Size
hi
my new featherweight that i am planning is a scaled down version of daves turbulance and i was just wondering wat some of the other featherweight sizes are to see how much i need to scale it down so it doesnt end up half the size of everything or twice the size of everything:P
Size
Our two feathers are roughly 40x40cm. One is 15cm high, and the other is 9cm. 40cm seems to be the average length I make mine to for some reason (might have something to do with the RRC size limits if I remember rightly)
It was quite interesting to see scaled down feathers such as RIP and TKM2. When I saw them both I thought TKM2 was really small for a feather and RIP was kinda big for a feather. If you build yours somewhere in between those sizes it should be fine :)
Size
Easiest way to do it is to get all your bits together and lay them out as you would like them in your robot. The size will be fairly obviouse to within a few centimetres!
It also depends whether you want thicker armour. The smaller you make it, the thicker you can have your armour. Thats why mine has a few mm between most of its components lol.
Size
it is gunna be 50cm long 35 wide and 18 high
Size
sounds pretty good to me!
Size
Size
The sizes of FWs are variable to say the least - I would say that Pillow Torques length is comparable with Rips height at the back. There are no size limits in the FRA build rules just as long as it stays within weight (currently 12kg) - of course when you get the essentials in there (batteries, motors etc), the rest is yours to play with. Although clean air may save you some potential damage by putting vitals out of reach, you have to weigh up (scuse the pun) the pros and cons of the type and thickness of armour you can put on there - it may mean that the dimensions may have to change to accommodate it all.
BTW PT is currently 500 x 330 x 100 mm (50 x 33 x 10 cm)
Size
could be smaller, tell geoff to get the hacksaw out :)
Size
Wait and see - but not yet :wink:
Size
Venom is 450mm x 270mm thats without the arm. Predator is 270 x 260mm. thats without the arms head and tail ( the parts that stick out but dont have anything in them lol)
Size
Tanto (HW)is 430mm long, 520mm wide, and 250mm tall hows that?
Size
LOL, thats tiny!
as i mentioned, the smaller you make it, the more weight you can spare for thicker armour!
Size
Size
Yeah, but 15mm of what? 15mm of hardox offers a bit :wink: more protection than 15mm of polystyrene although the snowstorm isnt anywhere near as impressive. The snow also provides an effective screen for escape :proud:
(Message edited by anukhet on July 25, 2006)
Size
hardox it is (hideing his polystyrene chassis)
Size
Size
Size
my robot size is 40 cm l, 30 cm w, 15 cm h.
Size
ploughbot is 300mm by 500mm altogether
Size
tantrum is 550mm diameter
yes, thats big for a feather
Size
Joshs dimenshions are a half scale of the real Turbulences dimenshions i gave him.
Josh your ram is half complete.
