HP buffer tanks
im abit unsure about the rules concerning HP buffer tanks. Are bottles such as the small welding bottles and sodastream bottles ok to use as buffers? I know they are no longer allowed by RW as supply bottles, but i cant find any rule saying they cant be used as buffers. Is there any rule concerning them? We are looking at improving the flow into our ram, and we cant fit a 1.1kg bottle in (if we could we would use it as a main tank and carry extra gas anyway).
cheers
HP buffer tanks
If you consider the Mentorn rules, you make use whatever you like after the bottle.
The FRA rules ask for some kind of certification that the part will survive the job.
HP buffer tanks
Why not hack away at one of your 600g Co2 Bottles Alan. :)
Stu
HP buffer tanks
i used a small oxy tank for the buffer tank at rw and it passed if any one wants one i have one left they need the conectors welding or brazing oni can bring it to witw
HP buffer tanks
If no one wants it ill have a look if its not gone by WITW, im still pondering over getting bits for a pneumatic featherweight, and I dont fancy hacking up and putting back together anything to do with the storage side of Co2 gas :)
Chris - http://www.featherweights.org/forum
HP buffer tanks
Just ignore that im getting confused again, never mind me carry on, more along now.
HP buffer tanks
Alan, yes im pretty sure you can use soda stream bottles as buffers,
Another option would be a disposable mig welding co2 bottles, Take the 1/8th fitting of the top, drill out a larger hole and push about 25mm of steel pipe in...Drill out the pipe and weld it to the bottle, then tap the pipe to 1/2 BSP...have it certified and that should be enough.
How many liters of gas do you need your buffers to carry?
regards
Dave moulds
Team Turbine/PLF
HP buffer tanks
It depends on the cylinder volume, but according to Mario, three times the cylinder volume should be sufficent.
HP buffer tanks
Right, 3* workvolume -cylinder(s)volume- is what I use as guideline.
In the Industry the formula is 5 times workvolume, but that is way to big for our purpose.
HP buffer tanks
But you never know, there might come someone who dislikes armour and has a lot of excess weight?
HP buffer tanks
Lee was your small oxy tank one of the BernzOmatic type? How do you go about removing the fitting from the top? And isnt it dangerous?
They sound like a good idea as theyre very light even when full of O2.
-- Kev
HP buffer tanks
didnt know this thread was still here, saves me having to start another!
now we have the bigger ram in merlin we need to fit in somes buffers. Im currently thinking of 2 sodastream bottles, as they are about the right physical size and have a handy 1/2bsp thread! ive got the bottles and emptied them, but i now need to remove the valve in the end, im assuming it just screws out? i want to make sure before i blow myself then length of the garage! or does anybody have anything already, about the same size?
cheers
HP buffer tanks
I use two of the 0.8litre aluminium paintball bottles as buffer tanks for my full pressure system. They are rated for CO2 pressure. I bought then on Ebay for ~£22 each. I have taken the bottle inlet up to 1/2BSP, and will be getting the bottles professionally retested before use. This costs £20-25 each.
Jeremy
HP buffer tanks
The tops of steel Sodastream bottles just unscrew ...theyre are thread locked on so you may have a fight on your hands.
You could just unscrew the pin valve ( slotted bit in the middle unscrews ) and then drill out the centre of the brass valve.
HP buffer tanks
Piccy of various size bottles uploaded on my profile.
HP buffer tanks
i was planning just to remove the valve (the bit with the pin on) and leave the brass fitting on. but i cant unscrew the stupid thing! so i might have to remove the whole brass fitting. If not ill just cut it off and weld a fitting on the end!
HP buffer tanks
Why bother, I have several rebuilded and tested oxygen bottles with different treaded neck available. 1/2 bso or 3/8 bsp, even 1 with a 3/8 hydraulic hose fitted on.
HP buffer tanks
Ill happily dismantle a couple of bottles for you Alan...
BTW ...The thread on the steel bottle is a std BSP Size ....3/8 as I recall.
HP buffer tanks
The tread I found on the sodastream bottles over here is M18*1.5
Handy as that is the metric version of 3/8 bsp.So getting more common over here each year;
HP buffer tanks
If you remove the whole brass fitting it is definatly a 3/8 below.
HP buffer tanks
cheers chaps, ive removed the brass fitting and they both are 3/8bsp. The first one came off easily but the second was on rather tight! isnt it always the case. Ive also got a smaller bottle, similar to a sodastream bottle that i think is out of a water fire extinguisher, so might put that in as well (that also had a brass fitting onto a 3/8), so might have all three in!
HP buffer tanks
If you have gone to a bigger ram, what have you done with your old one ?
HP buffer tanks
nothing at the moment, but i think its more or less knackerd! it had new seals put in for the world champs, but it seemed to start leaking within a few events. i think the cylinder walls have got damaged.
HP buffer tanks
If M18*1.5 is the metric version of 3/8 bsp whats the metric version of 1/4 bsp ?
HP buffer tanks
http://www.adneish.freeserve.co.uk/threads.htmhttp://www.adneish.freeserve.co.uk/threads.htm
M14 fine is the nearest in physical size to G1/4 ...1/4 Gas .. 1/4 BSP.
