Ready made robot shell
my sponsors have made a robot shell and put it on ebay link below (very reasonable) if the postage is a problem then if its ok with stedmark i can drop it off at an event
specs;
3mm mild steel
total weight 4.5kg
welded inside and out
100mm high
380mm long
255mm wide
http://cgi.ebay.co.uk/Robot-outer-shell-armour_W0QQitemZ120219187510QQihZ002QQcahttp://cgi.ebay.co.uk/Robot-outer-sh...10QQihZ002QQca tegoryZ294QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
happy bidding!
get them to come fight it! :)
It needs to be Gary proof!!!:rofl:
3mm mild, I dont think so. 5 or 6mm hardox might just do the trick thou.
To be honest - you would probably be more than fine with 3mm anyway - spinners might tear bits off - but wont go in deep enough to get the juicy bits.
I dont need to get into the juicy bits :)
Is there an option to fit Wings, for Gary,s flying lessons.:mrgreen:
I am looking at this and wondering if there is enough space inside for some motors, batteries and after a bit of modification a pneumatic flipper.
Obviously, it depends how you build it but anyone got any comments?
Andy
Looking at it there should be room inside. It looks well made and deffinatly enough room for a pusher.
definitly well made, and even if it idi get torn a bit its quite cheap
are you thinking of buying andy?
Yes mate, seems ok and relatively easily to adapt to what I need.
Andy
(Message edited by widow twanky on February 08, 2008)
was it anyone on here who ended up winning it?
Well ...with an ebay handle of boudoirbabe it narrows the field a little.
Its a boy from Richmond, London. He is active on the http://www.robotwars101.orghttp://www.robotwars101.org forum.
I must admit it got to the point that I may as well buy me an arc welder and do it myself. Still looked good though.
if you arestill looking for armour andy, if you drop me an email of exactly what you want im sure you could agree a price with stedmark
if you want a look at one he made for me im goin to barnsley
alex
