New Teamdragon Web Site
Hi all new web site now up
More to be added later.
would just like to ask every body if they would like to add there bots to the data base.
If you would could you send me a pic of your bots no larger than 100kb and its stats Weapon Drive armour controllers, power etc. web site address
Regards Tony.
Yeah it looks pretty cool. Hate to be a pain but just thought Id post updated specs of Drumroll here as theyve changed a bit since I filled out those forms at the Eurochamps :)
Robots Name. Drumroll
Featherweight
Weapon. 2.5kg Spinning Drum
Weapon Drive 2 x HTIs
Drive. 2 x 12v Drill Motors
Esc. Electronize 15A
Armour. Nylon 6, Hardox and Polycarb
Power. 2x 9.6V 3700mAh Ni-mh in series
No rush to change them, just whenever youve got spare time :)
Very nice Tony. Funny how hornet 2 has changed even since then :) I will send you an update in the next couple days.
Come on guys and gals get them pics and stats sent
Pillow & Small Torque are both undergoing rebuilds so as soon as they are ready I will send the details.
-2>BTW in the meantime the Pillow Torque website front page currently shows a couple of chicks with guns :)
Tony, Hannibalito 2 was sold to Andrew Mahony and is now called Wedgie.
So we have built Hannibalito 3
Full pressure flipper
Ram 1 tonnes of force
Flipper 175kg of force on the tip
10mm HPDE armour all round with Leather mask
Drive 2x Graupner speed 900, 70mm wheels 6,5:1 gear ratio
Scorpion XXL speed controller
13,2V A123 battery power
http://i172.photobucket.com/albums/w13/Babetheke/Robot%20Wars/H31.jpghttp://i172.photobucket.com/albums/w...20Wars/H31.jpg
And of course the First one also still exists and runs:
Hannibalito 1
2x Speed 900 drive,
4.5:1 gear reduction to 90mm wheels.
Scorpion XXL speedo.
3700mAh NiMH 12V pack
Armour: 10mm HDPE schell allround, 5 mm HDPE at the bottom.
Weapon: FP flipper 32mm bore x 75mm stroke. Compared to other flippers not a powerhouse, but extremely reliable.
This robot changes shape quite often, its latest incarnation looks like this:
http://i172.photobucket.com/albums/w13/Babetheke/Robot%20Wars/HannibalitoI-Vlinksvoor.jpghttp://i172.photobucket.com/albums/w...ibalitoI-Vlink svoor.jpg
Still needs its trademark scoop.
(Message edited by leorcc on January 08, 2008)
Hi Leo
thanks for info all changed, now about your heavyweights
come on you lot get your pics and stats for your bots sent PLEASE
tony, mine are all in bits at the mo lol, will send you my specs/pics when they are all back together.
email sent to the address on your profile. Let me know if you dont have it
Ill post my stats and pictures on heavies soon Tony.
Ill place our active heavies only, not the ones that are still in pieces for (re)build or went to that great scrapyard in the skies. :)
Obsidian
Axe robot.
2x bosch GPA750 @ 24V
Kart wheels for drive, chain and sprocket gearing
Sidewinder Dual motor Speed controller
Axe powered by 2 62mm bore cilinders at 16 bars.
It is now still running with Nitrogen, but will be convertd for CO2.
http://www.computerclub.nl/uploads/obsidian/obsidian12.jpghttp://www.computerclub.nl/uploads/o...obsidian12.jpg
Mantis
Hydraulic Crusher and lifter.
100mm blickles wheels for drive, angled gears for reduction
Hydraulic system with 2 rams, 1 for clamping/crushing, 1 for lifting the opponent.
http://www.computerclub.nl/uploads/mantis.jpghttp://www.computerclub.nl/uploads/mantis.jpg
RCC2
Steel jaws.
2x Reliance electric motors @ 24V
Trolley wheels for drive angled gears and chain for 8:1 reduction
Sidewinder Dual Motor Speed Controller
CO2 powered jaws, 1 62 mm cilinder.
http://www.computerclub.nl/uploads/rcc2.jpghttp://www.computerclub.nl/uploads/rcc2.jpg
Drone
Hittable object
Sparring partner robot for other robots to take a shot at.
2x wheelchair motor 250wat @ 24V
4QD ncc-70 speed control
Thick steel and HDPE armour all round
No active weapon.
Will take a picture soon.
(Message edited by leorcc on January 21, 2008)
