Team Gore Presents: House Bot Rebellion!
Thats right! A house robot rebellion! With the help of Anthony Politzi, I have acquired 8 deadly terrors for my next Crash & Burn tournament.
Since I am running late on something, I can only give their weight and names. Their names are...
Exa-GORE-ic (weight: 350kg)
Smaug the Golden (weight: 600kg)
Tira (weight: 125kg)
Taki (weight: 125kg)
Asterix (weight: 105kg)
Obelix (weight: 200kg)
Big Mac [Macbeth] (weight: 175kg)
Whamlet (weight: 150kg)
I wish to test out these robots, so Ive set up this little 7 fight tournament to see what happens.
So...I need 8 people to enter one vapourbot each. NO VAGUE STATS. Rules are the same as the Crash & Burn Tournament.
The tournament will be a tag-team terror. Two house bots will team up against a vapoutbot team. You may choose who you may team up with.
The house robots will be introduced in more detail later. You may reserve spaces if you wish to find out whos what.
Get this party started! :proud:
hmz, anyone fancies a team up with moi?
I will Martijn. Ill enter The Disc 5 for this. As I dont know what were up against yet, I thought Id enter the most slippery bugger Ive got:proud:
Save a place for Radio Friendly Unit Shifter...Ill be bothered to find the stats later.
Here they are:
http://teamcode14.proboards24.com/index.cgi?board=tonystat&action=display&thread=114 3769998http://teamcode14.proboards24.com/in...display&thread =1143769998
And here they are!
EXA-GORE-IC - the one guy you dont wanna have a pint with! :proud: With both hardox-tipped horizontal titanium crushing claws and axe, 15mm hardox 650 armour, the ability to lift his claws 60 degrees to hinder movement, plus an evil Freddy Krueger-esque face design on the front, if you come in contact with this fearsome foe, itll be the last time you ever do!
SMAUG THE GOLDEN, back from the Hobbit, is here to cause chaos in not just snuggly little dwarf homes! :proud: With 25mph on the table, he can give you a run for your money! Also, this demonic dragon sports Growler-like jaws with fangs that can crush titanium like a tin can. Through these same jaws, flames can be emitted through a gasoline system deep inside. Whats more, Smaug has three discs at his disposal: two veritcal ones in front, and a big horizontal one at rear. His + shape means that no opponent can merely slip by him! Add three pairs of spikes on the sides, and ornamnetal wings on top, and youve got yourself a pretty nasty combination!
NOTE: This is the greatest House Robot here.
Making her way into the line-ups is TIRA, an Ankle Biter-(not Matt Robinsons but the Battlebots middleweight)-shaped seductive little thing. If the green and purple feather design doesnt get your attention, then the 5000rpm vertical flywheel with three pointed hardox-tipped spikes will! Going at 20mph, she also uses a vacuum system to stay on her wheels after a blow. FEAR HER!
And fear this chick-bot, too. TAKI is Rammstein-shaped, but with an upside-down wedge on top of the other wedge (think ===). Not only does she have great strength and traction, coupled with 30mph top speed, but she has two spikes attached to the front, 45cm apart. If she desires, shell have a jawpiece on inside of the front-end design, like in SC III. The she-ninja hath awakened!
Dont count the gauls out! :proud: Represnting a little village in the times of the Roman Empire, ASTERIX, the smallest of the HBs, is also the fastest, at 45mph. Shaped like Bad Attitude, he also has a steeper wedge, 80 degrees from the ground, and aerodynamic lines on the sides that improve speed. And when Asterix plows into an opponent...by Toutatis, hold onto your hats! :proud:
Almost never seperated from Asterix is OBELIX, who is shaped like his buddy, but twice as large! He does moves a third of Asterixs speed, but watch out for that pneumatically-powered hammer! Having the head shaped like a menhir (a giant, egg-shaped rock; but this head is made of hardox), Obelix has HUGE damage capability.
NOTE: Both Asterix and Obelix have ornamental viking hats and moustaches. Asterixs moustache is golden whilst Obelixs is brown.
Flying the Scotland flag is Macbeth, codenamed BIG MAC! A low-cone shape, he is the slowest bot here, but thats alright: he has a highly destructive spinning with four spinning spiked hammers attached. Either the opponent will be:
1) Destroyed instantly
2) Flung across the arena
3) Both :proud:
NOTE: Macbeth wears a crown on his conehead. :proud:
Last but not in the least bit least, WHAMLET is here to cause more pandemonium than a bull in a china shop! :proud: Shaped like Shunt and capable of 30mph, like Taki, Whamlet also has a slanted flipping plow that can send a robot of its own weight (150kg) across the arena in a single toss!
NOTE: Has To wham or not to wham written in two lines on its sides.
And the Refbot, THE WATCHER, is armed with a fire extinguisher, 6 blazing red eyes [YES, SIX :proud:], and a lifting arm that lifts opponents into the air, or even house robots if theyre getting too naughty :proud:.
NOTE: The Watcher weighs 200kg.
Currently reserved
Frank Goacher - The Disc 5
Martijn Benschop - (reserved)
Anthony Politzi - Radio Friendly Unit Shifter
Five more, please. Well how are my house robots? :proud:
*insert evil laugh*
*insert evil laugh echo*
does it have to be a vapour.
a team-up with The Disc, I can live with that :proud:
lets see, given the fact Im teamed up with that discy thing, going with A Night at the Bar or Sheer Heart Attack myself seems overkill
I think Ill be going with Flick of the Wrist for this one
Name - Flick of the Wrist
Shape - 6-wheeled Tornado, including the angled rear to keep in contact with the ground while driving up a wedge
Weight - 100 Kilogram
Speed - 35 km/h (22mph)
Dimensions - 120x80x20 cm
Ground Clearance - 10 mm under the main body, variable clearance under the lifting spikes, with 0 mm as a minimum
Power - 2 B42-500 Magmotors at 48 volt
Movement - 6 wheels for awesome traction
Turning Circle - Zero
Weaponry - A pair of hardox, diamond tipped electric lifting spikes, a lot like the lifting spatula of American SHW Vladiator. These are 25 cm in length and can be lifted downwards which turns them into an active invertible lifting wedge. They can also be raised parallel to the floor, so they can act as a pair of classic ramming spikes. A 100 kg robot driving around at 22 mph is good for 5 kJ of kinetic energy. When this is brought onto a pair of diamond tipped spikes, this might seriously harm some armours.
Armour - 7 mm titanium all around
Srimech - It€™s invertible
Strenghts - High speed rambot, awesome traction
Weakness - Lack of devestating weapons
Here€™s a picture: http://jupiter.walagata.com/w/madbull/Flick.gifhttp://jupiter.walagata.com/w/madbull/Flick.gif
Fancy a RFUS and Aneurysm team up Tony?
Name - Stop crying your Heart out
Shape - Box with spikes on the top and spikes along the sides.
Weight - 100 Kg
Speed - 8 mph due to gearing to give torque and nifty power output
Ground Clearance - 3cm around the sides and rear, front scoop reducing the front clearance to 0.4mm.
Power - 2 LEM 130 motors, one powering each side. The motors are set at the rear of the machine, connected to the rear wheels by cogs and the front wheels by chains and reverse cogs to counteract the loss in timing.
Movement - 4 wheel drive, simple.
Weaponry - At the front, there is a flipper, powered by co2, which can self-right the beast if it needs to.
Armour - Under the titanium spikes, there is 5mm titanium armour all over, with foam inside to protect the inners from shocks. The chassis is steel.
Srimech - The flipper can self-right the beast
Colour - Brown with red tips on the spikes for protection.
Strengths - Drive system gives good torque, has falling cheese protection
Weakness - Will only last 10 minutes before going into a ball of flames
...if you have to ask that, then youre not entering. :P
Btw, YES, IT HAS TO BE A VAPOURBOT
(Message edited by kodster on April 01, 2006)
Im so tempted to ask if I can enter a superheavy....
But on the assumption that Im not - archangel
http://www.alexjholt.tkwww.alexjholt.tk
Sure thing. We can come on over, shoot the $[-]1t, and then cover whats left with a blanket acned with ciggarette burns. :proud:
So yeah. Aneurysm and Radio Friendly Unit Shifter it is.
Ill enter Bere stats in the vapour footy cup.
BE MORE SPECIFIC. :lame: And besides, I already told you that you couldnt enter, so I wouldnt accept it anyway.
Why couldnt I enter:angry::sad:.
Because you cant read the rules: It was clearly stated that you had to enter ONE vapourbot. If you have to ask a stupid question like that, then you shouldnt be allowed in. It isnt that anybody likes you anyway: Take a hint. Your stats suck, you spam, you act like a complete 6 year old, and every single person on this community hates you.
Stop plugging up the forums and just LEAVE. Myself, along with everybody else have just had enough of you. You are nothing but a hinderance here and you need to shape up or ship out.
Maybe he is. :S
Okay, the spaces filled are:
Martijn Benschop - Flick of the Wrist
Dave Sheppard - Stop Crying Your Heart Out
Andy Jackson - Aneurysm
Alex Holt - ArchAngel of the Abyss
Two more.
Ok, ok, ok I dont care if I get banned for life but Im actually 11 years old.
Ah. That explains the stupidity.
IF we could continue, I need 2 more people to enter.
If I could continue umm Forgot it.
I wasnt talking to you. Now get out of my thread before I go to Admin :angry:
Billions of people threaten me so dont think a retarded middle-class sealclubbing snob like you can stop me.
GET IT THROUGH YOUR DUMB-ASS HEAD. NO ONE LIKES YOU. YOURE A WASTE OF SPACE. EVERYTHING ABOUT YOU IS BAD, B-A-D, BAD. WHY THE HELL WOULD YOU WANT TO BE ON HERE IF EVERYONE HATES YOU ANYWAY?
YOURE JUST TRYING TO MAKE US ANGRY. WELL, INSTEAD OF GETTING ANGRY, I HAVE JUST CONTACTED ADMIN. SO ENJOY THE LAST DAY OF BEING ON THE FORUM, BECAUSE IT WILL BE YOUR LAST.
By the way, me and Anthony have been bashing you on MSN Messenger anyway, having a grand ol time. Just thought youd want to know that.
*Round of applause*
Just about sums it up, well done Kody and Tony.
*bowbowbow*
All right, I have set up the teams for the HBs, but the tournament still needs two more people.
1. Smaug & Big Mac
2. Exa-GORE-ic & Obelix
3. Asterix & Tira
4. Taki & Whamlet
Ummm hate to spoil your party but Im still here.
ENOUGH! WILL YOU JUST GET THE HELL OUT OF HERE AND LET ME START MY FRIGGIN TOURNAMENT?!?
Thank you. If two more people do not enter within the next three days, then I will put Typhoon 2 and Biohazard in as a team.
*before Tim has a chance to say it* Yeah, yeah, I know, I said only vapourbots but since nobody else is entering and Tim has crappy stats...
Why dont you just do Storm 2 and Biohazard not crappy Typhoon 2.
Tim, when you build a championship winning robot you might just have the right to call Typhoon 2 crap. Until then, give it a rest and stop pestering Kody please.
Actually I want to build a robot tech freak AJ but my dad wont let me.
Why did you call me a tech freak?
A) Im not one
B) There is no such thing
C) There was no reason to say it
My message is, never say wont let. A lot of people doubted Id ever build a robot, but I have because I ignored all the they cost thousands of pounds and youre not an engineer.
Ill say it again, until you build one dont slag other peoples work off, whether it being vapourbots or the real things. Now either start the way we all did by building up in a mature manner as a respected vapourboteer or simply clear off and stop annoying everyone here.
Sorry everyone, but Im sure you all agree the message needs putting through.
Yes, it does. Thank you very much AJ.
No im just calling you a tech freak because you along with some people in the old PA forum moan about the amount of batteries and every Freakin thing.
Yeah 500th post:angry::angry::mrgreen::mrgreen::blush::blush: :crazy::crazy::):):kiss::kiss::lame::lame::lol::lo l::new::new::proud::proud::rofl::rofl::sad::sad::-):-):talker::talker::uhoh::uhoh::wink::wink::yawn::ya wn:
(Message edited by dogbot4000 on April 03, 2006)
I have an idea...
..Why dont we just ingore dear little Timmy-pie, he is like a bully if you stop giving feedback he will move onto another victum because he isnt getting the sense of victory.
And yep Graham Coxon was brilliant last night
Dave, why are you of all people defending Tim? Look around the forum, there is nobody else doing so but you.
Ignoring him will do nothing, Tim needs to learn to shut up and stop ruining tourtaments of others.
And Tim, since all those essays shot at you did absolutly nothing to make you realise your stupidity, here it is so even you can understand it:
Shut the hell up and stop making stupid posts to boost your count.
Tony, have you consider the option that it could be of no fault of Tims that he is like he is? He could have brain damage or another disease which means that it doesnt tick in his brain that he is being annoying.
