Heavyweight DataBase
well every other thread has a database and Id love to kow how many heavies are in the UK
ok
Tanto
2x briggs and Stratton Eteks
either 36 or 48v
no weapon back to basic full body hammer
550mmlong by 600m wide 300mm tall
covered in T6 front and sides are 21-24mm thick back is 18mm thick rest vaires from 12 to 6mm thick
can anyone say Brick?
Gman
2x bosch 760s
24v
16bar flipper
3ft by 16inch
HDPE 10mm armour with some ti
Merlin
Bosch 750s
24v 13Ah Hawkers
FP flipper
3-6mm steel (hopefully hardox soon)
Invertable and SRIMECH
http://www.teammad.co.ukwww.teammad.co.uk
No sorry not just UK
everyones welcome
Revolution 3
Bosch 750s (3)
12kg 2,500rpm 8inch Flywheel
Invertible
Ni-Cads
Polycarb / Ally
Corkscrew 2
Drive Two Bosch 750,s
30 kg outer boby spinner
1 x mag for weapon
Invertible
5x24v Ni-Cads
15mm T6 and 2mm Tie Armor
Splinter
Drive 2 Bosch 750s 24V
Pneumatic Axe and clamping arms
4 SLA batteries 12V 7Ah 2x2 connected
virtually no armour
RCC2
Drive 2 Reliance electric motors 24V
linear actuator driven scissor weapon on 36V
SLA batteries 5x 12V 7Ah or 3 x 15Ah depending on event.
Alu 10mm armour
Mute
LEM 130s
24V 9Ah NiCads
Front & Rear FP Flippers
4Kg CO2
2.2mm Stainless, 4mm-8mm Gr 5 Ti, 6mm ally, 12mm Polycarb, 8mm Kevlar, 10mm poly & a few big chunks of 20mm Stainless
620mm wide x 950mm long x 220mm high
Big Nipper
3 off CIM2 Motors
15mph?
Nicads, 28.8V 4.8Ah Drive, 36V 2.4Ah Weapon, 4.8V Rx
Extremly slow Electric lifter with 270 degrees movement.
Extra Extra slow Electric Crusher
66cm wide, 66cm long (excluding arm), 15cm High.
5mm Ti Sides with 10mm Ribs, 6mm elsewhere, Ally bolted chasis 25-30mm (full of holes).
3 4QD pro 120Amps Speed controllers, custom microcontroller mixer board, 2 electronic clucthes for weapon.
Piano wire Ariel.
Solid Ti Spiked wheels 3 Dia.
8 Wheel drive (4 on botton,4 on top).
Fluffy Dice.
Spike
2 Bosch GPA750 @ 36V
2 Mythras 75A speedcontrollers
Pneumatic axe powered by fluidic muscles
6 Hawker Cyclon 8Ah (may be replaced in the future, Cyclons are rubish)
Steel frame
4,5mm Ti-6Al-4V side armour
24mm HDPE top armour
5mm aluminium bottom armour
spiked steel wheels
TSUNAMI
2 Bosch GPA 750
2 Mytrhas 75A Speedos
Haker Genesis
Steel frame
Titanium Grad 6 armour
FP Flipper
2 Rams 50mm
Srmech
Bulldog Breed
Full pressure Flipper ,
2x2kg Bottles
1x1litre Buffer tank
I 80mm Specially M/P Cylinder 8500pound /thrust
2xBosch GPA750 motors
Armour Titanium/4mm Hardox
Bags of attitude (jp says so!!!):)
For anyone else who posts on this thread, could you indicate whether you would mind having your details in a database for a website Im building? You would of course be able to change or withdraw your information at any point.
OK,
Cayenne
930x740x200mm
4x Iskra 800W
4x Curtis 70A Speedos
4x Hawker PC680 Batteries
10mm Polycarbonate armour with steel subframe
Weapons: ramming spikes and harsh language (LED moving message display)
Invertible
Serrano (previously Bob)
2x Reliance 800W
Roger Plant gearboxes with kart rear wheels
2x 17Ah Kiel
RoboteQ controller (on order)
Welded steel chassis, Aluminium armour
LP Flipper, 3x50mm bore cylinders at 10 bar
Leveller 2
Basic wedge Robot,
Two Reliance / Litton 800watt motors on Roger Plant S Gearboxes, Roboteq controller, Hawker Genisis SLAs, LP Flipper, with twin valves and buffer tanks, 2k CO2, Steel tube frame with Stainless, Alloy, and polycarb armour.
List in database please Jim.
Put us on the database. Are the FRA going to have a database with a list of all registered teams/robots? It would be useful to produce an area map of where and how many teams are in each area.
Will do, Mark. The map would be quite possible, for the UK at least. I can do it by postcode. Anyone who wants to take part, list their team name and postcode here or send it to robotdb@mode7.co.uk. Ill make a proper annoucement later on so I can get teams who build for other weight classes.
Time permitting, I might be able to produce something by the end of the month. I dont know if the FRA exec have their own plans.
you can place my bots in the database, no problem.
thats splinter and rcc2, see above.
THOR
2x750 watt bosch drive
roboteq
full presure hammer with 190 degrees of swing
2014 t6 5mm ali armour covered with 8mm poly
Kronic the Wedgehog
2x750 watt bosch
Vantec RDFR36e
Two full pressure flippers (1x40mm bore [top] and 2x40mm bore cylinders [front])
40mm square extruded aluminium frame with 6mm polycarbonate shell
Tough As Nails (TAN)
1.17m x 1.16m x 0.35m
99 kg
2x Bosch GPA 750 @ 36V
2x Mytrhas 75A Speedos
3x PBQ SLAs 36V 9Ah
FP CO2 horizontal crusher, 1.2T
1x 2kg bottle
3-6mm Hardox 400/XAR 400 armour
Ceros-Icarus
680mm x 350mm x 350mm
Full Pressure Flipper
2x2KG storage tanks
1 x 3.5litre buffer
Ram 125mm bore 110 stroke with 2 burketts and a third for dump.
Hawker Odessey Batteries
2 x Technobots Power Drive motors running 20:1
Roboteq speed controller (still the first one built :) )
Dural, Ti, Polycarb armour.
Please add to the database :) thanks
Francis
www.ceros.org.uk
SCORPION
99Kg,
1.65M(L) X 1.15M(W) X 0.28M(H),
2 X 800W Littons @ 17:1 Ratio,
Vantec RDFR 47E,
3 X Hawker SBS15. (Due for Ni-Cad upgrade early 2004)
400mm Dia. 8Kg 5000RPM Spinner powered by a Lynch LEM-130,
6mm 2014 T6 ali./10mm makrolon armour.
Please add to database.
Regards,
Geoff & John.
Team Scorpion.
TAURUS (previously UFO)
98kg
2 x Littons
2 x 4QD Pro 120s
3 x Hawker PC680s @ 36v
Low pressure (10 bar) Front hinge flipper
2 litre buffer tank
2 x Rams: 63mm bore x 160mm stroke
All contained in 1/4 aluminium (6082 T5) monocoque.
Thanks
B
Mayhem
100kg
Drive: 2 bosch 750W
4QD with Technobots interface
24V SLA (maybe 36V NiCads in 2004)
600mm, 14kJ Steel spinning disc powered by Bosch 750W (maybe LEM 130 in 2004)
3mm thick steel monocoque chasis
Regards
Richard
Team Mayhem
Postcode CM6 1UQ
The first postcode! Thank you Richard.
Ive finally put some pics of Tanto on my website.
http://www.tantorobot.com/tanto2.htmlwww.tantorobot.com/tanto2.html
HANNIBAL
2 X 800W Littons driving 2 front kart wheels
4QD pro 200 speedos
3 X Hawker SBS SLAs
Full Pressure single ram flipper
10mm ali monocoque wedge/flipper with some Ti
Post code SS17 8NA
VERTEX
105KG (Drilling more holes)
2 x 4HP Briggs & Stratton PMDC Starters(4WD)
Testing the Robowars.org BMC speed controllers
2 x 15Amp SLAs
A uniquely constructed flywheel weighing 19-20kg powered by a 5HP two stroke Mac Culloch Chainsaw at 1700rpm.
Work hardened 3mm Aluminium with a 1.6mm/3.0mm steel chassis.
Post Code: 4600
From now on could you just put the outward portion of your postcode (i.e. SS17 or M20) - this is enough to locate you on a map without giving away too much personal info. Cheers
Revolution 3
Previously listed (minus postcode)
Post Code: G75
Ceros-Icarus
Listed but minus LE11
Cheers
Francis
http://www.ceros.org.ukwww.ceros.org.uk
Merlin (at top somwhere)
LE67
MANTIS - NG24
2 x Bosch GPA 750
2 x 4QD NCC70 24v
2 x Hydraulic Powerpacks & Rams
2 x Micro Keil 24v 18Ah Batteries
Grab & Lift construction
All Steel, All 100kg Heavy
http://www.mantis-robot.co.ukwww.mantis-robot.co.uk
Right, I said Id do something before the end of the month! My first attempt at a map is now on my profile. It was a very cloudy day when I took the aerial photo of Britain. I have another map which I can overlay the points onto, but its tricky lining it up so everyone is in the right place.
For anyone interested theres also a very initial version of my database up at http://www.srimech.comwww.srimech.com - click on Robots from the front page. Have a play around with it if you want, its not finished so I make no promises. All feedback appreciated.
Aaron: Sorry I didnt include you on the map. Im guessing your postcode is in Australia, is it? I would like to do a world map in the future, but Ill need to do some research on your postcode system first. If you can convert it to a latitude/longitude that would help.
Oh yes.
That virtually no armour is now changed to 13 mm polycarb on the sides and back of Splinter.
Thundering
100kg
1.2(w) x 2.0(l) x 1m (h)
24V 200W EMD geared wheel motors
2 x Hawkers
4QD NCC motor controllers
1m dia rotary axe (500rmp) (100kph tip speed)
2 x Bosch 750 weapon drive
10kph speed
What happened to Thundering?
