Interface Board
We are using 4QD Pro 120s at 24v and currently using a Delbots interface but we are looking to change this for something a bit newer and better. We are considering either the programmable interface on Technobots or the DMR-202 from 4QD. Is anyone using a similar setup or does anyone have any opinions on which would be better?
Ian
Interface Board
I use the Technobots interface on my bot it works well and the computer software makes it very easy to set up to get your robot driving just right.
Ive not had any problems with it at all either mechanically or electrically.
Havent had any experience with the DMR-202 so I cant say how this performs.
Richard Wenman
Team Mayhem
Interface Board
I had the dmr. It fried it self.
Interface Board
I must admit the Technobots was running favourite, the computer connection for setup sounded interesting. I think Ill get one of those.
Thanks
Ian
Interface Board
Hi peeps. I have just got the r4qd interface from technobots and it is a good piece of kit. the only problem i have with mine is, it worked fine staight out of the box but i wanted to program the interface with my rc gear and now it wont work properly. when i load the program and try to save the data it sometimes sais invalid port number yet i know that it is plugged into the correct port. is it just me or is something not configured correctly like the computer, or have i got a duff interface? and now after all that i cant seem to erase everything i have done to get it back to how it was when i first got it.
someone please help me i want to take it for a test spin.
Cheers Chris.
Interface Board
Chris - what do you mean ?
You say it worked fine straight out of the box, but you wanted to program the interface (with your rc gear?) and now it wont work properly.
... what do you mean when you say program it with your RC gear ?
It sounds like youve never had a computer connected to it, but at the end of your post you mention that you want to get it back to how you first got it ?
If you could explain what youve done in a little more details people might be able to help - at the moment Im confused :sad:
Ed
Interface Board
ok. you can set up the interface with your rc gear so it is more responsive and to configure the weapon outputs.
it is connected to my computer but it doesnt seem to be saving all of the data to the interface, and now when i go and try and use it, it is all messed up, it wont do what i want it to do. and when i said straight out of the box, i mean on default settings.
Interface Board
Have you tried the reset button on the board. I believe you have to do it when you start to progamme the board it then resets the memory and you should be able to upload your new settings to the board.
The procedure is outlined in the instructions.
Richard Wenman
Team Mayhem
Interface Board
yes i have tried that. but when you go to the test and program tab it brings up the new window ok, but after doing what it sais, when i close the window it then sais that it cant open device com1. im sure that it isnt saving the data properly. it driving me round the bend.
Interface Board
Oh
Have you tried changing the com port. Up on the top menu if you click on com 1 a menu drops down and you select another port.
Although Ive always used com 1 myself I think it says in the manual that some computers allocate this for internal use and the one on the back of your PC is Com 2.
Im not sure about this idea but Im running out of ideas Im afraid :sad:
Richard Wenman
Team Mayhem
Interface Board
im sorry to say this but iv allready tried that. iv tried everthing i could think of. im not sure if iv got a dodgy board or software or something.
oh why me god, why me. :-(
my robots been plagued by bad ohmens from the beginning.
Interface Board
just out of interest, does anyone know where abouts ian swann lives. i might see how far away he is from me. to try and fix the problem by the person who created it.
Interface Board
Chris
Technobots provides support for its products and is happy to help. I sent you an Email earlier today suggesting that you phone me and I will try and help.
Paul
Interface Board
ok. i will phone you tomorrow. cheers m8.
sorry to be a pain.
Interface Board
if you have an older version of windows and logitech mouseware, it can give problems with other software like telebanking or other communication software because it claims the com port and will not release it. It is possible something like that blocks your software.
If this is the case, install the latest mouseware and that problem is solved. of not, good luck.
Interface Board
Oh my god. iv finally got it working. I tell you what guys, its amazing what happens when you read instructions properly, and also a little help from Paul Cooper.
Wicked. im so pleased i can finally take it out for a test spin. Yay :-)
Interface Board
Glad to hear it working:)
Sorry I wasnt much help.
Richard
Team Mayhem
Interface Board
Interface Board
Interface Board
What was done to correct the problem described in your first post?
Interface Board
i cant remember. i think i read the instructions properly and went through it slowely step by step. i think i had to recet everything as i had confused it so much it didnt know what it was doing. silly me.
