does anyone know the easiest way to
get a ram to operate on full pressure for h/w
robot similar to the likes of kronic,turbulence
where the rod of the ram does not connect to the flipper, Its a bit much for me to try and pull
cylinders apart and remachine ends etc Id probably blow it all up !!
There must also be robots that use normal cylinders moded for the full pressure that are connected to the flipper like a vdma 16bar,
would this be easier to do ??
valves and pipes are no probs and my buffer will
be a 2kg bottle.
Cheers
Terry.
