBOT GOES THROUGH
SEMI-FINALS
R4 - 4 x 1 ON 1, FOUR ROBOTS GO THROUGH
R5 - 2 x 1 ON 1, TWO ROBOTS GO THROUGH
GRAND FINAL
R6 - 2 x 1 ON 1, TWO ROBOTS GO THROUGH
PLAY-OFF - 1 x ONE ON ONE
R7 (GRAND FINAL) - ONE ON ONE
Now for the arena:
The Arena
The €˜WreckTaGon€™ is a hexagon shaped arena with three starting squares, coloured gold, green and blue. Originally, it had very little in the way of hazards, and still does, but these are very deadly - we still have the flipping spikes, and we also have the impaling spikes, set in sets of 5 in each corner of the arena, each made of Hardox and designed to cause serious damage. The pit release button for this arena is located on the bottom right side of the arena, with the actual pit being a mere 1meter away from it. Added hazards include the saws mounted into the floor to throw other robots away, and vertical flywheels behind each starting square - they weigh 50kg and spin at 1200rpm, each giving 50kj each. The arena is indestructible, with the floor being made of 50mm Hardox, with 3mm of polished Stainless Steel over the top of that, making the floor impossible to damage and VERY SLIPPERY! The walls are also made of 50mm Hardox, and are 65cm high, giving everyone the ability to flip someone OOTA! The arena (from a birds-eye view) is 5metres down and 7metres wide.
The Entry-Rules
€ I need 12 people to enter 8 robots
€ You must have a MAXIMUM of 4 real-robots and MINIMUM of 2 (And the realies must NOT be earlier than Series 5 of Robot Wars and Season 3 of BattleBots).
€ Wheeled robots must weigh a maximum 100kg
€ Shuffling/tracked robots weigh a maximum of 110kg
€ Walkers weigh a maximum 135kg
€ When you enter, give me your hometown (if outside of the UK, tell me the country as well), and a link for your robot stats, so I can find them!
The Judging System
Basically, Ive invented my own system - has 6 catogories, in which I mark out of 10. I then times that score in each section by how much the section is worth:
Dominance = ? x 6
Damage = ? x 5
Aggression = ? x 4
Stategy = ? x 3
Control = ? x 2
Style = ? x 1
The Seeds
With 16 heats of 6 robots, giving us 96 robots, we have 32 seeds, and 2 seeds per heat:
HERE THEY ARE:
+1>1. Intrigue
2. Fire And Ice
3. Ramthrax 2 (6)
4. Storm 2 (4)
5. Kali (1)
6. Die-Ceratops ReInvertus (23)
7. Killotine: EVO (3)
8. Tengu VII (8)
9. Big Nipper (12)
10. Wedginator 6.0 (2)
11. Sithis
12. Cat With Wheels
13. Back To Rock 3 (27)
14. Psyclonised (9)
15. YACATR
16. Sheer Heart Attack 2 (30)
17. Turbo Tails (21)
18. Achilles (16)
19. Leprosy Infection (22)
20. Killobite 5.0
21. Gabriel V1.2
22. Wedge Devolution (7)
23. Atomic (19)
24. Wedga€™s Revenge (24)
25. Hoof (28)
26. Whirligig 4.0 (18)
27. Orka MK.4 (13)
28. Cyclone Force 2.5 (31)
29. Gravity
30. Shrederator
31. Panic Attack
32. Axes Of Evil
So send in your robots, quickly!
List Of Entries
1- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
2- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
3- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
4- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
5- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
6- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
7- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
8- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
9- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
10- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
11- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
12-???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
Good show, Paul. :)
1. Intriguing
2. Wedginator Devilution
3. Killobite 5.0
4. Super Gore Revo
5. Seung Mina IV
6. Tira IV
7. Envy
8. Shrederator
You know where the stats are. :)
Gimme some time and Ill throw some in.
Vapours:
Leviathan
Crimson Thunder
Lethal Execution
Blue Sparks
Cat With Wheels
Sithis
Realies:
Chaos 2
Onslaught
Vapour Stats are on the ZED board
Phoenix Down (2)
Gabriel III (21)
No Exceptions
Nidhogg
Eye Of Ran
QE2
Haardvark (S2)
Dreadnaut (S3)
are you gonna concentrate on this or on the Challenge Belt first Paul?
Sorry, Joey - you cant have any realies earlier than Series 5 of RW or Season 3 of BattleBots.
Ah, didnt read...
In which case:
Grannys Revenge (S5)
Tip-Top (S5)
Save me a place please, I might have a few new ones ready for this.
Now this is just be, but this whole you must have real robots is just getting a bit tedious now, it was only ever really implemented to protect seedings in tournaments where realrobots were seeds and as thigns like E.o.t.R started off with that system its just a bit disinteresting.
The problem is I couldnt care less if a real robot Ive entered has done well or not because its nothing to do with my own designing prowess. Almost any (with a few notable exceptions) real robots never do do well.... Now to say no robots before from before series 5 removes even the amusement factor from it...
Anyway, with that out the way
Ramthrax 2
Kali
Tengu VII
Achilles
Black Panther
Slammer VI
then errr.....
Firestorm
Panic Attack 24k
I understand that Alex, but since Timmeh used to enter all real robots, I had to put a restriction on that, but I also wished for some people not to use all vapours, so it was in that area, but since Timmeh is gone, next time (if theres a next time) I will remove the rules on realies.
Here we go again. :lame:
Representing Glasgow, Scotland:
TEAM BRAVEHEART:
1) Wedge Devolution
2) Killotine: EVO
3) Spin Dash Unleashed
4) Whirligig 4.5
5) E Clawdius Unum
6) Turbo Tails
7) Pussycat (RW7)
8) Mega Hurts L.T. (RW7)
STATS:
1. Wedge Devolution
SHAPE- low wedge with sloped rear
COLOUR- sleek and shiny silver
WEIGHT- about 100kg
DIMENSIONS- 90cm X 75cm X 30cm
SPEED- 16mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
ARMOUR- 4mm Hardox
WHEELS- inside robot, 4-wheel drive
POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
NOTES- flashing red light on top of robot, flies Scotland flag
STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
http://img166.imageshack.us/img166/7555/wedgedevolutionza6.pnghttp://img166.imageshack.us/img166/7...olutionza6.png
2. Killotine: EVO
SHAPE- compact box-wedge ala Storm 2, rounded back
COLOUR- red
WEIGHT- about 100kg
DIMENSIONS- 100cm X 70cm X 35cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front with spatula, 10mm at sides and back. Skirts at sides and back produce 0mm.
ARMOUR- 3.25mm Hardox
WHEELS- inside robot, 4WD
WEAPONS- The main weapon is the large pneumatic axe, composed of 3.5mm hardox. It is very similar to that of Killerhurtz and operates with a rack-and-pinion system like Terrorhurtz. Running on 160psi, the axe runs off an 80mm X 20mm ram and stores its gas in a 2kg main bottle and 1kg buffertank. If anything goes wrong with the axe, Killotine can use its great pushing power to simply ram its opponents to death.
SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. Also, just like the original Killotine, the machine has a rounded back and a red semi-sphere on either side of robot to stop it getting beached.
NOTES- flies the Scotland flag, thanks to Tom, Aaron & AJ for helping with the design
STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
WEAKNESSES- so-so turning, limited gas supply
http://img511.imageshack.us/img511/8806/killotineevocw0.pnghttp://img511.imageshack.us/img511/8...tineevocw0.png
3. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
SHAPE- skirted box, with rounded sides and back.
COLOUR- dark blue bodywork, with red-and-white striped skirting.
WEIGHT- about 100kg
DIMENSIONS- 100cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
ARMOUR- 4mm Hardox
MOVEMENT- inner, 6WD
POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
NOTES- flies Scotland flag.
STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
PIC- http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
4. Whirligig 4.5 (sort of formerly Whirligig 4.0)
SHAPE- flat disc
COLOUR- gold with Mauler-style scary face on top. The face shows the direction of the robot.
WEIGHT- about 100kg (see bottom)
DIMENSIONS- 101.6cm diameter X 12.7cm
SPEED- 15mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 8mm
ARMOUR- 1.905 cm thick Grade 5 titanium
FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
WEAPONS- The main weapon on Whirligig is the spinning outer ring, fitted with 9 x Pussycat-style claws. The spinner is powered by an LEM-130 running at 36v. It can reach speeds of 1000rpm and produce up to 100kJ...more than enough to kill another bot at full speed.
As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
NOTES- flies Scotland flag, thanks to AJ, my first properly calculated machine
STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
WEIGHT CHECK:
armour = 33.72kg (inc blades)
chassis, mounts, bracing etc = about 30kg
drive and weapon motors = 12kg overall
NiCads = about 15kg
feet = about 10kg overall
TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule. Probably.
http://img137.imageshack.us/img137/1297/whirligig45xt7.pnghttp://img137.imageshack.us/img137/1...ligig45xt7.png
5. E Clawdius Unum (formerly Clawdius Decimus Murderous)
SHAPE- skirted wedge with small box section and rounded back
COLOUR- deep green with red shield emblazoned on the wedge, depicting a gold lion with a crown
WEIGHT- about 100kg
DIMENSIONS- 95cm X 70cm X 40cm
SPEED- 14mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
ARMOUR- 4mm Hardox
POWER- 2 X S28-400 MagMotors
WEAPONS- The main weapon, as ever, is the hydraulic diamond-tipped crushing claw. It is powered by a Vivoil pump with an 80mm x 40mm ram, with a 2kg tank for storing the hydraulics. The claw runs at 3000psi and, aided by the diamond tip, should be able to leave plenty of holes in another robot.
The front wedge also features a Firestorm-style blade and two flat spears to aid in getting under the opposition. The wedge itself is now home to several Mute-style barbs to help ensnare other robots.
SRIMECH- A rear-hinged pneumatic arm on either side, powered by a pair of linear actuators. The rounded rear also prevents the robot getting beached.
NOTES- flies the Scotland flag, thanks to AJ, et tu, Brute? written on the underbelly
STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fairly quick srimech
http://img137.imageshack.us/img137/1801/eclawdiusunumor1.pnghttp://img137.imageshack.us/img137/1...iusunumor1.png
6. Turbo Tails
SHAPE- short box with front wedge, sloped sides & rounded rear
COLOUR- yellow with the foxs face looking particularly evil on the front slope
WEIGHT- approx 100kg
DIMENSIONS- 100cm X 75cm X 25cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- approx 0mm at front (titanium blade), 8mm everywhere else
ARMOUR- 3.5mm monocoque Hardox, with 2mm yellow fur over that.
MOVEMENT- 4 inner wheels
POWER- 2 x C40-500 MagMotors. Can produce approximately 12hp.
WEAPONS- Tails chief weapon is the horizontal spinning blade. Now mounted on top, its a bit heavier than before and has Fluffy-style heads instead of the old hammers. Its powered by an LEM-130 running at 36v and has top speeds of around 2500rpm, so its definately just as deadly as before - if not, more so!
The front wedge also hosts a forward-hinged flipping arm, powered by an 80mm x 20mm full-pressure CO2 ram. The arm operates at 750psi, giving it a fair bit of oomph, and stores its gas in a 2kg main bottle. Capable of just over 30 fires per fight.
SRIMECH- The flipper. Sloped sides and rounded rear also prevent it getting beached.
STRENGTHS- weapons synergy, touger armour, fast, fairly compact, greater pushing power
WEAKNESSES- not quite as manouverable as before, flammability, wholl take it seriously?
http://img84.imageshack.us/img84/7952/turbotailslongered5.pnghttp://img84.imageshack.us/img84/795...slongered5.png
Ill enter whoever I entered in EOTR 5.
Gonna enter the ones from Wet N Wild here along with Bulldog Breed and X-Terminator 3.
http://strickenone.proboards99.com/index.cgi?board=wwvapourshttp://strickenone.proboards99.com/i...oard=wwvapours
Decided. Just enter whom I entered in the previous tournament...with the exception of the real robots. The robots entered there will be Hexadecimator and Kan Opener.
Ill enter the same robots I previously entered in EOTR 5
Frank, you need to pick another realie, as you originally entered FireStorm, but Alex has entered that.
No no no, Martijn, you have to put that in bigger letters so that he can see it. :proud:
(Message edited by kodster on June 14, 2008)
Liam is imminently returning! The world is saved! He wants a space reserved :proud:
as you wish Kody
quote:
+2>are you gonna concentrate on this or on the Challenge Belt first Paul?
in other words, if you finish the challenge belt first, reserve me a spot
...Can I just kill Alex and take Firestorm from him?:)
Meh, Ill enter Warrior SKF simply to screw Aaron up should he want to enter:proud:
If I was that easy to kill do you reckon Id still be around now?
I killed Alex ages ago and have been replacing him for quite some time now
he loves you
Well yeah, because if you were that easy to kill you wouldnt be a threat and thus not worth killing.
Paralyzation
Shape: Box with low wedge
Weight: 100kg
Dimensions: 99 X 94 X 40
Batteries: 6 X 36V 3.6ah NiCad BattlePack
Drive: 2 X MagMotor S28-400 each at 24V
Wheels: 4 X Foam Packed Wheels with a thin layer of vulkalon rubber on them
Top Speed: 19 mph
Ground Clearence: 0mm at the front, and 3mm on sides and back
Armour: 3.23 mm Hardox
Weapon: 19kg Spinning Drum with 10 teeth Powered by a 24V LEM-130, spins at 4600 RPM
Srimech: Why should it? Its invertible.
Strengths: The Drum, Good Control, Foam Packed Tyres, Hard to Approach from the Front
Weaknesses: Exposed Tyres...
Turbo Shredder
Body Shape: Box
Weight: 100 kgs
Top Speed: 15 mph
Dimensions: 96 X 93 X 42
Armour: 4mm Stainless Steel All Around
Ground Clearence: 3.2mm all around
Wheels: 4 X Wheels Inside (Aluminum Hub)
Power: 2 X Lem-130s running on 36 volts
Battery: 4 X BPK-3600-36 BattlePacks
Weapons: A very nasty 19kg, 3800RPM horizontal spinning disc powered by a LEM-130 on 24V, capable of dishing out 30KJ
Srimech: Invertible
Strengths: Powerful Weapon, Great Pushing Power
Weaknesses: None Hopefully
Death Wish 2
Body Shape: Just a simple Box with rear wedge
Weight: 100kg
Dimensions: 90 X 85 X 30
Drive: Steel Tracks with Vulkalon rubber powered by 2 X LEM-130
Batteries: 4 X 36V NiCad BattlePacks
TC: Zero
Top Speed: 19 mph
GC: 0.0014mm at the back and 4mm anywhere else
Armour: 4mm Hardox
Skirts: A Titanium skirt on the rear
Weapon: At the front, there is a big and devastating 21kg Horizontal Spinning Flywheel powered by a Honda CR125 Motorbike Motor. Its top speed is 9000RPM. It is deadly within 2 seconds.
Srimech: None, but Invertible and rounded sides and back help it not to get stuck
Strengths: Devastating Name and Weapons, Extremely Sturdy Tracks
Weaknesses: As usual, the tracks might be exposed to axes or crushers (Although Very Strong and Sturdy)
Drum Boy
Shape: Barberous 2 and a bit
Colour: BLACK
Weight: 100kg
Dimensions: 96 X 42 X 42
Armour: 8mm Titanium
Wheels: 2 X Tightly Foam Packed Wheels with Hardox Hubs, based on Stinger
Drive: 2 X C40-500 Magmotors Powered by 4 X 24V NiCad BattlePacks
Speed: 15mph
Ground Clearence: 6.8mm All Around
Turning Circle: Zero
Weapon: 19kg Full Body Drum with 8 X Grade 5 Titanium Teeth, a bit blunt and curved upwards. Its powered by 2 X LEM-130s and spinning at 3000RPM. This also spins upwards to flip AND damage opponents at the same time.
Strengths: Invertible, Flipping it does nothing at all, PSYCHOTIC WEAPON!!!!
Weaknesses: Although EXTREMELY sturdy, wheels kind of exposed.
Revenge of Black Death
Shape: Box with wedge
Weight: 100kg
Armour: 4mm Hardox
Dimensions: 90 X 87 X 30
Drive: 2 X 24V LEM-130
Wheels: 2 Aluminum Hub Wheels with a thin layer of urethane rubber
Top Speed: 19 mph
Batteries: 4 X 24V NiCad Battlepacks
TC: Zero
GC: 0mm on front, 5mm on the back and sides
Weapon: Flipper powered by 2 X CO2 Fire Extinguisher Tanks, 13kg Laser-Cut, Horizontal Flywheel with 4 curved teeth on the back powered by a single LEM-170, spinning at about 4000RPM
Srimech: Flipper, Flywheel on the back and sloped sides prevent it from getting beached.
Strengths: Flipper, Disc, Good Pusher
Walk Don€™t Run 3
Shape: Disc Shaped
Weight: 110 kg
Armour: 6mm Hardox for the ring, 3.5mm Hardox for the top and bottom
Dimensions: 89 X 89 X 20
Drive: 4 Shuffling Pads with 6 Legs with vulkalon rubber
Batteries: 5 X 24V NiCad BattlePacks
TC: Zero
Top Speed: 13 mph
GC: 3.8mm
Weapon: A 32kg Spinning ring with 2 X 2kg Hypnodisc style teeth, but more larger and more curved, Spinning at 2200RPM powered by a 36V LEM-130, has an absolute buttload of shock proofing inside to stop it from self-destructing.
Srimech: Its Invertible
Strengths: 360 degree Killing zone, EXCEEDINGLY DESTRUCTIVE!!!!!!, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH
Weaknesses: Almost invincible, but does not like flippers, although invertible
Axetra
Weight: 100kg
Shape: Box with skirts and a Firestorm-style Low Front Wedge
Dimensions: 97 X 83 X 42
Armour: 3.6mm Hardox
Power: 4 X 36v NiCad BattlePacks
Drive: 2 X S28-400s
Wheels: 4 X Vulkanised Tires
Ground Clearence: 6mm without skirts and 0mm with skirts
Top Speed: 15 mph
Turning Circle: (Seriously, does this need to be here?) Zero
Weapon: A great big 200PSI 9kg axe powered by the same system that Terrorhurtz uses, capable of dishing out 1000kg of raw force, diamond coated blade to maximize damage. Can dent hardox easily.
Srimech: Axe, Round back and cylinders on sides prevent it from getting beached
Strengths: Can still push if axe fails, Can cause a lot of damage
Weaknesses: Only limited to 50 hits
I will also enter Gravity.
My bots will represent Vancouver, British Columbia.
(Message edited by samuel3764 on June 16, 2008)
Paul i want my vapour at ur tournament so heres my vapours
Name: Texas Chainsaw Massacre 2
Shape: Sewer Snake (new version lifter)
Colour: Grey
Speed: 28MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Power: 4 12v battlepacks giving 48 volts total
Motivation: 6 Battle Tread Carefree Wheels
Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 1,14 x 76 x 46m
Weaponry: Lifting Tusk powered by a 7hp 2-stroke STIHL disc cutter engine the tusk is made from S7 Tool Steel and heat treated to give it maximum strength and can lift 500-800kg up to 1.2 meters about the ground
Self-Righter: Invertible
Strengths: Powerful Lifter good armour, speed
Weakness: exposed wheels
Name: Psycho Killer 2
Shape Tornado (RW 7)
Colour: black
Speed: 24MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x LEM130 at 36v.
Power: 6 NiCad Battle Packs at 36v
Motivation: 2 TI Tracks w/ 1inch custom made raptor claw for grip (inside of the robot)
Ground Clearance: 0mm on the front 1mm on both sides and 1mm on back
Dimensions in CM (Length x Height x Wide) 75cm x65cm 20cm
Weaponry: crushing/lifting claw powered by a modified chainsaw engine driving a hydraulic pump at 2000psi it also has 2 custom made TI wedge on front to help get its opponents to the weapon with ease.
Self-Righter: invertible but can self right with weapon
Strengths: Powerful lifter, good armour and speed
Weakness: Hates spinners
Name: The Grudge 1
Shape: Suicidal Tendencies
Colour: Black
Speed: 18MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x S28-400 Magmotors @24v
Power: Four 12v, 16Ah Hawkers
Motivation: Custom Made titanium tracks w/rubber strips on it for grip
Ground Clearance: 2mm
Turning Circle:0
Dimensions in CM: 1.38m x 0.74m x 0.70m
Weaponry: Pneumatic stinger powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2200 joules at end of swing
Self-Righter: The Stinger has a spike on top that pop out to self right the machine Strengths: Powerful weapon, good armour and speed
Weakness: exposed tracks from the back
Thank Rurak, but you need at least one more vapour and 4-2 realies.
I also need entrants from Chris and AJ and were set to go.
paul, if youd be so kind to PLEASE anwer my question, I asked it only 4 times so I understand its easy to overlook, but still...
(Message edited by MajinB on June 16, 2008)
And what question would that be Martijn?
:rofl:
I dont believe theres a bigger font available than the one I used last time...
anyway
verdanaarialhelvetica>+2>are you gonna concentrate on this or on the Challenge Belt first Paul?
Ah, I have the solution for that:
http://www.insaneclown.nl/vapourbots/paul.phphttp://www.insaneclown.nl/vapourbots/paul.php
PAUL.
+2>STOP DODGING MARTIJNS QUESTION.
Name: Revenge of the Zombie 2
Shape: Cross shape box with rounded back and has 4 TI spikes on robot 2 in the middle of robot and the other 2 on the back for ramming
Speed: 20MPH
Weight:220lb (100KG)
Armour: 5mm Titanium
Chassis: Titanium
Drive Motor: 2 x LEM130 Lynch Motor
Power: 4 x 30cell 36v 3Ah Sanyo NiCad Packs
Motivation: 4 Nightmare style tires w/ welded TI spikes
Turning Circle: 0
Dimension in CM (Length x Wide x Height:) Unknown
Weaponry: Bulldozer blade on the front made out of Titanium w/ 2 raptor claws on top (to give it a meaner look)and a Pneumatic axe powered by a 4kg liquid CO2 dual high-flow CO2 regulator 250mm stroke, 100mm bore pneumatic cylinder develops 900kg of force and 2300 joules of energy direct rack-and-pinion drive 5 liter buffer tank
Strenght: Revenge of Zombie 2 has the speed and Push ability of Storm 2 and has one of the most powerful axe
Weakness: Hates powerful Spinners
Self-Righter: Axe
Note: Revenge of Zombie has 3 interchangeable axe heads made out of S7 Tool Steel
Colour: Grey
Speed: 28MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Colour: black
Speed: 24MPH
Armour: 6mm TI
Chassis: Titanium
Name: The Grudge 1
Colour: Black
Speed: 18MPH
Armour: 6mm TI
Chassis: Titanium
Turning Circle:0
sorry dont have any relies yet
What Paul means is to pick realies from the main wars, you dont have to had built them
indeed Ruark, pick whatever realie you want...
Paul?
