Bosch 35watt Motors
Hi
I have been looking into these. The seem perfect for what I have planed. But after talking with another roboteer he says that most people use the 12v motors at 24v to get any speed. Is this true?
I am looking to run teh 12v motors at either 12 or 14.4v and i am wondering what kinda size wheels i would need for roughly 10mph
Regards
Ian
Bosch 35watt Motors
we run G3 currently on 14.4v and its fast and powerfull enough. We are upgrading to 24v when we get the brass gears, dont run at 24v without getting the brass gears, also make sure they are kept well cool.
Cant remeber what size the wheels are, only about 50mm.
Bosch 35watt Motors
How much are these 35watt motors each?
Bosch 35watt Motors
Brand new about £55 each.
From a fellow roboteer - not sure on the price. but under £35.
Ian - go on what Alan just said, up to 14.4v is a decent speed and power on the normal plastic gears, then if you want, use 24v on a brass gear, long as ther kept well cool.
But saying that- DTK has still hmm lets say damaged a few brass gears running on 24v still. But oh well - things happen.
Mr Stu
Bosch 35watt Motors
I think Stu means me !.
There 25 quid a pair when ive got some,
which i havent at the moment.
They do 700rpm on 12v and double that on 24v
so a 120mm dia wheel would give 10 mph @ 12v
or 60mm dia @24v
:)GORD
Bosch 35watt Motors
Have anyone got some second hand ones they are willing to sell? I can afford £15 maybe £20.
Thanks in Advance
Aaron
Bosch 35watt Motors
Gordon, just re-read your post, £25 for a pair sounds good, do you happen to have a pair by any chance :proud:
Bosch 35watt Motors
Okay, not only still chasing a pair of these motors, but also wondering if anyone has gone to the extent of drawing a set of these motors up in Rhino 3D?
£30 for a pair? Anyone :sad:
Bosch 35watt Motors
Hi Aaron,I dont have any at the moment ,but i do have a autocad drawing somewhere ill try to get it up online.
:)GORD
Bosch 35watt Motors
Ok you should find the Drawing here its a .DWG file
http:http://www.twnly-grdn.supanet.com/Std-bosch-35w.dwgwww.twnly-grdn.supanet.com/Std-bosch-35w.dwg
:)GORD
Bosch 35watt Motors
What version of AutoCAD did you use to draw that in? I tried to open it with AutoCAD R14 and it told me it was an incompatible version.
Bosch 35watt Motors
Aaron i use 2002 lite
:)GORD
Bosch 35watt Motors
mmm, Ive used AutoCAD 2001 Lite, is there a option to save it as an older AutoCAD version?
Still interested in the motors if anyone can help!
Bosch 35watt Motors
Aaron ive resaved the file in r14,so have another go.
:)GORD
Bosch 35watt Motors
Im Going to be putting an order in for some brass gears for the 35ws. We tried this before but when it came to putting order in alot seem to drop out. Post if you want some then i will get a price, ill find the price out next saturday, so will need to know before then.
Cheers,
Dave
Bosch 35watt Motors
Hi
I know gord posted a link above to a cad of the Bosch 35watt motor but it is now down, I was wondering if anyone had one? I use rhino 3d 2 so the best file type for me is .3dm however I can read autocad drawings (running autocad 2002).
If any one could help I would be much obliged.
Regards
Ian
Bosch 35watt Motors
Sorry Ian a typo slipped in .
http://www.twnly-grdn.supanet.com/std-bosch-35w.dwgwww.twnly-grdn.supanet.com/std-bosch-35w.dwg
:)GORD
