you can only enter one robot for each country and theres gonna be 32 countries and ill make it fair.
still doing it?
tryin to kevin wanna join in and play the world cup
Do I have to enter a vapour bot?
Ccan I enter Firestorm V?
Im entering in Firestorm V
I also want to enter Firestorm IV.5
kevin, Dan asked first though
Im going to enter Firestorm M
Im entering Firestorm Ove out of here already Timothy
To-Shay Guys,
Im entering Mad Cow
Dimensions-95cm length, 80cm width, 40cm height.
Weight-100kg
Shape-low wedge/sloped rear with Biohazard like side and rear skirts
Wheels-4 inner wheels
Speed: 20 mph
Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 750psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. There are two spikes at the back to prevent the robot flipping itself over.
Motors-2 LEM-COs running at 36v
Power-4 x 36v 3600mAh NiCD packs
Armour-6mm titanium all around
Ground Clearance-0mm front, 0mm around the sides/back with skirts.
Turning Circle-0m
Strenghts-Powerful flipper, nippy around the arena.
Weakness-People are always in awe of it.
(Message edited by kevin on September 17, 2005)
so, so far its Firestorm 5 V Firestorm 5 V Firestorm 5 V Firestorm 5 V Firestorm 5
My bet my be a bit out there but i am going to go for Firestorm 5 i dunno why it just seams like the best to choose
You see, thats where youre wrong Martyn. Firestorm 5 is going to be the victor, not Firestorm 5.
Firestorm V might be an outside favourite, but only on a judges.
Fiery storm type thing
Weight-100kg
Shape-firestorm shaped
Speed: 20 mph
Weapon: A high pressure version of firestorms flipper
Ground Clearance-0mm front, up to 5mm everywhere else
Turning Circle-0m
Strenghts-powerful flipper, is easily mistaken for firestorm so people overestimate it and therefore try to pull off compelx manouvers which would work againts a good machine, but this machien can counter them because its not precision driven
Weakness - its design wasnt thought through at all, may do a double flip when self righting
Summary: its firestorm but at high pressure
Name - A Brick
Weight - 100 kg
Shape - A brick
Wheels - Nope
Speed - 0 mph
Weapons - Nope
Motors - Nah
Power - Not this time
Armour - Brick
Ground Clearance - Zero all around
Turning Circle - 50 light-years
Strenghts - Cant be knocked out, low centre of mass
Weaknesses - Its a brick
Name - A Pie
Weight - 100 kg
Shape - A pie
Wheels - deliciouslly tasty cherries, which arent moveable.
Speed- 0mph
Weapons - Deliciousness
Motors - Thisll get your motor running
Power - sugar
Armor - A lightly toasted crust
Ground Clearence - 0mm al around
Turning Circle - Your face
Strengths - Our lord and savior
Weaknesses - Too sugary for its own good.
Weight: 100kg
Wheels: Customly molded out of Jello.
Speed: 0.000000000000000000000000000000000000000000000000 000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000001 mph. Another 1/100th a mph when it jiggles on random ocassions.
Weapons: Trapping power: lets see anything run after its been drowned in Jello juice!
Power: The AYB fanbase.
Motors: Made out of candy.
Armor: 3 inch chocolate.
GC: 0 everywhere.
Turning Circle: MJs face.
Strengths: Its jello for the love of god!
Weaknesses: The chocolate and candy might be out of place...
Oooh, this tournament sounds fun... :)
Weight: 0
Shape: A clone of Firestorm
Wheels: 2
Speed: 0
Weapons: A rear hinged flipper, because rear hinged are better.
Motors: 2x Bosch 750s
Power: Woot juice
Armour: Lots of ali
Ground Clearence: 0, however it can move my floating
Turning Circle: A square
Strengths: Its a rear hinged Firestorm, meaning it is better than the rest
Weaknesses: Clone accounts
seriously though, I think I wanna enter Firestorm
sure hope nobody has any problems with that?
(Message edited by MajinB on September 18, 2005)
yes you can enter real robots but you have to pick a country(like lithuania,ukraine,brazil)countries like that for your robots hence the name world cup anyway . someone can have firestorm 1 someone can have firestorm2etc.etc. that means everyones happy
(Message edited by dogbot4000 on September 18, 2005)
Anothercloneaccountonthefraforum will represent Erratus.
a real country perhaps?
Ill be Belgium then, Im bound to win that way.
Representing almighty Prussia :wink::
NAME- Whirligig 4.0
SHAPE- flat disc
COLOUR- deep yellow with Mauler-style scary face on top
WEIGHT- about 100kg (see bottom)
DIMENSIONS- 101.6cm diameter X 12.7cm
SPEED- 15mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 4mm
ARMOUR- 1.905 cm thick Grade 5 titanium
FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
WEAPONS- the main weapon on Whirly 4.0 is a much improved spinning shell. Weighing in at 33.72kg overall, its heavier than before and now boasts 9 Pussycat-style blades - 3 on the top, 3 in the middle and 3 on the bottom, so it can get some scars in nearly all opponents. The shell is now powered by 2 X LEM-130s running at 36v (these lie on their side, so they will fit comfortabely inside Whirly). These produce 2000rpm...and 183 kilojoules. This should be enough to completely obliterate another machine. Or worse.
As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
NOTES- Mauler-style scary face on top and bottom which show direction of robot, flies Scotland flag, my first properly calculated machine
STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
WEIGHT CHECK:
armour = 33.72kg (inc blades)
chassis, mounts, bracing etc = about 30kg
drive and weapon motors = 12kg overall
NiCads = about 15kg
feet = about 10kg overall
TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule.
Picture here: http://picturevillage.com/photo/data/9db6faeef387dc789777227a8bed4d52/13817_p253030.jpghttp://picturevillage.com/photo/data...d52/13817_p253 030.jpg (top right. Soz for smallness)
Breaking the trend, thats me. :proud:
Fiery storm type thign will represent The Congo for no particular reason
A Brick will represent Lovely
Yep, its a real country
A Pie will represent... uh... Area 51...
Jello will represent the bermuda triangle.
ok I need some more people and Ill put in 4 robots for people to pick if they want to
die ceratops invertus
mega morg
typhoon 2
flippy
choose your pick
Um, Die Ceratops Invertus isnt your robot to allow other people to choose...
seriously Tim, Die Ceratops Invertus is Chris Ms vapour, dont use him or let him be used without his permission
*shakes head* Tim, Tim, Tim, havent you ever considered seeing a mechanic to tighten your bolts and replace your missing nuts?
Honestly. Hes hopeless. ABSOLUTLY hopeless.
ok u can pick compass uni-directional instead of DCI
Im postponing the tourney to 2006 Adios to these tourney till 2006
Yay Freedom from crappy fights until 2006.
arent you still writing fights though dave? :proud: j/k
LMAO, Martyn! That is the best line youve come up with in years mate! Oh, God taht was awesome!
lol Martyn for the first time your funny.
OK because all of the teams which have qualified for the world cup this tourney is starting all over again now so you can either enter realies or vapours for these countries(note they are in alphabetical order::)
Angola
Argentina
Australia
Brazil
Costa Rica
Croatia
Czech Republic
Ecuador
England
France
Germany
Ghana
Holland
Iran
Italy
Ivory Coast
Japan
Mexico
Paraguay
Poland
Portugal
Saudi Arabia Serbia And Montenegro
South Korea
Spain
Sweden
Switzerland
Togo
Trinidad And Tobago
Tunisia
Ukraine
USA
