Need Help
HI I am new to this robot stuff and Im looking for help with building my first robot. Since I have worked for a long time with things on Tracks I plan on building a tank like robot. With spinning weapons and numatic lances. I need help on deciding how big to make this and how heavy. Since I can not seem to find any size limitations anywhere on line I figured I would ask. The weight thing I think I found somewhere that said 220 pound or is that killograms? Anyway I need help. I am located in Pa in the USA . and if there is any one near by that could help me please e-mail me.
Need Help
220 lbs. For a walker its 200kg. There are size limitations on the official rules.
Need Help
Just looked at the specs. Heaveyweights can be up to 220 pounds walkers 441 pounds . Why can walkers be heavier? Seems they should all be allowed the same thing or is it they feel more weight on the walkers the harder to beat them, I have seen a few walkers be taken out with the exposed hydralic lines being pinched or ripped off.
I can not seem to find the size limitations I have been looking at the 2003 rules and regulation page I was sent. Where do I find the size limits?
Need Help
the reason that walkers get a weight advantage is that the walking mechanism is alot heavier than a wheeled robots one
if i remember correctly robots had to fit within a 1m by 1.2m rectangle
Need Help
From the Robotwars rules for series 7, but i dont think it changed over the years:
2.2 Dimensions
2.2.1 Overall dimensions must not exceed 2 metres x 1.2 metres.
Need Help
By the way, if you do make your robot that big, your going to have lots of problems keeping the weight down or making a solid construction.
as far as the walker issue: the organisers of robotwars have a policy what is and what isnt a walker. if you make a walker with just a camshaft system, you will not be allowed the weight advantage.
Need Help
As hes decided on tracks, thats not a biggy.
If you are considering entering Robot Wars, rather than Battlebots, you must keep to the metric weight limit of 100Kg for wheelers / 200Kg for walkers). I believe that Battlebots and spin-off events have limits of 220lbs / 440lbs. I believe Battlebots used to have a very, very generous size limit that prevented robots being too big to enter the arena, but I have no idea what the limit might be!
If you havent already found it, the BB tech forum at http://forums.delphiforums.com/n/main.asp?webtag=BattleBot_Tech&nav=start&prettyurl =%2FBattleBot%5FTechhttp://forums.delphiforums.com/n/mai...v=start&pretty url=%2FBattleBot%5FTech deserves a visit.
Need Help
Leo,
The rules do change. The maximum width for Series 7 was 1.2 m, whereas for Series 6 it was 1.4m. Mentorn wanted to reduce the max width to 1.1m for Series 7, but were persuaded against it. It could come down to 1.1m for Series 8, if that takes place.
Jeremy
Need Help
So If I read this right 2m x 1.1 would be a safe overall measurement 78 x 43 , thats a lot larger than I was thinking of making my robot. and I have decided on Tracks Not wheels for the weapons I am designing. I am thinking of some shape that can be rolled over but still be functional. I have the sides worked out so it can be rolled onto its side but end right back up on top or bottom , that works with my small model I built out of clay , But the weapons would have to be positioned where the retract into the main body to allow for rolling over. This Im still working on,
What fun something else for the wife to yell at me for. :) I have been doing a lot of research on radio controls what do most of you use manufacturer and number of channels.
If you r interseted in seeing what I do for a living go to my home page http://www.goldingtparts.comhttp://www.goldingtparts.com
Note the bus project.
Thanks for the help Ill be asking more questions all the time till I have this built and probably after. Some day I hope to meet you all in the RW arena.
Need Help
Mark, unless you are planning to enter events in the UK, Id check out what the regs are with radio gear in the US, I think 75Mhz is a more used frequency over there, whilst we are stuck with 40Mhz
Need Help
The only reason I would be building the robot would to eventually come over there , But I guess it would not be too hard to change the radio & reciver right?
I see in the instructions reference to crystals being excessable, are these the chips to change the frequecies so both operators dont have the same freq.? Does this happen often. And as for the removible links , I see in some of the fights that the links can become disloged, is there a better link that can be used or is this a standard unit that has to be on the outside of the robot ?
Is Killercarrot a robot? if so when are you going to be in the arena so I can watch for you?
sorry for all the qwuestions but being new to this Im going to keep asking them.
I check all the Robot forums each day and Im learning a lot.
I just designed the tracks Im going to be useing and I dont think Ill have a problem with them coming off or someone getting under them.
I know I have been told I should build a wheeled robot first but my back ground in tracks goes way back to when I was a Tank machanic in the army. I have in my yard more tracked viechiles than any one else in my area including a For Model TT Tracked Armor Truck . its like a half track. Went to town today in it we have 18 of snow on the ground.
Love the looks I get. So this is one of my tracked reasons for building a track robot.
Thanks again for the help.
Need Help
yes Reciever crystals swap out to prevent overlaps of frequency. I use a selection from 40.675 to 40.975. RW specify a minimum of 3 sets, and you have to be able to swap them quickly.
The crystals are simple push fit affairs, and you need a matching Rx Tx pair, costing about £10. Radio gear can be swapped, but its not inexpensive to use only if you visit the UK, though when added to the cost of shipping to the uk, travel etc, I guess it comes out pretty minimal.
I would be more concerned about bringing over a crated machine,swapping the radio gear and running it without proper set up.
removable links are easily steadied with a little tape on one side, this isnt enough to stop the link being pulled if it needs to be, but does stop things rattling loose.
Killercarrot is a robot (slaps back those who would argue the point), and was aired last week, heat F, where we drove badly, but lost well.
Its been said before killercarrot flies well
piccies of the carrot if you follow links on the worthing live event section (its the orange one).
Need Help
Note that converting a 75MHz set to 40MHz generally requires more than simply changing the crystal, and some makes dont convert.
You will need to use 75 for testing at home or risk jamming frequencies used for some other purpose (or being jammed, which you may consider a worse problem...), and aquire 40 for competition in the UK.
That tracked truck sounds great!
Need Help
http://photos.bravenet.com/163/947/593/6/8254F85518.jpghttp://photos.bravenet.com/163/947/593/6/8254F85518.jpg
this is a picture of one of the trucks in the snow
Need Help
that last link didnt work so heres another
http://www.ttparts.net/pic48317.jpghttp://www.ttparts.net/pic48317.jpg
I just want to say thank you to everyone that is helping me with this robot.
is ther a way to post pictures tight here in the posts??
Need Help
Mark,
I admire your tracked vehicle, and I wish you luck with your design.
The few tracked vehicles that I have seen on Robot Wars have suffered from damaged tracks and loss of mobility very quickly. Superior pushing power is not worth much when you have lost one of your tracks. The drive on tracked vehicles is relatively heavy, and the engineering is complicated. My view is that you need that weight for armour, but you are clearly an expert, so.....
Need Help
I have been thinking I might just build two different robots one on tracks one on wheels and see which works better. Then I also have something to battle against before going against an oponent.
I will just have to see which is better to design and work with , Trail and error I guess is the way to go. Your all so lucky iover there to have a place to gather and test your robots against others. I will have to find others here in this area that have them also, but it looks like most of the compition will be on the west coast , a long way from here.
Ill keep you all informed.
Need Help
Hi
This is not related to Marks question, didnt want to start a new discussion. Im trying to measure the voltage to a motor that is being acelerated by a PRO 120A controller. The voltmeter is in parallel with the motor. Im getting really wierd readings. Anyone know what im doing wrong? I think it may be due to the pwm of the controller but am not sure.
Need Help
Unless you give full throttle, the voltmeter will show an average value of the PWM signal.
Have you tried using an oscilloscope?
