the first 6 robots have byes to the 2nd round
*holds up a sign that says IM confused*
wat happens is the first round is qualifying then i sort out a draw 4 4-way melee than 2 qualify from then on its 4-way melees until we have a winner
come on enter
whoever enters then i can tell people about the house robots and everything
You probably need some more detailed rules
For example:
your views of walker weight
how many entries per person
weight classes
Clusterbot rules
Flying rules
Accuracy rules
Flipper pwoer rules
Spinner speed rules
and there are others.
no flyers because i dont know what there are
max walker weight: 240kg
max entries 3
max clusterbots 4
accuracy rules between 25 and 97%
flipper power rules max 20 flips
spinner speed rules max 46947rpm
and please tell me the others
By accuracy I meant how carefully will you scrutinise the stats to see if they are realistic.
Flipper power measures how far soemthing is flipped, not how many eg. firestorm has a vast number of flips but they dont go very far, in contrast chaos 2 has many less, but they are more powerful.
Spinner speed generally is at 1000, 1500 or 2000rpm, that means for a weapon with a 3m circumferance a blade could travel at approximatly 2.3km per second, which is kinda unrealistic.
Flying robots are robots that fly.
Walker limits are usually 150kg or 200kg depending on preference.
Ask some other people if you want more rules, as Im not that up on the rules, as my tournaments have had quite basic rulesets.
(Message edited by alex_holt on August 24, 2005)
Name- Couldnt Risk A Potato (CRAP)
Weight- 100kg
Shape- Box
Weapons- 2 X 46947rpm vertical discs
it acuracy is 97%
Robot 2
Name- Even Couldnt Risk A Potato er (even craper)
Weight- 100kg
Shape- circle
Weapons- 4 X 46947rpm horizontal discs
it acuracy is 97%
Name - Da Plastic Bag
Weight - 40 kg
Shape - Plastic Bag
Weapon - God
Its accuracy is 97%
R2 -
Name - Pie
Weight - 240 kg
Shape - Pie
Weapon - 46947 rpm hortizontal disc
Its Accuracy is 97%
martyn and dave shep have got automatic byes
and the arenas are
death arena where theres 6 cpzs
normal arena
and gravitys delight an arena where theres 3 arena floor flippers
and house robots m2,101,atomic 2,die an 473kg bot with 5 flippers on front and back and 3 along the sides and its got a head with a flamethrower inside it,G5 a very first of its kind a 521kg clusterbot 1 of them has got a drill the other ones got a machine gun and grovity which is gravity with a wig on
and this is how the robots are set out
name
weight
speed
weapon
srimech Y or N
summary
tracks Y or N
walker ^ ^ ^
strengths
weaknesses
and i hope thats answered everything
Shape: Invertible box
Speed: 20 MPH
Weight: 95 KGs
Weapon 1: A front drum, spinning at 46947 RPM using a customised motor and drive train to give it near instant acceleration, able to rip any kind of armour to shreds.
Weapon 2: Rear flipper with 20 flips.
Armour: 3 MM of a customised alloy, which is lighter than Polycarb but completely invincible.
Drive: 4-wheel drive running off a customised drive-train, providing it with 30 HP
GC: 0 all over thanks to customised skirts, which will not be gotten under by ANYTHING. The only reason this can move is because it has such a powerful drive.
Strengths: Everything is customised
Weaknesses: Flipper has limited flips.
(Message edited by pcbore on August 25, 2005)
lmao! 50 Bucks says that actually gets allowed in.
change it so at least its not invincible then ill let u in
Speed: 20 MPH
Weight: 95 KGs
Armour: 3 MM of a customised alloy, which is lighter than Polycarb but almost completely invincible.
I was waiting for Kustom to come along :proud::proud::proud:
That robots crap. My robot would tear it to shreads.
Name: The AJ bot.
Shape: Spinning dome
Speed: 25 MPH
Weight: 96 KGs
Weapon 1: An entire body spinner that spins at 852308528578432905 rps. Has magents and extra weight to stop the robot from flying off into space.
Weapon 2: Awesomeness
Armour: 2 feet of steel which is customised to weigh only 30kg.
Drive: 4-wheel drive running off a BETTER customised drive, providing it with 31 HP.
GC: 0 because of awesomenessnoob skirts, which surround the bottom of the robot. Impossible to get under, even by Kustom.
Strengths: Because I said so.
Weaknesses: Its awesomeness only lasts until it loses which it wont.
What the hell, im going to go uber too :proud:
Name: Doom of The AJ Bot!
Shape: Vladiator
Speed: 99999999999999999999999999999999999999999999999999 999999999999999999999999999999 999999999MPH
Weight: 100kg
Weapon 1: Lifting Spikes designed to get under the AJ Bot and can lift anything else as well.
Weapon 2: Rear drum spinning at 46947rpm. This is impossible to get under with magic, and is designed to rip through the AJ Bots armor.
Armor: 99999999999999999999999999999999999999999999999999 999999999999999999999999999999 99999999999999999999999999999999999999999999999 foot thick hardox deisnged to absorb impact from the AJ bot.
Ground clearence: -99999999999999999999999999999999999999999999999999 99999999999999999999999999999 99999999999999999999999999999999999999999999999999 9999999999999999999999. Can get under ANYTHING. and yes, this is right, its sunken into the arena floor and can still attack anything with ease. Once again, the work of magic. ANd can espically get under the AJ bot.
Drive: 4 wheels with 99999999999999999999999999999999999999999999999999 999999999999999999999999999999 99999999999999999999999999999999999999999999999999 999999999999999999999999999999 99999999999999999999999999999999999999999999999999 999999999999999999999999999999 99999999999999999 Horsepower.
Strengths: The AJ bot dosent stand a snowflakes chance in hell aginst it, and neither does anything else.
Weaknesses: Mattys pants.
OVERWEIGHT!
Nobody else is taking this seriously, why should I?
That doesnt stop it from being overweight.
And yours is underweight?
Reserve my pants a place :wink:
Yes, the two feet of steel is customized to weight only 30kg. That weight includes the shell and frame.
The motor, is specially made to weight only 10kg. This leaves 56kg left. All four wheels combined weight 6kg.
The motors for the wheels weight 10kg cumulative. This leaves 40kg.
Now the batteries, controllers, magnets, and extra weight comes two that remaining 40kg. Leaving me at 96kg.
Oh yeah? Well my drive motors, being magic and all, weigh a mere 10kg. The armor, another 10kg. The wheels, another 10 kg. the drum and motor, you guessed it, another 10kg. the forks, another 10kg. The batteries and all else of such, 50kg. Your caculations on mine were off.
So much Hardox cant weight 10kg, even with magic. Silly Toniyi =P
okay so aj frank ant and someones pants hasgot automatic byes
ok im gonna bring in more robots
weight: 86kg
speed:63mph
weapon: big flipper
srimech: N cause its invertable
summary: a big flipper,63mph,invertable nuff said
Tracks:Y
walker:Y
strengths:Simply the best
weakness:Legs
o ant and someones pants r in the qualifying round soz
One Y Damnit.
People dont enter there own tournys tim
weight: 86kg
speed:63mph
weapon: big flipper
Tracks:Y
walker:Y
weakness:Legs
How the hell can you have a tracked walker? Especially one that only weights 86kg?!*Raises both eyebrows*
(Message edited by matt_macdonald on August 26, 2005)
weight: 100kg
speed: 30mph
weapon: A really really powerful pair of vertical pincers that can slice through anything, the blades are diamond tipped so they are practicalyl unbreakable
srimech; no, invertible
summary: looks slighlty like 101, but really heavily armoured, and its tracks are partically indestructible due to the composite material they are made from, additionally the claws can produce over 500 tons of pressure, and the tracks give it vast traction. The armour is moutned on a chassis, in a way that even if the armour was to break it would not damage the robot inside particularly and the chassis woudl protect everything.
tracks Yes
strengths: very tough all round
weaknesses: it can be flipped
*grumbles* Stupid FRA forum system that dosent allow editing after 10 minutes...but The Doom of The AJ Bot is underweight due to sheer magic. Thats all I have to say, and my case of being underweight is rested. :P
(Message edited by Swiss_tony on August 26, 2005)
i can have a 86kg tracked walker because of sheer magic
and im only entering because noone else is
NAME: Space Colony FARK
WEIGHT: 200 tonnes
SPEED: the speed of light
WEAPON: The Eclipse Cannon. A laser blaster powered by 7 x Chaos Emeralds and capable of destroying half the moon in one shot.
SRIMECH: Doesnt need it. You try flipping something that heavy :wink:
SUMMARY: Giant ball with insanely-powerful cannon. nuff said
WHEELS: aye
TRACKS: yup
WALKER: sure
STRENGTHS: ...um...everything?
WEAKNESS: The laws of reality
Curses, Matt, Ill be sure you NEVER wear pants again!
*Begins ripping apart every pair he can find*
Oh soz, theres a mistake in Space Colony FARKs weight.
Make it 72kg. Itll fit, Im positive. Its made from paper-light, but hard-as-diamond Nonexistium :wink:
WEIGHT: 237 kg
SPEED: Speed of Lint
WEAPON: Sheer ramming power
SRIMECH: Invertible
SUMMARY: Destoys all in sight with its infinity-probability drive.
WHEELS: Yes Please
TRACKS: Ok
WALKER: Your pushing your luck son
STRENGTHS: Tonys robot is destroyed in its wake
WEAKNESS: Andys Jumper
NAME: The Toni Tribute Robot
WEIGHT: 75 kg
SPEED: 2 mph
WEAPON: A potato launcher and a box which says Y dammit
SRIMECH: Nah
SUMMARY: Random pile of crap
WHEELS: Nope
TRACKS: Nope
WALKER: Yep
STRENGTHS: Potatos are scarried
WEAKNESS: No armour
I wish i had known about Nonexistium when i was writing my stats :sad::sad::)
Oh thats a point, I forgot to mention my armour, its adamantium-octiron alloy.
