What to build?
Okay, partly because I genuinely want advice, and partly because I think this might be an interesting discussion (and full of hints and tips), please humour me for this essay - and tell me your thoughts...
Im a beginning roboteer. Ive been hanging around the forum for a while, and following the show since the beginning - with the obvious planning of my own robots that seeing Robot Wars tends to induce in the mechanically minded. I know my Bosch 750s from my Eteks, my regulators from my actuators, my PICs from my MOSFETs, my planetary gearboxes from my harmonic drives (anyone using one of those?) - at least in theory. Ive got several elaborate designs which Id like to build, each unusual and potentially effective, but also, without exception, *complicated*.
Given that I know my place, and that Id rather learn before I build a super-robot which takes vast amounts of time and money (because getting it trashed because of a stupid mistake will be very annoying), common sense says I should build something simple and traditional, but more likely to lose, first. Because I know Ill lose, the robots out there are no longer season 1 quality and neither are the drivers, and its better for my ego to be thrashed in a robot I know isnt very good anyway.
But what to build?
Conventional wisdom says start with an antweight or a lightweight, but I cant see much being reusable for the heavyweight I really want to produce. Besides, I probably couldnt see it well enough in the arena, and Id rather have a bit of room to work with. Also its easier to drag victi^H^H^H^H^Hfriends in to help with something bigger. So humour me, if only because Im in this bit of the forum, and assume I want to cut my teeth on a heavyweight.
Conventional wisdom next says, build a box on wheels. The problem with that, of course, is that there are at least two boxes on wheels on the live circuit anyway (obviously I mean SMIDSY and King B) - with Tanto and others upcoming - and the chances of me doing anything to any of them with a poorly built first robot are tiny. I may expect to lose against everything, but Id want a finite chance of getting lucky. More importantly, a rambot kind of relies on being put together better than its opponent when it smacks into it - and somehow I doubt thatll be the case.
Thwack bots (T-Wrex, Overkill, Stinger) may be slightly better in terms of not taking the whacks they give out, but are harder to drive, and Id really struggle in a small arena to do anything useful with it. Besides, sit and spin is a boring tactic, and overhead thwacks arent so effective. Plus: live event = railings. Tend to be trouble.
So although Im willing to be persuaded, Im probably looking at active weaponry.
That leaves:
Pneumatics (flippers or axes - TaN/Huggy Bear/Complete Control style clampbots probably require more driving skill than I have for now). Every book on the subject says stay well away from pneumatics until you know what youre doing, or youll kill yourself on them. Ah. Problem there... Otherwise I like the flipper idea. Axes are interesting, but modern armour (other than what Ill be able to put together) kind of means I dont expect to get far with one.
Hydraulics (pretty much crushers, unless anyone has other plans). Like pneumatics, but more dangerous - and I know least about it. Kind of restricts you to entering an extreme damage class, with a spindly appendage sticking out of your robot while people with spinners are wandering around. Not a problem (much) if you have driving and engineering skill, but thats what Im here to get.
So, unless someone talks me into pneumatics, that leaves electric weaponry. Which means:
1) Spinners. Same problem as hydraulics, extreme damage only, and you need to build them really well so theyll take a hit. Oh dear. Besides, Im from the Rex Garrod school of not demolishing the opposition, so Ive never really like the idea. Since this is for live events, Id probably not be allowed to run anyway.
2) Lifters (like Panic Attack and Biohazard - and arguably Storm 2, although I dont buy it). Okay if you have a lot of driving skill and a solid robot. Oh dear. Also kind of reliant on the presence of a pit, which is by no means universal in a live event.
3) Electric axes. Hard to get through current armour, and anything powerful enough to bypass this problem (e.g. Beta) is going to be expensive and hard to build.
4) Saws. With the possible exception of the Pussy Cat blade (which is arguably a spinner), pretty much incapable of cutting into any current armour. Rare these days for a reason.
5) Esoteric stuff (drills, disembowellers, stampers, stompers, flingers, wheelcutters... dont ask me to explain all that) - not very tried and tested, probably wouldnt work very well, might not be arena safe, and might do expensive damage to opponents if they *did* work. Not for a first robot, methinks.
So, I think Ive just said why I wouldnt start with *anything*. Hence my dilemma.
People have always said start with a box, because its the obvious thing with which to start. So, to the general assembly: is that still good advice? With all the combined knowledge of the roboteering community, is the easiest thing to build really the simplest? What stands up best to being built badly? Im not expecting to win, just to put on a good show - and that point of view is another reason why a (dull) box is a bad idea. What has the greatest chance of producing an interesting fight, per unit competent builder?
Dragging tiddlywinks into this: experts at tiddlywinks win by playing very simple shots very well. Leave yourself in a position where you never have to *play* a difficult shot, and youll never *miss* a difficult shot. A novice advised by an expert is a dangerous opponent. What is the robotic equivalent - the minimum input/chance of failure for the maximum return?
What, with everything you know, would you decide to build if you had a competency failure?
Anyone?
Fluppet
What to build?
Mr. Fluppet.
I too am starting out on the path to enlightenment/non-destructive-carnage, and Ive got a handful of ideas Im considering. Like you Ive considered all the weapons and sizes and Ive come to a few conclusions.
1. Weight. Im building a feather for the pure and simple reason that I cant afford to build a heavy. I couldnt even afford one speed controller never mind two, and a mixer, and the 2MAh batteries, not to mention £100 PER MOTOR etc etc... Im not building a lightweight because theres so few of them and you never see events with a lightweight class. Middles are basically smaller heavies with most of the same problems, and Im just uninspired by ants.
2. Weapon. Pneumatics would be nice and Im not ruling them out for the future. Hydraulics - ditto but harder to implement, more dangerous etc etc. Axes/hammers - ineffective without pneumatics or money (as you said). Spinners - Im not after wholesale destruction (of me or others) so theyre out. That leaves me two options. 1. An electric lifter/flipper. This is relatively cheap to make, should be easily able to lift a feather (another problem with a heavyweight is the extra power needed for this kind of thing) and can be used as a srimech if well done. THis is probably what Ill go for. 2. An electric crusher/gripper. Sounds unlikely but its a possibility Im considering. It wouldnt do as much damage as hydraulics etc and therefore should be allowed in the low-damage competitions. Im not going for a rambot as I already have my motors and Ill be woefully underpowered and too slow to push around the featherweight equivalent of Storm II (they should do an ant called Storm in a Teacup :proud:) etc.
3. Shape. Build around the weapon is the advice I heard. I have a few ideas buit its going to basically sit on a rectangle of box-section steel and the frame can be whatever shape works, with a few rules (to let the weapon do its stuff etc). For control Im having the wheel span nice and wide, and probably a castor at the front, but with (hopefully) and adjustable zero ground clearance at the front and maybe skirts around the sides and back. I like the idea of a plough shape, but itll basically be a funny shaped box. It wont be invertible (I plan to use Dominics motor mounts and wheels eventually and Id have to make it very thin to be invertibe on the same wheels) but it will have a srimech of sorts.
My most likely point of failure is going to be the electronics which Im designing and building for myself. Its a full speed only speed controller, but with two stick control (one up down, one left right) and spin on the spot capability. At the end of the day tho, itll be driven by microswitches and relays and Im designing it in such a way that if the electronics fail I can take em out and JUST drive with Microswitches and relays, and only lose the on-the-spot part.
Basically Im keeping it as simple as I can on the assumption that at some point it will fall apart and break something, and I dont want that to mean a rebuild, or buying something else pricy to replace it. It should also be able to take a short flight and land on concrete and be ok, but Ill test that at some point no doubt. (another testing issue with a heavy - how do you throw it to test it? Unless you live near a big flipper)
Ill stop there as my rambling is refusing to come to a sensible end point.
-- Kev
EDIT : that all sounds like Im saying dont build a heavy which Im not. Im just saying Im building a feather for these reasons, and heres my thoughts on a first bot. You never know, my feather may go overweight and become a lightweight yet.
What to build?
Dont feel too impressed by other robots and do try to design/build one that can take a few hits and deal out a few as well. If you feel constrained by a budget too small go at least for a feather or antweight and get the experience, you will learn a lot out there and have the chance to exchange ideas and tips with other roboteers. You might even be able to acquire parts for a heavy in time when you start to know certain roboteers, or better parts for your existing robot (be it heavy of feather, or even ant, we dont care). Some people know the cheap addresses, or might arrange something for you that you can afford. Talking is very important here, as are having a broad mind about everything and showing an open attitude as well.
Shape: there are so many geometric shapes, choose and combine... strange and weird designs may pleasantly surprise onlookers and may even confuse opponents. With regard to the frame I would suggest support beams when and where you can have them, triangular support shapes tend to be the strongest and are recommended. (If you dont understand what I am referring to, send a private message and I will make a drawing for you.) Not everyone can buy or -even more difficult- install hardox or titanium armor on his/her robot you know ! Most often it is the frame that literally holds the robot together, along with strategically placed bits of tougher armor here and there. Armor does not need to be on the outside of the robot either... protect the real expensive and/or vulnerable parts deeper in your robot and you might walk out of a fight with less damage than you think.
Weapon: you might be surprised at what a simple weapon will do. Damage counts ! Being agressive counts ! Strangest weapon I have seen so far: a ships propeller, strange but true and it is a German robot too. They have a long history of surprising their enemies. (See for instance the Blitzkrieg where they used floating planes to drop troops instead of parachutes !!!)
Driving: experience is the key word here. Live events give you the opportunity for gathering experience in both driving and fighting. Do not expect to win at your first battle ! (Though it may be a really big nice feeling if it happens.)
I may not be right, I even may make mistakes in my explanation, but this is how a non-technical person sees Robot Wars. Have a go at it.
What to build?
most importantly.....
featherweights fit in a bag and can ge carried on the train/to the arena on your own.
recently discovered that, unless you have a mate at all times, heavyweights are a pain in the...... back for one.
feather...... stick with em, they hurt less.
What to build?
The dictum with RW these days seems to be: Whatever you do, do it properly.
I would be inclined to build a flipper- theres no better way to learn about pneumatics than to play with them (in a safety concious way of course!) and they really do become very easy. Yes, it is dangerous, but not if you take a common sense approach, and realise that if you dont know what will happen if you stick this tube in that fitting, dont!
LP pneumatics are obviously preferable to HP for a first-time robot, and can, in many circumstances, be just as effective, if not quite as spectacular. If done properly (read: a la M2) then they make excellent weapons.
I can see the logic in wanting to start with a heavy, but feathers really do have some massive advantages over heavies, not least in size and expense (tho by no means complexity). They really are scaled down heavies. Antweights, im my 4 years of experience with them, are not the place to start if you have heavyweight aspirations. The technology and construction styles and techniques, materials and so on are very different to feathers, lights, middles, and heavies, which all have very similar construction techniques.
Fitness for purpose: this obviosly encompasses combat, but also, as is all too frequently overlooked, maintainability and repairability. It makes an enormous difference when in the pits. Thankfully it doesnt happen so much anymore, but it used to be the case than crystal changing was a 20 minute affair with some robots.
Materials- Fitness for purpose, not just fitness period. Ill illustrate this with an example from the semi shown on saturday: St Argo was well built and nicely machined, but I beleive (and correct me if Im wrong) its wheels where a hard grade of aluminium, eg 7075 or 2014. Yes, these materials have a high Youngs Modulus, and are reasonably tough, they tend to snap and shatter instead of bend and be gouged when hit by spinners. This isnt very desirable for wheels- as you saw, a massive chunk of the wheel was snapped off by a spinner. If we then look at TANs wheels, they are made of a plastic (I forget which- appologies) which doesnt snap off in large chunks, instead close inspection of them reveals spinner tooth marks- where they have been gouged, but the wheel is still in tact. So while St. Argos wheels may on paper appear stronger than TANs, it doesnt make them more suited for their purpose. This priciple applies equally to armour and chassis.
In short, Id build a pneumatic feather as a first machine- its advatages include:
a)You will learn about pneumatics as well as electronics- so 2 disciplines- which will allow you to make a more informed choice when building your heavyweight. (the same could be argued for a hydraulic feather, but hydraulics are expensive, difficult (ie you have to know what youre doing) and very heavy).
b) Flippers need good, powerful drive, and need to be very well driven, so you will have the benefit of learning to design a high performance drive, and learning to drive it well at live events. (again, allowing you to make a more informed choice when building a heavy). I dont want to start another spinners dont need good driving arguement, but I think it is true than flippers tend to need slightly more accurate positioning, and rely on good driving, slightly more than spinners.
c) You have all the adavtages mentioned previously of building a feather.
d) Feather flippers are fun!!!
Hope thats of some help, and Id be glad to talk to you more about any of that at the social (although there will be far more qualilified people than me there so you may be better off talking to them :-)
What to build?
The wheels from TAN are made out of HDPE 500 draintube. Eddy describes the build filosofie behind them perfectly.
Now my idea of a heavy. If you aim for life events, you can build in blocks.
First a drive, but 2 seperate units that can be mounted in whatever you can get.
At first without a weapon, mount massive, cheap batteries, so you get the full weight, and try to distribute this as if the weapon is in place.
Then you can practise as much as you want without weapon, and in the mean time, buidl yourself a weapon you can use to bolt between the drives.
This is methode live events only
If you think about participating on Battlebots/RW mentorn style events, completely purposebuild is a more interesting option.
Maddox rule 1 nothing serves only 1 purpose, if avoidable TAN is the first machine going along this lines(for us). With the pistonrod as most fun application. It is main weapon part, but also a structural member of the chassis, and low pressure buffer to boot.
The chassis is frame and armour, and keeps on going, even after 2 years of intensive use. 2 wars ,and a lot of live events.
What to build?
Babeth rule 1: The more working parts you have the more can break down.
Babeth rule 2: Air can be armor.
Babeth rule 3: Layers arent just cool.
Babeths Major Rule:
Nolite id cogere, cape malleum majorem - Dont force it, get a bigger hammer
And to top it off with a Japanese Proverb:
To a person with a hammer, all problems look like a nail.
What to build?
RCC2 is very well armoured then Babeth. :)
What to build?
Thank you, everyone! To keep this going, I should probably provide a few more parameters for leverage, at the risk of making this less applicable to other readers of the thread.
Firstly, budget. Id like, at least for a first robot, to keep it as far under a thousand as possible, but Im presuming something in the a few hundred range. This presumes I can re-use as much as possible, though - I cant afford to make a habit of it, unless I get sponsored. I suspect thatll cover a basic heavy if Im prudent, although obviously were not looking at titanium and Magmotors. Im not counting petrol/accommodation etc. in that.
If Im going with a heavyweight (Ill come back to that in a minute), that breaks down as follows.
Im presuming that its worth my while to buy a couple of modded Bosches. Partly for ease of replacement parts, partly because I might be able to sponge a temporary replacement in the pits if Im really stuck (and equally loan things out, obviously), and partly for ease of matching the motors. Im sure I could get some decent motors for less from a scrap yard, but the first time they get wrecked I can see myself needing to re-do my entire gear train for a different motor. Any opinions - is this an unnecessary investment, or would the second-hand route be a false economy? I dont have an infinite amount of time (any more) for scrap hunting - although since this is why I can now afford to start building I shouldnt knock it.
Im guessing, unless Im lucky in scrap, that Ill be buying gears/sprockets/chain/bearings (depending on the drive train). Im hoping theyre not ridiculously expensive. I dont have a machine shop (Im also budgeting for a cheap MIG welder, although I have some basic other tools thatll cope at a push until I start with the hardox), and there are the same issues with replacements otherwise.
The frame and armour, on the other hand, Im thinking purely of the scrap route. Box section and steel/ali plate are much of a muchness at my stage of procedings, and a grands worth of titanium pepperpot after the armour gets trashed wont do me as much good as something I can fix up with a sledgehammer and some judicious welding, or replace for a pittance. Well see about wheels and weaponry. I dont think thats contentious.
Control might be, however. As I said, most of what Id *really* like to build is... interesting. That includes the locomotion. Even if I start with a simple bot, I dont want to spend a fortune on a Vantec or 4QD that I cant re-use.
I have passable electronics knowledge (Im really a software kind of guy), but I might be able to cobble together something that would work well enough in a given application, even if it wouldnt impress David Gamble much. I know Im going to need PWM (and some speed-dependent voltage ramping/current limiting) and not just on/off, btw - Im trusting some appropriate microcontrollers can sort out the hard bits. (Kev - you probably wont smoke your motors like a heavy would, but are you *sure* you can get away with on/off control?) Id rather trash some PICs and a few FETs than a 400 quid unit, and it makes life easier for some intelligence in the control system too. Am I biting off more than I can chew?
The same applies to the radio end of things - I have no problem building a custom controller, and ideally Id want to send a data stream to the robot, which can then sort out the mess. Is my best bet to buy a radio modem, or should I actually build the transceiver myself? If so, would I be trusted to get the frequencies right? Is this way overboard for a simple first bot?
Okay, done giving my circumstances.
Regarding feathers, Eddy and Kev: Im still concerned about how much robot is reusable, and there are scary people talking about translational spinners in that forum. If Im treating the motors as an investement, and if I have no problem with the physical size of the robot (I own a car which would fit it, and since Im of a size where Id only count as a heavyweight because Im a walker I could probably move it around okay - I need the exercise!) are the other benefits still more significant? I can see people from work helping on a heavy, but not on a lightweight. Plus custom electrics only seem insignificantly light weight on a heavy.
On the other hand, Id rather lose my finger (scuse the pun) to a pneumatic accident with a feather than break my jaw on a heavyweight...
Pneumatics: given advice and due care, is this advisable for a sufficiently paranoid novice? Is it going to cost a fortune? Several of my more interesting designs have pneumatics in them, so the extra experience would be welcome, but is this too much to start with? If not Ill look at electric lifters, but I doubt I can make an effective one - other than, possibly, a dull Biohazard clone, which would be trashed by Storm2.
Marios modular idea is interesting (and yes, live events only) - although Im hoping that I can do some remodelling with MIG and an angle grinder; I certainly want to expand the design as I try to learn about new techniques. Ive got robots designs which are pretty detailed, but for something I want to be a simple trial run, I dont want to over-think it - thats why Ive not built yet, after all!
On the other hand, Ive always believed that robots can get trashed, but ideas cant. Therefore a robot should be designed very carefully, but built as cheaply as possible. Im deliberately going against that here to get some more parameters for the design - Ill still build cheap, but Im not particularly building to win. Doesnt mean I wont think about it, but itll stop me straying too far from the beaten path (even though I generally favour innovation over success; besides, I can hardly ask people to give me ideas for a completely novel robot design in this thread).
Shape: Wedges are clearly good, and skirts might be wise too (if I get the hang of attaching them). Novice question: in TV footage all wedges look like theyre on the ground - how much is that really the case? Ive never been close enough to a running robot to tell, and people keep talking about a given robot being lower at the front. Getting under a better robot does seem my best chance of doing anything much.
I had a long debate with people on the RW forum last year about triangles. I know the principle, but Im not sure I ever got a straight answer as to whether some people had a more rectangular design deliberately to allow for the frame corners to rotate to absorb impact - where a triangle would have to fracture. Andrew Marchant assures me that there are no true right angles left on Tornado, but its pretty stiff anyway. Any more thoughts on that?
Eddy: Do flippers need good, powerful drive? By modern standards? If so, a couple of Bosches might not cut the mustard these days. Enough to control the robot well and shove another robot while flipping it, but Id have thought orders of magnitude behind ram bots?
Babeth: to John Reid, all opposing robots look like nails. Who am I to argue? For the rest of us, the trick is designing a universal hammer. As for being too impressed by other robots - the roboteers have my respect for building anything (particularly for so long as I havent), but that doesnt mean I dont look at every robot with a view to working out how I can beat it!
Rather than address everything else everyone said, just presume Im grateful so I can stop rambling before everyone loses interest.
And yes, Eddy, looking forward to talking with you at the social. :-)
Fluppet
He does go on...
(Yargh. Ive just seen this in the preview, rather than a bit at a time in the entry box. Must learn to be more concise.)
What to build?
Have a look at Roger Plants website, http://www.bigcheeserobot.comhttp://www.bigcheeserobot.com - he has combined gearboxes and axles and motors to fit them, and suitable speed controllers.
2 axles: 30 gbp
2 reliance motors: 50gbp
2 Curtis 1208C speed controllers: 100gbp
Total 180 gbp for all the power transmission components you need, plus a bit for postage and packing.
This will not give you as much pushing power as Storm II but at this stage I wouldnt worry about it. It will almost certainly be more power than your wheels can put down onto the floor. You say you are more interested in innovation than winning, which is a commendable attitude, and you shouldnt worry about being underrated in terms of power. Reliability is more difficult to quantify and is, in general, better with tried and trusted components like these rather than bleeding-edge technology.
I would advise against building your own speed controllers. I tried this, and it was a very interesting project, but there were a lot of difficulties and I gave up once I realised I could get the Curtis controllers for 50 pounds. You may find that a lot of your existing knowledge of circuits doesnt hold when youre into hundreds of amps. Of course, you may know enough about this field to make a good job of it. Mine lasted about 30 seconds in its first proper fight, which was a severe disappointment considering they let down the time Id put into the rest of the robot.
Control electronics are much easier (from my point of view) and theres still room for quite a bit of creativity there if you just treat the speed controllers as power output stages. Just make dead certain it fails safe!
Best of luck.
What to build?
With the idea Jim brings, using a Plant drive, fairly cheap and useable, but not top of the bill(no Storm II like you mention), but for starters fine, and even has some resell value, if you are experienced enough to go for the expensive stuff.
So for the budget stuff, I have a foolproof on/of drive system, but as the relais, Albright SW88B 24 are reasonably expensive- £50 each over here, brandnew- no improvement over the Curtis actualy, but a fair basis for a homebrew speedo, needing only 1 mosfetbank.Just an idea I add.
Personaly I wont spend time on speedos. About every Dutch electronics wiz that tried it went over the budget needed to buy a Vantec.Only Kees Sicking, the builder of the Mythras speedos favoured in the Netherlands and Germany succeded to now.(Now Hammerhead used also hi powered homebuild speedos, but cheaper?)
Pneumatics. The cheap safe route is to go the compressor way. For a heavy, team up several of the small carcompressors. Im working on systems like that(for live event machines), and they seem to be damn cheap ,and if the batteriepower is on board, even lighter and longer lasting than CO2 powered low pressure systems.With the added benefits of cheap recharging, easy acces to replacement parts, and on top of that all, no liquid CO2 problems.
Now for more info about these things, my email, and even living room is available for a lot of questions(and the bar behind the corner has lots of good stuff)
MSN is also available.
What to build?
Youll need a lot of patiens if youre going to build a transceiver by yourself! I belive Jim has built a 459 MHz PCM radio for http://www.srimech.com/mode7/robot/index.shtml>
What to build?
Rather than the Reliance motor and £15 type S axle for your heavy weight, use my CIM2 motor and my type TE axle.
The CIM2s cost £75 each, cheaper than a Bosch and more powerful.
The Reliance motor is fine for fun robots but can€™t compete when pushing against the average heavy weight.
On 36 volts the CIM2€™s give 3.3 KWatts output each when driven by a 150 amp current limited speed controller.
They are very reliable too, I have been using them, at 36V and 150A, on my 170 Kg off road robot for 3 years, with no problems or overheating.
It does 15 MPH across ploughed fields and powers up steep slopes with ease.
The components to build your own chain drive with axles and bearings will probably cost more than TE gearboxes.
My gearboxes and motors just fix into the chassis as one unit, simply put your wheels onto the output shafts, you have an instant drive system without the alignment problems you will have with a chain system.
They are sealed from dirt, well lubricated and long lasting units that will out last several of your robot design changes.
I have sold over 500 units, many of them have made it onto RW on TV.
I now have adapter sleeves to take 25 mm bore Go-kart hubs directly onto the ¾ inch axle shafts on my TE gearboxes.
Two motors and axles cost £270, 4QD 120/160 amp 36 volt speed controllers £280 the pair.
I will be selling my own dual motor speed controllers soon for a similar price. They are especially developed for robots with all the right facilities built in.
One model covers 12 to 60 volts.
That is about half your £1000 budget so leaving plenty for the rest of the robot.
CIM2 plus TE axle weighs 8 Kg, 16 Kg for the pair, not bad for 6.6 KWatts of drive power.
The Reliance and type S axle will give you 900 watts output and weigh more than the CIM2 + type TE. The Reliance and type S have a much shorter life expectancy too.
I would advise on using the KISS principle for you robot design, I have gone the other route with The Mule and The Big Cheese.
The Mule was entirely home brew from aerial through speed controllers and gearboxes.
Fine if you don€™t mind fault finding to component level and replacing chips, between bouts, in your own electronics.
Much easier and quicker to change a complete standard speed controller, even borrowing one from an eliminated robot if need be.
All your robot building time comes to nought if you get unreliability problems from your own electronics.
I know it is more satisfying to build your own but very frustrating when the whole thing stops, just because you used an unwise choice of component in some vital part of it.
What to build?
Andrew, if youve ever seen the CIM motors in action, you know that theyre a fine piece of engineering.
What to build?
Big Nipper uses Cim2s, and with success.
I have the reliance motors in RCC2. They are fine motors, but as Roger stated in his posting not that powerfull. At the time though, i bought them keeping the cost factor to a minimum. RCC2 still drives and handles beautifully with the Reliance, but it is a very bad power to weight ratio.
So when i do a refit of RCC2, they will more than likely be with AEGs, or with CIM2/CIM4 motors.
What to build?
CIMs sound like a good option. But your arguments for Bosches also ring particularly true.
I think you are right to go with the heavy, having read your reasoning above. And I certainly think that flippers need powerful drive trains. Your objective as a robot builder is to deliver your weapon to your opponent. And the better drive you have, the better you will be able to do that. Id be very much inclined to go for 36V if you can. Bosches on 36V are a fantastic drive (as Tornado demonstrates so eloquently (in as far as fighting robots can be considered eloquent :o). Geared down reasonably for something like 12mph (a very good speed for most live event arenas). If you get some decent current limiting speedos, then youre laughing.
As for orders of magnitude, well, yes conceivably, but there is absolutely no reason why (apart from money obviously) you shouldnt have a 36V LEM powered drive train- LEMs weigh as much as Bosches, and whilst you need a slightly more resilient drive train to cope with them, that is made up for by having considerably lower RPMs, so not so much reduction required.
That brings me on to Speedos. You can build them, yes, but they will probably end up being more expensive, but certainly a fantastic learning curve, and when they do blow up, youll be able to fix them. The low power side is basically a PIC, which, being a software person :o) you should have no problems with. Im not a software person, but I can cope with PICs, and that is the more fun side of the current speedos Im building. The high power side is more difficult for me- I can cope with MOSFETs, their drivers, high and low side, charge pumps and so on, but current limiting is giving me enormous headaches, to the point that Im tempted to get some logic level MOSFETs with built in current limiting. While their on resistence is fractionally higher, we can get round that problem by paralleling them. The choice between H-Bridge and Relays is largely a software one. H-Bridges are harder to program for, but are nicer in terms of control. I would go for a relay controller however, as it uses fewer MOSFETs (cheaper and considerably less bulk when you consider how banks of MOSFETs in an H-bridge need to be arranged, plus you dont need a complex system of copper buss bars), is easier to program for, you dont have to worry about high and low side driving, and a number of other reasons which are randomly entangling themselves in my head. If you wont to get something on the arena, and having fun, buy some 4qds or similar (or perhaps a roboteq- though that€™s probably a little on the expensive side) then you can build speedos on the side, and incorporate features into them as you begin to get an idea of what you want in a speedo. As I said, theyre fun, satisfying projects, but not really enormously practical for a first robot.
Ground clearance- the likes of Cassius and firestorm produce rather elegant wood shavings as their fronts plane across the floor. Storm 2 has more ground clearance than I expected, however it still seems to get under everything because its front is so bloody hard, so delivers its KE more effectively into the opposing robot such that the opposing robot jumps up perpendicular to storms wedge, and so storm gets under it. At least that€™s what seems to be happening last time I saw it.
No need to apologise for long ramblings, theyre well punctuated and readable, which makes a refreshing change. Although far too much time spent on MSN has done no favours for my typed English, Im still very much from the €˜Babeth€™ school of thought when it comes to forum postings, as the way you/one writes speaks volumes.
What to build?
Cayenne has 459MHz radio as does Serrano, but they use the LPRS modules which work a bit like a one-way radio modem. I dont have the equipment to do the actual RF stuff myself.
What to build?
Thank you for your feedback, everyone. Excuse the delayed reply - needed time to sit down for a good witter! Here goes, and I hope some of this is still of use to other beginners who read this thread...
Babeth: Meant to say before, your rule 1 is very well phrased (as I would expect of you!) The complex robot designs which I have on paper are complex because of a high degree of redundancy. I include a long list of failure modes in the designs, and how they would cope with them. This thread is about avoiding having more failures than I can design around. :-)
Thank you, everyone, for the advice on motors. I remember Rogers site of old (i.e. about a year ago - Ill get my zimmer frame out) and the Cim2s sound like a good option. Big Nipper did indeed seem to have good performance (nippy, as it were). Im trusting that Im not going to have too much trouble with replacements if I go down the Cim2 route - I remember Roger being involved in another thread last week about problems acquiring replacement magnets for Bosches, so my perceived benefit to using them may not in fact be valid. Roger - should I be doing something on your web page to get a more complete catalogue? Ive never been quite clear from your site precisely how much you sell - you seem to mention things Ive not seen listed - should I be contacting you directly for more details? I know you have better things to do than be a webmaster, so this is just an inquiry, not a criticism!
The gearbox combination also sounds like a good thing for a novice. Strangely, many of my designs seem to have such odd drive mechanisms that the stick a wheel on an axle advice may not be as much use, long term, as youd think. But still, I could be better off starting with a managable RPM and hooking that up to something odd in a single stage, rather than trying to build the gearing into the mechanism myself. Give me a year or twos practice with a welder and I hope Ill be showing the community what I mean!
My only concern about a single piece unit is the possibility of repair. If I snap a chain or shred a sprocket, its not so much to replace, but Im not sure what can be done to a knackered gearbox. Obviously Im planning to shock mount the drive anyway, but am I going to have to buy them in bulk for every tournament, or is there a chance of repair?
I might take Eddys advice when it comes to speedos - buy a couple, then start building some. My biggest concerns are over paying for unwanted facilities, and the one size fits all problem. I doubt Ill ever have a use for mixing - even when I start Ill probably have a PIC doing some work to add some failsafe and add a bit of autonomous control. It seems a waste (and less reliable) to generate PWM speed control from a PIC and have to shove it into an analogue speed controller input. Anyone got a speed controller which, essentially, just does the current limiting and drives lots of FETs? What do the - apparently single channel - Curtises do?
Also the number of motors and power required from them is likely to vary vastly between my robots: Ive expressed an interest in innovation, and that means that whatever I build, and however ineffective it will be, Im unlikely to end up with a box on 2/4 wheels very much. My most developed design uses 16 independent motors, each needing speed control... (but it would keep functioning, after a fashion, with only a couple intact - and Jim, dont worry, the bleeding-edge technology is all my own, and therefore a lot cheaper than using anyone elses!) Ive had a cunning plan for a first design which is much simpler (Roger should be proud of me for applying KISS), but the big money needs to be spent while thinking of the long term.
On the other hand, the prices people have been stating for controllers are lower than I was led to believe a year or so back; possibly the market has moved on, or maybe I just memorized the Vantec cost (I remember the £4-600 bracket). While I still dont want to throw away more unnecessary speedos than I have to, it sounds like Im not going to blow the whole budget on something I can only use once.
Jim - thanks for the radio components tip; actually I could use bidirectional data, so I may well be better off just buying a radio modem and being done with it. Ill have to investigate - someone gave me a pointer on the old forum, and I can dig it out.
Mario - I realize you should know, but about the compressors: really? I was under the impression the power to weight was far inferior to a CO2 cylinder, but Ill believe you, and I guess the choice of low pressure would help. Obviously it would make my life easier, consumables-wise, in terms of testing at home, and might avoid me venting an entire tank in a closed room and knocking myself out...
[Ironically, having bought my new camera for taking snaps at Debenham, I asked about cleaning the sensor. You cant use propellant-based air dusters, youll have to use carbon dioxide; I can give you the name of a manufacturer said the bloke in Jessops. I advised him Id probably cope. :-)]
Also, thank you, Mario, for the offer of help - you may come to regret it as I get my plans together!
Finally, thanks, Eddy, for the reassuring news about Storms ground clearance. Now I just have to find a way to exploit it! Also, thanks for the reassurance about my heavyweight reasoning - very welcome to hear someone tell me Im not spouting utter nonsense - and Im glad Ive fooled you into thinking Im coherent. :-)
(The tiddlywinks crowd I hang around with are the most pedantic people I know, and include a fellow of classical linguistics. Babeth holds few fears for me when I spend my time with people who use pusillanimous and callipygous in regular conversation, and using less when you mean fewer brings months of scorn.)
Oh, one last thing. I was looking up the FERM MIG 100 TURBO MIG WELDER on Screwfix Direct. You might also be interested in... Chainsaw. Theyve dealt with us before, havent they? (Who else would need both a welder and a chainsaw? How do you weld the tree back together again? Unless youve just lumberjacked a cellphone mast, obviously.) :-)
Thanks again, everyone. I hope to be able to enter something within the next few paycheques!
Fluppet
[Britney mode: Yargh - I did it again.]
What to build?
The Curtis controllers are single channel, they take a variable resistance or variable voltage input. Annnoyingly, it has 2.5V as the centre (off) position, so you have to be careful you dont switch them on with 0V applied as this is full reverse. The PICs I use have a single PWM output to generate a variable voltage, so I have four PICs running the drive motors on Cayenne, and another two running the weapons. The only speed controller Im aware of with more flexible input is the rather pricey RoboteQ which accepts RS232 input.
If you find a radio modem which works on 459MHz or 40Mhz please let me know. If you want to use other frequencies, prepare for a bit of debating with the FRA.
What to build?
Thanks, Jim. Are you actively smoothing the PIC output for the Curtis, or is there enough capacitance in it anyway? Maybe it doesnt matter, but if its point sampling then I could see some weird beating effect could happen. Just being paranoid. And thanks for the 2.5V warning!
Ill certainly publicise any radio modem I find, but it sounds like - if youve been looking for one and not found it - Ill be doing some soldering. Im not planning to be a pain regarding odd frequencies (if I was going to play those games Id stick an 802.11b card in the thing and make much of my life simpler) so if I can only find something inappropriate then Ill roll my own.
Cheers for the feedback,
Fluppet
(Woohoo - short post.)
What to build?
The mythras speedos from Kees have a bus using an rs485 driver, but not using the rs485 protocol. In stead it uses standard serial communication over the rs485 bus. It runs at 57k6 bps and is verry easy to controle. You can select an adress on the speed controler and just hook them all up to the bus. I dont know if this is what you are looking for, but I just thought id mention it.
What to build?
Hmm. Thank you, Stefan - thats certainly worth me looking at. Ill investigate.
Fluppet
What to build?
Id be interested in gaining more info about the mythras as everyone seems to be singing its praises. Any good links?
What to build?
http://www.mythras.demon.nl/http://www.mythras.demon.nl/
But you wont find much information there. All I can say is that the price of a speedo is 190 euros and an interface is 60 euros. The speedos are great, the interface is suitable but not brilliant.
Standard theyll do 75A, but Kees also can tweak them up to 200A on request. They have 3 fets per leg. I know of someone who accedentally ran them at 72V for a short perriod, and they didnt blow up. If you want more info, you should probably mail Kees. He is quite busy though, so a response may take a while.
